How To-Front/Upper Fairing Removal - 600RR.net
03 / 06 RR This forum is dedicated to all the How to write ups for 03 to 06 RR
post #1 of 70 (permalink) Old 05-13-2006, 12:19 AM Thread Starter
BiGxbOix510's Avatar
Images: 63
Found a write up on it earlier but his pics are [X]. So here's a quick one.
Had to take mine off to play with tripage's third light+install magic blinker for my watsens, so I thought "Hey, what the hell..."
HOW TO REMOVE FRONT FAIRING
(On my 05, shouldn't be that different from 03-04)
1. Start with the 3 Hex bolts on each side of the fairing.
2. Go under the fairing, behind the wheel and find the last screw that connects to the radiator, loosen it until you can spin it with your fingers and yank that sucker out. Each side.
3:(EDITED, BIG THANKS TO NewRedRider FOR THIS SHORTCUT!)-You don't have to take the mirrors and the windscreen off. All you need to do is remove the 2 bolts holding the main fairing stay on and the entire front clip comes off. The guage cluster and mirrors stay on the front clip. All your doing is removing the ram air covers and disconnecting the PIN connectors.
4. No go back up to the mirrors and lift/pull the fairing up to get it off with the stay and windscreen in one big piece. Might get caught around the middle fairing, reach down and guide triangle ram air tubes out.
2005 600RR Black Metallic (I miss it already)
2008 GSX-R750
http://www.myspace.com/bigxboix510
BiGxbOix510 is offline
The Following 3 Users Say Thank You to BiGxbOix510 For This Useful Post:
id4rox (07-20-2012), Reaper (03-16-2011), USArmyCombatMedic (01-27-2012)
post #2 of 70 (permalink) Old 05-13-2006, 12:20 AM Thread Starter
Images: 63
5. Pull it slowly towards you and down, wiggling from the bottom to loosen the airducts from their locations. But don't take the fairing out completely, just to break it free.
6. Look under the clutch side airduct and unplug the 2 main connectors, there are lock buttons to push in+hold then you pull it apart.
7. Pull off the fairing slowly making sure it's not connected to anything on the bike. Now it's halfway to a streetfighter...
8. And you are pretty much done.
Putting it back is not as easy as getting it off, but it's pretty easy. While slipping on the airduct tubing+reconnecting the 2 main connectors to the wire harness. Play around with it to fit. Then it's rather basic reverse steps. Good Luck.
2008 GSX-R750
Jhoney (01-26-2014), Reaper (03-16-2011), Vicious M3 (04-09-2012)
post #3 of 70 (permalink) Old 05-13-2006, 12:40 AM
TonyTheTige-rr's Avatar
Location: Vallejo,California, Riding all year long baby!!!!
very nice write up, when we first took out my front fairings we took alot of screws underneath where the intake air ducts are, after doing that we were like "wait a min didnt need to take those out"
www.707photography.org
[canon 60d] [17-50 2.8] [50 1.8]
TonyTheTige-rr is offline
post #4 of 70 (permalink) Old 05-13-2006, 10:50 AM
NewRedRider's Avatar
Images: 24
Nice write up. One thing though. You don't have to take the mirrors and the windscreen off. All you need to do is remove the 2 bolts holding the main fairing stay on and the entire front clip comes off. The guage cluster and mirrors stay on the front clip. All your doing is removing the ram air covers and disconnecting the PIN connectors.
I borrowed your picture.
NewRedRider is offline
The Following User Says Thank You to NewRedRider For This Useful Post:
Reaper (03-16-2011)
post #5 of 70 (permalink) Old 05-20-2006, 01:24 AM
so all you do is take off the 3 side allen bolts and those two bolts you circled and ur done?
post #6 of 70 (permalink) Old 05-20-2006, 01:51 PM
Images: 24
Yeah, instead of taking the fairing stay off the front fairing, you take the fairing stay off the steering stem. Don't forget the trim clips in the resonator by the radiator and your PIN connectors to your gauges. That's about it. Just use the mirrors to hold each side. Why they show all that crap in the SM is beyond me. This is so much easier and faster. Less parts to take off and replace. You can bet your a$$ the dealer doesn't take all that crap off.
post #7 of 70 (permalink) Old 05-30-2006, 12:30 PM
anicca's Avatar
i can't see the pics of the original poster, is this sticky fuct or should i go with what Red wrote up?
anicca is offline
post #8 of 70 (permalink) Old 05-30-2006, 01:10 PM
Images: 24
Trust me. Go look at the bike and tell me I'm wrong.
BTW, Photobucket sucks! Use www.imageshack.us. Never had a problem with them.
post #9 of 70 (permalink) Old 06-03-2006, 12:56 AM Thread Starter
Images: 63
Bump, Fixed the pics!
(i moved them in my album, forgot about what it affected)
Edited in NewRedRiders shortcut.
(Thanks a lot! That way saves a lot of work.)
A few pics are not what it would look like with taking off the fairing stay,
but I doubt anything crucial is missing. Take care.
2008 GSX-R750
post #10 of 70 (permalink) Old 06-04-2006, 03:04 PM
Images: 24
Good fix man! I don't want to see my boys working any harder then they have to.
post #11 of 70 (permalink) Old 06-09-2006, 11:21 PM
Ichiro's Avatar
what's the torque spec for those fairing stay bolts?
05 RR Slv/Blk
Super perfundo on the early eve of your day
Ichiro is offline
post #12 of 70 (permalink) Old 06-10-2006, 08:34 PM
Images: 24
I haven't found one anywhere. So I'm guessing 15-20ft/lbs with lock-tite.
post #13 of 70 (permalink) Old 06-10-2006, 09:52 PM
Ruler007's Avatar
[img]www.600rr.net/vb/attachment.php?attachmentid=2187&stc=1[/img]
Ruler007 is offline
post #14 of 70 (permalink) Old 06-11-2006, 04:32 PM
Ichiro's Avatar
Dude, your attachment didn't work try again
05 RR Slv/Blk
Ichiro is offline
post #15 of 70 (permalink) Old 07-02-2006, 01:41 PM
blue_rrockit's Avatar
DAMMMMN i wish i read this two days ago *cry*
blue_rrockit is offline
post #16 of 70 (permalink) Old 07-07-2006, 04:56 AM
I had to take my nose off again to install a HID and flushmounts...one thing this guide doesn't mention is the trim clips connecting the air duct cover to the ram air tube. Don't forget those or else u'll rip a new one in ur air tube.
post #17 of 70 (permalink) Old 07-30-2006, 07:17 PM
Banned
ProphetX is offline
post #18 of 70 (permalink) Old 09-24-2006, 09:43 AM
TonyBarron's Avatar
thats the problem with the service manual, it reads like an installation in reverse.
To put it back together... that is. In reality, well thats different.
Great work BiGxbOix510...
TonyBarron is offline
post #19 of 70 (permalink) Old 09-24-2006, 10:02 AM
cojolio's Avatar
good info...a little too late because i took all that crap off yesterday... but now i know better...
BTW it was a B!tch to get the front fairing off....
Grunts own the night.
11Bang Bang!:evil1:
US. Infantry
http://www.myspace.com/cojolio
cojolio is offline
post #20 of 70 (permalink) Old 11-09-2006, 08:07 AM
DysanRR's Avatar
TTT
I just did this install lastnight!. OMG!. What a PITA! I followed the guide here and successfully got the Front end off as shown. That was about as easy as it got. Putting it back together was a nightmare.. I highly recommend anyone else attempting this to have a buddy helping.. It would have saved me so much headache. Trying to hold that front peice by myself with one hand while attempting to get everything to line back up, holding wires out of the way, plugging in those 2 connectors, etc with the other hand. Ughh! Then I tested the lights only to find one side not working!. While still holding everything I managed to get a better lock on the wires with the inline splicer so it's working again.
The biggest issue for me after the above was getting all those little plastic tabs you pop into place to line up. Then I kept losing those rubber fairing nuts.. They'd pop out and fall down inside the bike somewhere.. Son of a!.
Anyhow, the aggrevation was worth it.. The bike looks 10x better already!. Thanks for the Guide!
2006 Honda CBR600RR Light Silver Metallic
Hotbodies Flushmount Turn signals, PUIG Dark Smoke DB Windscreen, Yoshi RS-5 Ti Slipon, Tripage LED Rear Pegs PC Black, SPR Fender Eliminator, OES Frame Sliders, Black Painted Engine Covers, Melted Gauge Cluster - Thank you Puig DB
DysanRR is offline
post #21 of 70 (permalink) Old 11-10-2006, 11:07 PM
belleater's Avatar
what did ppl use to get the 2 bolts off? im having trouble fitting a wrench in there.
belleater is offline
post #22 of 70 (permalink) Old 11-10-2006, 11:23 PM Thread Starter
Images: 63
Try this....(hope you've got TOOLS!)
12mm flexible socket, extension, and ratchet.
2008 GSX-R750
post #23 of 70 (permalink) Old 11-11-2006, 01:22 AM
belleater's Avatar
thx for the picture but i dont have that long of an extension. i got the top bolt off with a wrench. but the 2nd one is sill cramped in there. i think even if i did have a long extension i still wouldnt be able to get the lower bolt off. i have an 03.
post #24 of 70 (permalink) Old 11-11-2006, 01:56 AM Thread Starter
Images: 63
The extra leverage with the ratchet just makes it alot easier to reach and loosen.
If you've got enough wrist+arm power
Small ratchet...
Small wrench...
There's always a way, just gotta find it.
And if you don't have the tools.....you gotta do it the hard way. :\
2008 GSX-R750
post #25 of 70 (permalink) Old 11-11-2006, 07:36 AM
belleater's Avatar
alright im going to give my friend a call for some tools. thanks a bunch for the pictures!
post #26 of 70 (permalink) Old 01-05-2007, 04:31 AM
chrism67177's Avatar
if i would have seen this before, i couldve saved 80 bucks to get my LP flushmounts installed!
RED RIM STRIPES
LP EURO LED TURN SIGNALS
COMPETITION WERKES FENDER ELIMINATOR
SHOGUN FRAME AND SPOOL SLIDERS
OEM REAR SEAT COWL
YOSHIMURA RS-5 CF W/ CF CONE
chrism67177 is offline
post #27 of 70 (permalink) Old 01-18-2007, 12:03 AM
watsgowinon's Avatar
damnit... i know I should've read here first.
watsgowinon is offline
post #28 of 70 (permalink) Old 03-20-2007, 07:23 PM
WTFFFF!!!!! I was looking for this for days!! just figured it out on my own and now i find this!! ERRRRRRRR
CBRdave is offline
post #29 of 70 (permalink) Old 03-30-2007, 10:36 PM
Six
Six's Avatar
This really helped me out today on my repainting project. Thanks for the info.
Six is offline
post #30 of 70 (permalink) Old 04-08-2007, 08:38 PM
MAXIMUS
SWEET! I can't wait to try this tommorow, I just got my flush mounts so this is perfect. Will let you know how the progress goes tommorow.
Latimus is offline
Human Verification
