How to remove PAIR (Pulsed Secondary Air Injection) valve (write up by abadfish) - 600RR.net
03 / 06 RR This forum is dedicated to all the How to write ups for 03 to 06 RR
post #1 of 52 (permalink) Old 10-01-2006, 07:40 PM Thread Starter
**Miss O'Seven BOTY 2011**
Moeman's Avatar
Images: 647
Feedback Score: 148 reviews
check out this link for the write up
http://cbrworld.net/forums/thread/248171.aspx
Honrary Chairman
Deafet may serve as well as victory to shake the soul & let the glory out
A great deal of intelligence can be invested in ignorance when the need for illusion is deep
Moeman is offline
post #2 of 52 (permalink) Old 10-01-2006, 07:56 PM
Comb's Avatar
That's a good write-up... that's just how I removed my PAIR valve. I did option A with the vacuum plugs because it was cheaper than buying the block-off plates... and simpler too.
Comb is offline
post #3 of 52 (permalink) Old 10-06-2006, 10:04 PM
powderblueRR's Avatar
What the advantages of doing this to your bike?? Will i have to have the mapping redone again or not?? Thanks Terry
powderblueRR is offline
post #4 of 52 (permalink) Old 10-26-2006, 10:41 AM
deemack79's Avatar
thanx for the tip
deemack79 is offline
post #5 of 52 (permalink) Old 10-28-2006, 04:23 PM
xcessiv's Avatar
Images: 7
Feedback Score: 5 reviews
just like powderblueRR, id also like to know what it affects and does exactly. i dont like doing things randomly :( sounds good however. i wanna do this, the emissions stuff, and the velocity stacks, assuming everything doesnt have a side effect i dont favor.
The brighter the picture,the darker the negative
xcessiv is offline
post #6 of 52 (permalink) Old 10-28-2006, 05:24 PM
bananamane's Avatar
seems like a alot of work....does it give ne more power?
is that on all bikes or just CA?
2003 RR Black
DIY Stacks
Yoshi S/S
Hotbodies Flushmounts
C/A Integrated Taillight
Pilot Power 2CT
H/M Fender Eliminator
Puig DB Dark Smoke
Brembo 15cc Reservoir
PC III
Gear Indicator
GPR Damper
Pazzo Levers
Goldeneye HIDS
vortex spools
Painted Black
Lowers
Rearsets
Engine cover
gas cap
bananamane is offline
post #7 of 52 (permalink) Old 11-07-2006, 08:54 PM
jshortsl's Avatar
I was under the impression that pair valves were only on CA bikes. Am I mistaken?
jshortsl is offline
post #8 of 52 (permalink) Old 11-07-2006, 09:04 PM
NewRedRider's Avatar
Images: 24
Yep. All of our bikes have a PAIR vavle.
NewRedRider is offline
post #9 of 52 (permalink) Old 11-07-2006, 09:39 PM
Saves on weight. A guy on here did this mod and said he can't tell any difference in terms of performance.
James06CBR is offline
post #10 of 52 (permalink) Old 11-07-2006, 09:41 PM
JSS829's Avatar
so whats the purpose of doing this? Is it just like doing an EGR block off on a car?
Two Brothers Slip on
Harris Frame Sliders
Pilot Powers
Custom FE
Ohlins .95 Fork Springs
Ohlins Fork Valves
-1/+2 w/ oem 525 chain
Shock Racing turn signals
EBC HH Sinter Pads
JSS829 is offline
post #11 of 52 (permalink) Old 11-07-2006, 10:15 PM
Images: 24
Yep. Same principle for both systems.
post #12 of 52 (permalink) Old 12-06-2006, 07:41 PM
Does anyone know how much weight?? ?
It doesn't look like much.
This seems like the performance increase is mostly theoretical based on it simply eliminating a process not strictly focused on producing forward motion. Just one of those things a racer wouldn't put back on.
Unless someone has some data showing a difference, I can't imagine doing this unless I'm in there anyway, or bored on a Sunday afternoon =P.
TheZenOfSpeed is offline
post #13 of 52 (permalink) Old 12-06-2006, 11:53 PM
Comb's Avatar
Not much... maybe a pound.
Comb is offline
post #14 of 52 (permalink) Old 02-18-2007, 11:21 AM
Hailwood's Avatar
Awesome write-up. I ditched the PAIR system yesterday, and this guide was a big help. It was fairly straightforward, but I wasted a ton of time because one of the screw heads on the air filter was stripped and I had to drill it out.
Hopefully it will stop snowing and warm up soon so I can ride the bike.
Hailwood is offline
post #15 of 52 (permalink) Old 02-18-2007, 12:04 PM
hrvat2's Avatar
Removal of PAIR valve and installation has no power gain benefits. Installation of block off plates is for one purpose: to prevent "popping" under deceleration as unspent fuel is shot out of the exhaust. The function of the PAIR valve itself is simply to aid w / emmissions by introducing air into the exhaust to burn off any unspent fuel during the combustion process.
hrvat2 is offline
post #16 of 52 (permalink) Old 02-24-2007, 04:51 PM
Evolution478's Avatar
does anoyone who has done this have an error code?
Evolution478 is offline
post #17 of 52 (permalink) Old 02-24-2007, 06:29 PM
Hailwood's Avatar
Nope, no FI codes or anything here.
Hailwood is offline
post #18 of 52 (permalink) Old 02-24-2007, 07:27 PM
Must be something else I finally got my bike back together this weekend and got it started the light is blinking twice and this was the only thing i could think of that i did that could cause it but i guess not. You did remove all of it right including the valve controller that all of the tubes went into and also the only thing that plugged into anything.
post #19 of 52 (permalink) Old 02-25-2007, 11:01 AM
Hailwood's Avatar
Yup. I removed the servo, the 3 hoses, and the plug, and capped everything off with 5/8" vaccum caps.
Hailwood is offline
post #20 of 52 (permalink) Old 07-15-2007, 12:30 PM
ever since i messed with this the error light has been on:(
bonzai600rr is offline
post #21 of 52 (permalink) Old 07-22-2007, 09:52 AM
DragOnDragger's Avatar
wouldn't having the bike remapped properly prevent the need to remove the PAIR valve? Or does it have anything to do with the mapping. Forgive the stupid Q's not much of a mechanic and know little to nothing about the werks of my 07.
2008 CBR600RR
-Jardine CF RF-1 pipe
-Proton Flushie fronts
-On frame, cut in sliders.
-04-06 Tail light conversion
00' Maxima
2010 3.5SR Altima(Wifes Wip)
2011 Dodge Ram 1500 Laramie(yes, it's got a HEMI)
"You may not be able to buy Happiness, but Happiness does have a price!"
DragOnDragger is offline
post #22 of 52 (permalink) Old 10-09-2007, 11:04 AM
kiggy74's Avatar
Feedback Score: 7 reviews
Actually, most dyno shops require blocking off the inlet from the PAIR to the airbox before doing any tests anyway. Otherwise this recirculated emission impacts the data they get from the exhaust sensors.
WERA #262
2007 CBR600RR
kiggy74 is offline
post #23 of 52 (permalink) Old 10-10-2007, 11:52 PM
What other emission related equipment can we get rid of to save weight or increase performance?
scubamike is offline
post #24 of 52 (permalink) Old 11-02-2007, 04:36 PM
good write up. i think ill take this project on when i return to the states.
jeremyolson84 is offline
post #25 of 52 (permalink) Old 12-04-2007, 01:48 AM
BalSacRR's Avatar
Alright, I cant be the only person having problems finding 5/8" vacuum caps. I live in California, after doing research i see someone found them at advanced auto (not in california) and they called them bypass plugs. Before I leave my house, can anyone let me know for sure where to find them?
BalSacRR is offline
post #26 of 52 (permalink) Old 12-06-2007, 09:49 PM
Will this cause an error light?
03 R1
05 600RR Track Bike
GTABurnout is offline
post #27 of 52 (permalink) Old 12-06-2007, 09:52 PM
tripage's Avatar
Feedback Score: 91 reviews
Try autozone or something similar. No mil light when I did this on my 04. T
tripage is offline
post #28 of 52 (permalink) Old 12-07-2007, 03:58 PM
rocketscience's Avatar
Images: 17
Another question... What do you do with the center opening after the two side openings are blocked off?
Just leave it open? Put one of those mini K&N's on there?
I'm never wrong. I once thought I was wrong, turns out, I was mistaken.
rocketscience is offline
post #29 of 52 (permalink) Old 12-08-2007, 01:05 AM
Images: 17
Anyone know?
post #30 of 52 (permalink) Old 12-08-2007, 01:04 PM
Black05rr's Avatar
Images: 53
Feedback Score: 11 reviews
You need to leave the center hose hooked up...
"Make sure to leave the crank case vent line in place. Blocking off this line will cause very bad things to happen. Leaving it open to the atmosphere will just cause a mess and dirt to get into the system. Just don't mess with it. You fucked the earth by pulling out the PAIR and SMOG systems, don't **** yourself as well by getting heavy handed with this plumbing thing."
http://www.peterverdonedesigns.com/600RRpairsmog.htm
Eric
Black05rr is offline
Human Verification
