Sorry that it it an was an incomplete post.... I had to look for the subframe trims, air duct covers, rear hugger and (the seat cowl which I'll add it in a bit)
Description:
1. Upper cowl (oem) broken right clip for duct cover ohhh also theres a warp on the right side right below the base of the mirror (see pic)
2. Left duct cover (oem)
3. Right duct covers (crack on the right duct)
4. Left mid fairing (oem) with honda emblem
5. Right mid fairing (oem) with honda emblem
6. Left lower fairing (new-aftermarker)
7. Right lower fairing (new-aftermarket)
8. Tail fairing (oem) rash but not that bad and all tabs still there.
9. Rear hugger (aftermarket)
10. Headlights with projectors. As for now I'm running halogen bulb (that I modified) in one projector only and hid on the other however the bulb sometime works and some time doesn't ....Im to lazy to search where to get an mini H1 hid but im sure its out there somewhere (ebay...or????)
For bulb replacements, lens needs to be detach from the housing bucause I modified the chrome reflector to be able to take the projectors. Headlights looks better this way instead of simple black plate to hold the projector.
The chrome reflectors was also wraped with 3M cf sticker which was a pita to install due to lines and curves on the reflector itself.
Hair line crack
Description:
Hair line crack
