Dyno Jet Quick shifter - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 20 (permalink) Old 11-02-2012, 03:49 AM Thread Starter
Just had a question how to use one of these...
Previous owner installed it on the bike.
All I know is that you don't need to use clutch to shift up.
So I do my thing, first gear -> 14,000 rpm, and then just kick up.
But the bike jerks...
Am I suppose to roll OFF the throttle then kick up then open throttle again? (for every gear?)
Or am I not shifting at the right RPM?
SHould it be smooth when shifting up with the quick shifter? (thats what I thought...)
ohdavee is offline
post #2 of 20 (permalink) Old 11-02-2012, 11:23 AM
I would NOT run it to 14k in 1st and then shift.
I would call DJ and ask them some questions........
or visit their website at least.
tary preisser is offline
post #3 of 20 (permalink) Old 11-02-2012, 11:27 AM
Tyleronanrr's Avatar
Images: 2
Quick shifters are not meant for shifting from 1st to 2nd. Only use it after 2nd.
Tyleronanrr is offline
post #4 of 20 (permalink) Old 11-03-2012, 04:35 AM Thread Starter
I'll give DJ a call... lol
ohdavee is offline
post #5 of 20 (permalink) Old 11-03-2012, 04:51 AM
^^^ this
Just the same as when you clutchless upshift without a quick shifter you're not supposed to do it from 1st to 2nd, doesn't work with slamming through neutral.
- 2004 CBR1000rr - Sold
- 2008 CBR600rr - In action
->Spiegler SS Brake Lines
->Renthal grips
->China gold levers
->Brake Res. Delete
->Leo Vince SBK Slip on
->OES frame sliders
->HotBodies flush mounts
->CBR Heaven fender eliminator
->BKmoto 35w HID 6000k
havok289 is offline
post #6 of 20 (permalink) Old 11-03-2012, 03:04 PM
CK_32's Avatar
Quick shifters or not 1 to 2 is a big gap.. I always use the clutch from those 2 then clutch less from there
I'm on stock shifting tho just clutch less shift.
My YouTube channel.
CK_32 is offline
post #7 of 20 (permalink) Old 11-03-2012, 04:02 PM
BOTM Winner 07/14
tornado bait's Avatar
Images: 17
Feedback Score: 12 reviews
Actually, 1st to 2nd gear is no different than any other gear change with respect to how shift forks, detent roller and star assembly operate or distance between them. QS should work same as well. If not then there is likely a set-up issue.
Sent from my HTC One V using Motorcycle.com Free App
Vortex, Tucker Rocky, Speed & Strength, BikeMaster, E4S
Cafe Racer Inc.
Tornado Bait Racing
tornado bait is offline
post #8 of 20 (permalink) Old 11-03-2012, 04:20 PM
BOTM Winner 07/14
Images: 17
In case someone has a hard time believing my previous post here is a pic from a 2005. Notice the 6 star points (one with notch) and 6 valleys. The star point with the notch is neutral. Other than the notch for neutral the shift star is symetrical and degrees of rotation for shifting between gears is the same.
Cafe Racer Inc.
Tornado Bait Racing
post #9 of 20 (permalink) Old 11-03-2012, 06:42 PM
CK_32's Avatar
Same size or not that clunk is not good.. Any metals or parts/joints hitting that hard will wear faster than not.. Rather play it safe than sorry.. Its just one gear...
And if your so set on not having to clutch it from 1 to 2... get one of these and be done.
My YouTube channel.
CK_32 is offline
post #10 of 20 (permalink) Old 11-04-2012, 10:05 AM
BOTM Winner 07/14
Images: 17
OP has a QS.
Cafe Racer Inc.
Tornado Bait Racing
post #11 of 20 (permalink) Old 11-04-2012, 10:16 AM
**Miss O'Seven BOTY 2011**
Moeman's Avatar
Images: 646
Feedback Score: 148 reviews
The speed shifter on the 675R is awesome it would be a great addition to any bike
Honrary Chairman
Deafet may serve as well as victory to shake the soul & let the glory out
A great deal of intelligence can be invested in ignorance when the need for illusion is deep
Moeman is offline
post #12 of 20 (permalink) Old 11-04-2012, 12:51 PM
Raj24v's Avatar
No help to the OP but that 675R sounds sooooo sexy!!!
Raj24v is offline
The Following User Says Thank You to Raj24v For This Useful Post:
Moeman (11-04-2012)
post #13 of 20 (permalink) Old 11-20-2012, 06:20 PM
bypr0duct's Avatar
If you want to use the quick shifter from 1st to 2nd and reduce the clunk my suggestion is to wire the PC into the speed sensor and calibrate gear position. This will allow you to set individual kill times per ger (ie longer kills for the lower gears). Once you have it all setup properly the shifts will be silky smooth through the whole box, although there will always be a bit of a jolt from 1st to 2nd under hard accleration simply because of the high torque forces at work. This is assuming you have a PC V I'm not sure if its possible on a PC III.
From memory my race bike has a kill time of 75ms for 1st to 2nd & I can flat shift it out of the 1st gear hairpin at about 11k no problem. No point redlining it in 1st then it does get a bit rough on the shift. If its a street bike and you mainly shift at lower RPMs then you may need an even longer kill time.
bypr0duct is offline
post #14 of 20 (permalink) Old 11-20-2012, 06:26 PM
MiniG0D's Avatar
you SHOULD just be able to barely click up on the shifter and it cuts fuel and slides right into gear with almost no effort... that's IF it was installed properly...
if that is not the case connect your PC5 to a computer and in the menu there are settings... it may not be enabled or you may have the switch type (NO/NC set inverted)... the 600RR SHOULD be a Normally Open (NO) switch... also there is a setting I forgot what its called for it to have different settings for each gear or one setting for all gears... you have to have speed sensor wires connected to your PC5 for the independent settings for each gear option to work... so if you are unsure if thats connected then just change that setting to one setting for all gears and it will work regardless...
If none of the above is true they may have only installed a shift sensor without the "quickshifter expansion module" which allows the PC5 to temporarily cut all the injectors off so you can shift...
Heres what the QEM module is:
http://www.powercommander.com/powerc...on_module.aspx
And as far as the speed sensor if you look on your PC5.. there are a series of holes... two of those holes should be filled with wires from the SFM module (the 3rd and 4th over from the left if you have the label facing up and are looking from the back) and the 3rd one over from the right is the hole that a speed sensor wire would be connected to (again its optional but it is required to have the independent settings for each gear setting enabled)...
Also you MUST have the latest firmware (not maps but the actual PC5 software) and QEM software for it to work right.. they are both available on the powercommander site and can be updated while you are plugging the PC5 into your computer to check the settings...
The only other thing you can double check... on the sensor mounted on your shift rod... there are 2 types of sensors... push or pull... its marked in small print on the label... I believe the 600RR stock uses a push type sensor (you can verify this by seeing which way the rod moves during an UPSHIFT... if the rod is being pushed you need a push type sensor... if its being pulled a pull type (I'm pretty sure the 600RR uses a push type unless you have some type of rearset or something that changed the direction the rod travels (but again you can easily check by doing what I just said)...
Anything else feel free to post back or message me...
MiniG0D is offline
The Following User Says Thank You to MiniG0D For This Useful Post:
tary preisser (11-20-2012)
post #15 of 20 (permalink) Old 11-20-2012, 06:49 PM
jamiedaugherty's Avatar
I never use the clutch on any of my bikes when doing the 1-2 shift. It's never been a problem. Not sure why the Quickshifter would care, I thought it cut the ignition no matter what the gear the bike is in.
jamiedaugherty is offline
post #16 of 20 (permalink) Old 11-20-2012, 06:52 PM
MiniG0D's Avatar
it will cut it regardless of gear... I have no idea about the long term effects on the shift star or any of the shift/clutch mechanism but it will allow you to shift between 1st and 2nd as well as 2nd-5th equally... that may be a good use for the gear specific settings and setting the 1st to 2nd shift with a longer kill time but it hasn't been an issue
MiniG0D is offline
post #17 of 20 (permalink) Old 11-20-2012, 08:25 PM
yah anytime ive done clutchless shift between 1st and 2nd its rough unless it was high rpms
jmarquez808 is offline
post #18 of 20 (permalink) Old 11-21-2012, 11:36 AM
I've found that when shifting 1-2 (clutchless) I need to get the RPMs up to about 8-9k for a smooth shift, everything is else around 6-7k. But I always use clutch from 1-2 just because I won't find myself needing to rev that high when I'm just commuting to work.
S1NFUL PC40 is offline
post #19 of 20 (permalink) Old 11-21-2012, 01:21 PM
fallingbomb's Avatar
The duration which the ignition (or fuel) needs to be cut is slightly longer since there is a larger difference in the gear ratios than when shifting between any other gears.
2007 CBR600RR -- CVMA #270 -- Pictures -- Build Thread
fallingbomb is offline
post #20 of 20 (permalink) Old 11-22-2012, 01:34 AM
hxccalinip's Avatar
Look at how siick this shitter is!!
hxccalinip is offline
Human Verification
