Vibration Noise??? - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 24 (permalink) Old 11-28-2012, 01:55 AM Thread Starter
Vibration Noise???
I have approx 55k on my 2007 600RR and when I down shift at certain RPM's I am getting a vibration noise, almost like plastic fairing or something. I checked all fasteners and they all tight. I was thinking it might be something inside the exhaust? my roomates bike is sort of doing the same thing. Anyone else hear this vibration noise on their bike? Thanks.
hrcrider is offline
post #2 of 24 (permalink) Old 11-28-2012, 02:12 AM
CK_32's Avatar
Video..?
Probably help a ton hearing and seeing where its coming from.
My YouTube channel.
CK_32 is offline
post #3 of 24 (permalink) Old 11-28-2012, 02:14 AM
chain ...?
tary preisser is offline
post #4 of 24 (permalink) Old 11-28-2012, 02:17 AM
I'm a pretty lady!!!
weStTXgrEase_mOnKay's Avatar
Feedback Score: 14 reviews
Turtles??????
2012 Suzuki GSX-R1000
2W1R elCapitan
Alexander the Great
Happy Catholic
weStTXgrEase_mOnKay is offline
post #5 of 24 (permalink) Old 11-28-2012, 02:24 AM
Dynamic's Avatar
Next time it happens put your hand on the gas tank and push down a bit, just around the gas cap. I hear a slight vibrating noise on mine once in a while and I noticed that's where it's coming from.
Dynamic is offline
post #6 of 24 (permalink) Old 11-28-2012, 03:08 AM
Op joined in 03 he's a triple og!!! Go op!!!!
2W1R elCapitan
Alexander the Great
Happy Catholic
post #7 of 24 (permalink) Old 12-01-2012, 07:32 PM
CK_32's Avatar
I was thinking about this the other day at work.. And do you have anything in your compartment..? I'm assuming its probably a tool or something bouncing around in your passenger seat. Could be mistaken for the exhaust being in the same area.
My YouTube channel.
CK_32 is offline
post #8 of 24 (permalink) Old 12-02-2012, 06:25 PM Thread Starter
No noise from the gas tank and nothing in my compartment.
hrcrider is offline
post #9 of 24 (permalink) Old 12-03-2012, 05:28 PM
Do you have stands? maybe put the bike on the stands and test around to see if a friend can find the vibration noise
DAMNitzHENRY is offline
post #10 of 24 (permalink) Old 12-03-2012, 08:46 PM
Sdbir11's Avatar
I'm thinking that you need to get the slack out of your chain.
Sdbir11 is offline
post #11 of 24 (permalink) Old 12-03-2012, 09:09 PM
i have the same problem but it sounds like it is coming from my gauge cluster area
nuclear0240 is offline
post #12 of 24 (permalink) Old 12-03-2012, 10:45 PM
ChrisR.Conley's Avatar
I have this as well, mostly before the bike has had time to heat soak. If it ain't broke, don't fix it. It's annoying, but I'm not going to tear the bike apart looking for it.
ChrisR.Conley is offline
post #13 of 24 (permalink) Old 12-04-2012, 12:20 AM
boostedlt1's Avatar
my windscreen had a bad vibration noise, check those bolts maybe?
Adam - Slocum Racing
'95 lt1. 355 - 9.4:1 - LE2 heads - LE cam - t70 @ 8psi (until i get moar fuel)
'03 CBR600RR - Two Brothers Slip-On
boostedlt1 is offline
post #14 of 24 (permalink) Old 12-04-2012, 12:59 AM
CK_32's Avatar
Dang my bikes been through a crash and I have none of these issues this bread has made me a little great up haha
My YouTube channel.
CK_32 is offline
post #15 of 24 (permalink) Old 12-04-2012, 01:15 AM
SilentSun's Avatar
Ooo, it's unlikely to be this, however when I was installing my radiator guard I noticed that the top mounting bolt was very lose, to the point of nearly coming off. Once I installed and tightened it though I noticed a big improvement in the lack of vibrations coming from the front of my bike.
Perhaps check that? Otherwise I'm going to bet chain.
600rr 11
SilentSun is offline
post #16 of 24 (permalink) Old 12-04-2012, 04:17 AM Thread Starter
The chain is ok, I check it and lube it all the time. Its really weird, it won't do it on the stand just sitting in my garage reving it. It only does it when I'm riding and I am down shifting from a high rpm, then between 6-8 rpm it sounds like all my fairing up front are vibrating and then goes away once rpm is low.
hrcrider is offline
post #17 of 24 (permalink) Old 12-04-2012, 06:46 AM Thread Starter
Actually I really focused on it tonight on the way home from work, it actually makes the noise between 4 and 5 thousand RPM, and I can hear it rattle while just sitting and reving it. I strongly think it is something in the exhast pipe itself, I have a spare back half so I will throw that on and see what happens. Just wondering after a certain amount of miles the baffles inside or whatever gets loose and will rattle, because the more I think of the noise it sounds like a metal rattle or fast vibration of metal.
hrcrider is offline
post #18 of 24 (permalink) Old 12-04-2012, 08:25 AM
Try checking between third eye and wind screen.
bought my 07 600rr on 11/4/11. rode it once before riding season was over, best time of my life.
drumstick93 is offline
post #19 of 24 (permalink) Old 02-12-2013, 02:18 AM Thread Starter
Ok fellas found out what it was, as it was getting worse it was easier to locate. It was the cam chain tentioner. Cannot adjust the stock one, so installed an adjustable one and the noise went away. Starts getting loose again, I will just adjust it. Makes the bike feel new again. Hope this helps anyone in the future. Bike started doing it at about 40,ooo miles or so.
hrcrider is offline
post #20 of 24 (permalink) Old 02-12-2013, 03:49 AM
BOTM Winner 1/13
Nuttynu's Avatar
Haha duh! Why didn't we think of that. Yes the infamous CCT crying after 30k plus.
Did you get a APE or got a new stock one ?
My Ride Report :
-Alaska,The Last Frontier
Nuttynu is offline
post #21 of 24 (permalink) Old 02-12-2013, 05:54 AM Thread Starter
I got the aftermarket APE..
hrcrider is offline
post #22 of 24 (permalink) Old 04-20-2013, 11:48 AM
I have the same problem ... what else changed when you changed the CCT...??? any thing in performance???
and also was there in the past a light vibration on your handlebar grips and after changing the CCT the light vib. gone???
kiro is offline
post #23 of 24 (permalink) Old 04-20-2013, 08:11 PM
i also have the same exact problem on my bike 40k miles on it, 2007, im too lazy to fux with it, putting it in a shop hope for the best
elul21 is offline
post #24 of 24 (permalink) Old 04-20-2013, 09:17 PM
JackDaWack's Avatar
My windscreen was driving me crazy, when i would grab it it would stop.. One of the rubber grommets either pulled through or i wasn't paying attention when i put it back together. Something will always vibrate on a bike at a particular RPM, just when its in your face at cruising rpm it's a PITA. I have a feeling the front brake line vibrates a lot, and there is very little you can do about it.
Mods
2-Bro's Slip on
SS FE kit
Proton Flush Mounts
OES sliders and spools
Amsoil Full SYN
BKmoto Projector kit
JackDaWack is offline
Human Verification
