setting high idle speed - why not? - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 22 (permalink) Old 07-07-2006, 01:39 AM Thread Starter
First of all, hello to everyone as this is my first post, though I've been reading for a couple of months.
I read in one of Keith Code's books that he would sometimes suggest racers to set their idle speed very high (4K rpm IIRC) to avoid engine braking. This got me thinking, why not use this on the street too? The way I see it you have several benefits:
1. Throttle action should be less sensitive, especially in 1st gear (this was also mentioned in one of the threads yesterday).
2. You don't use engine braking (not sure if this is good, but Keith Code seems to think so).
3. If you get scared mid-corner and chop the throttle off, it won't be as bad.
4. In stop-go traffic, you don't really need to give any gas, you just ease the clutch out.
5. You can't stall the engine.
Having said all this, I have very little experience with bikes, so I might very well be very wrong in the above. But if not, why don't we just increase our idle speeds (other than due to increased fuel consumption)? It must be obvious, but I can't see it.
Philip
boxas2003 is offline
post #2 of 22 (permalink) Old 07-07-2006, 01:48 AM
AF_Brad's Avatar
Images: 8
I would feel stupid at a stop light with the engine turning 4k. That's just me though.
http://www.myspace.com/af_brad
2006 600RR, all black, mostly stock.
$5 DIY fender eliminator
DIY shorty levers
LP aero LEDs
Powder coated covers
Powder coated tripage LED pegs
CA taillight
Painted windscreen
Rim tape
etc, etc
Best of all....IT'S MINE!!
AF_Brad is offline
post #3 of 22 (permalink) Old 07-07-2006, 02:03 AM Thread Starter
Well you don't have to put at it at 4K. That was just the number in the book for racing. How about 2K?
Philip
post #4 of 22 (permalink) Old 07-07-2006, 02:09 AM
lowlife's Avatar
Philip
1) throttle sensitvity will not change, the bike will continue to accel slightly even with the throttle relased, not a good thing on the street...
2) engine braking is good at street speeds...
3) it will be worse since you will chop off the throttle and the bike will still accelerate, causing you to be more scared and panically grab at the brakes...
4) In stop and go traffic you will over heat....
5) youcould stillstall the engine.....
In all of your sujestions above, basic riding skills will work 100% better than upping you idle speed, it works on the track because of the higher corner speeds and much more aggresive riding.....and you will look stupid with your idle up that high on the street....
lowlife is offline
post #5 of 22 (permalink) Old 07-07-2006, 02:37 AM
davedog665's Avatar
wish i could turn my idle up that high with out all the work too do sooo but thats for stuntin
http://www.myspace.com/bentoutofcontrol
WtB Pm me!
tsx projectors/stunt cage
Dave
davedog665 is offline
post #6 of 22 (permalink) Old 07-07-2006, 03:05 AM
Super Mod Wanna-be
TOMIMOTO's Avatar
uhhh....... all you have to do to turn the idle up is turn the little idle dial thingy. I wouldn't recomend it though.
New England AWD - www.neawd.com~
TOMIMOTO is offline
post #7 of 22 (permalink) Old 07-07-2006, 11:01 AM
APEX_600RR's Avatar
Thats not an actual idle adjustment screw, its an air screw. It richens up or leans out your mix which makes the idle move around but you cant get it any higher than about 2400RPM. Another stock 600RR, 900RR, etc air screw must be installed on the throttle bodies replacing the throttle butterfly stop to have a true idle adjustment. Trust me, us stunt nerds know far too much about the idle adjust mod: Stunt How-to's: Idle Adjuster, BAS jumper, Fan switch Mods
APEX_600RR is offline
post #8 of 22 (permalink) Old 07-07-2006, 02:51 PM Thread Starter
1a. I believe throttle sensitivity will be better in the sense that when you turn the throttle completely off you don't get jerked as forward due to as severe engine braking.
1b. I don't see how that's a bad thing. I would think of it as having an automatic car versus a manual car, in the sense that you're always slightly accelerating. This could even help with incline starts a lot.
2. I don't see why, and I've read quite different opinions about this, but if you know why, I'd like to hear it. I think I read somewhere, use the engine to accelerate and the breaks to decelerate, and it makes a lot of sense to me. You even avoid the danger of using engine braking, hence not lighting up your brake light, hence having someone rear-end you.
3. It won't be worse because chopping off the throttle is much more of an instinct reaction than applying the brakes. Also you will sense the deceleration and probably won't feel the need for more. But this is purely hypothetical, so I don't know who is right.
4. This is a good point.
5. I don't see how. Again, it's like having an automatic car. The engine never stalls there.
Philip
post #9 of 22 (permalink) Old 07-07-2006, 03:01 PM
NewRedRider's Avatar
Images: 24
Philip, I have to agree with lowlife and the concensus here. This is a bad idea and a recipe for disaster. Your concerns can be resolved with riding skills. Engine braking is your friend. Drag your front brake lever when you're engine braking so your light flashs at the driver behind you. You should be covering the brake levers anyway when you're braking, whether it be with the engine or the brakes. You better not rely on a brake light to prevent the cager behind you from running you over. You better be watching them and have a plan of escape just in case.
NewRedRider is offline
post #10 of 22 (permalink) Old 07-07-2006, 03:31 PM
Ducati Champion Del Mondo
Visitor Q's Avatar
Images: 158
Feedback Score: 6 reviews
Yeah... I don't really feel the need to travel down that road. Just learn how to handle the bike better.
Jason
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Visitor Q is offline
post #11 of 22 (permalink) Old 07-07-2006, 04:15 PM
troy45's Avatar
Be careful turning the idle adjuster up as far as it will go - my cable has an annoying habit of jamming in that position and needs mole grips on the end of the cable at the throttle bodies to free it off again if you want to lower the idle speed again. And as already mentioned it only takes idle up to around 2500 rpm anyhow.
troy45 is offline
post #12 of 22 (permalink) Old 07-07-2006, 04:15 PM
RandomStrata's Avatar
Images: 26
Pretty sure the book was referring to the track and not the street, but that's just how I see it. He might be referring to street racers, who knows.
ya I'm an ass.
RandomStrata is offline
post #13 of 22 (permalink) Old 07-07-2006, 04:26 PM
davedog665's Avatar
cool man thanxs for lettin him know whats up! im not where i need to b yet to need 3 or 4k idle but it would b nice to not have to do all the work but i hear that it looks worse then it is?
WtB Pm me!
Dave
post #14 of 22 (permalink) Old 07-07-2006, 05:02 PM
Ichiro's Avatar
Mostly it seems like a waste of gas to me...
05 RR Slv/Blk
Super perfundo on the early eve of your day
Ichiro is offline
post #15 of 22 (permalink) Old 07-07-2006, 06:26 PM
She was Holding The Magnifying Glass
BOBO's Avatar
Feedback Score: 10 reviews
I'd so no to street riding, I run mine around 2k at track and seems to work good,but I also have a slipper clutch.
Getting old is NOT for pussies!
If I were 4 foot tall I'd have a BIG D
BOBO is offline
post #16 of 22 (permalink) Old 07-07-2006, 08:37 PM Thread Starter
Ok guys, thanks for the replies. It seems you all agree, so I'll take your advice.
Philip
post #17 of 22 (permalink) Old 07-08-2006, 03:18 AM
lowlife's Avatar
smart man....
lowlife is offline
post #18 of 22 (permalink) Old 11-14-2010, 01:03 AM
Mistahtaki's Avatar
1.) waste of gas
2.) more wear on the clutch
3.) noisy
4.) have to hold clutch more
5.) too many cons to list
Mistahtaki is offline
post #19 of 22 (permalink) Old 11-14-2010, 01:05 AM
Mistahtaki's Avatar
thread revival
post #20 of 22 (permalink) Old 11-14-2010, 04:25 AM
Nico's Avatar
Originally Posted by Mistahtaki View Post
thread revival
How the hell did you find this?
Nico is offline
post #21 of 22 (permalink) Old 11-17-2010, 02:20 AM
Mistahtaki's Avatar
truth is......i just dont know.
post #22 of 22 (permalink) Old 11-17-2010, 02:40 AM
Nico's Avatar
Fair enough...
Nico is offline
Closed Thread
Human Verification
