Parting Out a 07-12 CBR 600RR
All prices are PLUS Shipping
Everything Must Go!
Sold AS IS
Rear Wheel (Phoenix Edition) - $250
Rear Brake Rotor - $50
Fuel Tank - $100
Fuel Pump - $100
OEM Fuel Cap – Black - SOLD
OEM Fuel Cap - $25
Radiator - $150
Fan - $50
Ram Air - $150
Gauge - $300
Gauge Harness - $50
Gauge Mount/Stay - $50
Air Box w/ Stacks - $50
Secondary Injectors - $50
ECU - $250
Kickstand w/ Switch - $50
Radiator Reservoir - $15
Left Headlight - $100
Rear Brake Mount - $25
Front Sprocket 16T - $15
Blue Pegs - $20
Front Forks w/ Triple Trees - $500
Right Clip On - $50
Left Clip On - SOLD
Switches - $50
Blue Vortex Levers - $50
Clutch Perch - $25
Front Wheel (Phoenix Edition) - $250
Front Rotors - $150
Horn - $25
Passenger Rearsets - SOLD
Blue Passenger Pegs - $20
Steering Stabilizer - $100
Front Seat - SOLD
Rear Brake Caliper - $50
Rear Brake Master Cylinder - $50
Front Brake Calipers - $100
Front Brake Master Cylinder - $100
OEM Tire Hugger - $15
Air Box Boot - $25
Voltage Regulator - $150
Phoenix Edition Fairings - L $150 R $50
Phoenix Edition Fuel Tank Cover - $150
Phoenix Edition Tail - $50
Phoenix Edition Front Cowl - $50
Third Eye - $50
Subframe -$200
Swingarm - $150
Rear Shock - $250
Rear Suspension Links - $50
Wiring Harness - $250
OEM Header - $50
OEM Muffler - $50
OEM Heat Shield - SOLD
Throttle Body - $250
Injectors - $100
OEM Levers - $25
OEM Filter - $25
OEM Rear Sprocket - $25
OEM Front Sprocket - $25
OEM Chain - $50
OEM Tail Light w/ Turn Signals & Plate Mount - $50
OEM Turn Signals - $25
OEM Mirror Mounting Brackets - $25
Everything Must Go!
Sold AS IS
Fuel Tank - $100
Fuel Pump - $100
OEM Fuel Cap - $25
Radiator - $150
Fan - $50
Ram Air - $150
Gauge - $300
Gauge Harness - $50
ECU - $250
Blue Pegs - $20
Right Clip On - $50
Left Clip On - SOLD
Switches - $50
Clutch Perch - $25
Front Rotors - $150
Horn - $25
Front Seat - SOLD
Air Box Boot - $25
Third Eye - $50
Subframe -$200
Swingarm - $150
Rear Shock - $250
OEM Header - $50
OEM Muffler - $50
Injectors - $100
OEM Levers - $25
OEM Filter - $25
OEM Chain - $50
