The real deal - Brembo full floating HP series rotors for Honda 600RR and some models 1000RR. Will fit any year 600RR, will fit 2004-2005 1000RR, and will fit 2007-2007 1000RR if the 5mm caliper spacers are not used. 310mm diameter, 5.5mm thickness. In good condition, carrier buttons are in spec, rotor surface should be cleaned prior to use.
$370 shipped ground to CONUS.
