2004 - Does parts from 03 to 06 fit? - 600RR.net
03-06 RR Modifications 2003, 2004, 2005 and 2006 Modifications
post #1 of 18 (permalink) Old 07-16-2009, 08:28 AM Thread Starter
Catherine4483's Avatar
I just bought a wrecked 04 and i need to get the fairings, headlight, tack, and some other random parts. So will the 03 to 06 parts work?
Thanks
Catherine4483 is offline
post #2 of 18 (permalink) Old 07-16-2009, 08:31 AM Thread Starter
Here are the pic's :)
post #3 of 18 (permalink) Old 07-16-2009, 10:21 AM
l0weed's Avatar
I believe the gas tank cover, front fender, tail section need to be 03 to fit the frame. Computer bits are engine year specific as well. Headlight needs to be same year as upper, as does windscreen. I "think" that's about it. At least off the top of my head.
*edit* I have a complete 03/04 oem body that needs some minor cosmetic work...headlight too some place. Pm me if your interested. I'll go take some pics and we haggle a bit. :-)
~Loyd
Power corrupts.
Knowledge is power.
Study hard, be evil.
self-wife= bikes in near future again.
l0weed is offline
post #4 of 18 (permalink) Old 07-16-2009, 10:46 AM
some parts do fit and others dont. There are a lot of differences in the 04 and 05 bikes.
rallyegolf is offline
post #5 of 18 (permalink) Old 07-16-2009, 11:45 AM
krisboro's Avatar
Front upper, mids, lowers, and gas tank cover will all fit without any modification. Headlight is identical 03 thru 06.
Only thing that won't bolt up without extra parts is thefront fender and rear cowl. If you wanted to use and 05-06 rear cowl, you would also need the rear subframe and battery tray, along with black plastic side covers. Exhausts are also only interchangeable with different subframe, due to mount points.
Switch gear is interchangeable. Gear shifters, brake and clutch levers and front master cylinder, rims, rearsets and other bolt on parts are mostly interchangeable. Suspension parts are different, but also swappable with extra parts (complete front end with triples) Tach is same 03-06.
Clip ons 03-04 are different to 05-06 (different bore size)
krisboro is offline
post #6 of 18 (permalink) Old 07-16-2009, 12:37 PM
yoshiharu's Avatar
Feedback Score: 9 reviews
Upper cowls are different from 03-04 to 05-06. They will both bolt up to the mirror brackets and mids, but the ram air tubes are different, as are the windscreens.
As stated above, the entire tail section is specific to 03-04 or 05-06, including front seat. So mids, lowers, tank, and lights are 03-06. To make it simple, all the rest of your bodywork should be sourced specifically for 03-04.
2006 600RR. STOLEN, RIP. Arata slip. PC III. BMC. GPR. Driven D3. ASV C/5. Sato rearsets. ZG dbubble. Galfer SS lines.
yoshiharu is offline
post #7 of 18 (permalink) Old 07-16-2009, 11:38 PM Thread Starter
PM Sent!
post #8 of 18 (permalink) Old 07-16-2009, 11:46 PM
http://fiche.ronayers.com/Index.cfm/...9/Group/CLUTCH
Ronayers.com parts fiche....may be able to cross reference the part numbers...I saw someone did that to figure out the year of their plastics in another post and i have it permanently bookmarked now!!
isotope is offline
post #9 of 18 (permalink) Old 08-18-2009, 11:51 AM
Furyous's Avatar
I have a question...
I purchased an '03-04 upper cowl for my '05-06 (found a good deal and mine is trashed from an accident).
From what I'm reading and what yoshiharu said, it sounds like I can bolt it up just fine. Can anyone confirm this? Also from what yoshi said, will I need a new windscreen? I can't use my OEM 05-06?
Thanks in advance!
'05 CBR600RR- 15k RPMs of fun
'08 Apex Blue Pearl S2000 CR (#543 of 699)
'06 STi / '05 RSX-S / '05 S2000 / '03 Si - Gone but not forgotten
Furyous is offline
post #10 of 18 (permalink) Old 08-18-2009, 08:20 PM
yoshiharu's Avatar
Thanks in advance!
The upper will bolt to the mids fine (3 bolts on each side). 05-06 windscreen is different. I've never actually matched them up, but the 03-04 screen comes down further and meets the third eye...05-06 has about an inch of plastic fairing between the screen and the third eye (not to mention different part #s). Ram air tubes are different also, and 03-04 has those little ram air pieces that mount below the headlights.
post #11 of 18 (permalink) Old 08-18-2009, 10:33 PM Thread Starter
Thanks in advance!
Right now i have a 05 red upper on my 04 and it fit fine. The windscreen had to be swapped but looks ok.
post #12 of 18 (permalink) Old 06-19-2012, 06:49 PM
Everyone is talking about full fairing swaps. Will an 05 Lower fit up to my 03 mid? Thanks
oh and are the Blacks the same blacks for those different years?
acidwarped is offline
post #13 of 18 (permalink) Old 06-19-2012, 10:47 PM
krisboro's Avatar
Yes it will.
krisboro is offline
post #14 of 18 (permalink) Old 06-20-2012, 07:34 AM
krisboro's Avatar
And yes, the paint is the same color on the black 03-06
Honda paint code NH1.
You can check for yourself here: http://www.servicehonda.com/hard%20p...20cbr600rr.pdf
krisboro is offline
post #15 of 18 (permalink) Old 06-20-2012, 10:39 AM
Thank you. Getting parts tonight.!
post #16 of 18 (permalink) Old 11-16-2012, 03:12 PM
I guess you guys are right, I had no problem doing a facelift on my 04 rr with 06 rr parts!!!
Dmann1 is offline
post #17 of 18 (permalink) Old 11-17-2012, 12:53 PM
krisboro's Avatar
Great. Got pics?
krisboro is offline
post #18 of 18 (permalink) Old 11-17-2012, 03:38 PM
agreed, dmann can you elorbrate?
bejbis is offline
Human Verification
