Need a solution for BREMBO RCS clearance... - 600RR.net
03-06 RR Modifications 2003, 2004, 2005 and 2006 Modifications
post #1 of 26 (permalink) Old 11-14-2012, 01:04 PM Thread Starter
Mina's Avatar
Exclamation Need a solution for BREMBO RCS clearance...
I just installed a Brembo RCS on the stock clip-ons.
As I'm sure, most of you already know about the adjuster hitting the dash when the bars are turned all the way to the left.
If I were to get a set of Woodcraft 48mm clip-on with no rise, will this fix the issue?
Mina is offline
post #2 of 26 (permalink) Old 11-14-2012, 07:41 PM Thread Starter
Mina's Avatar
Anybody?
I'd rather not butcher my dash with a dremel...
Mina is offline
post #3 of 26 (permalink) Old 11-14-2012, 07:44 PM
*BOTM Feb '11, Mar '12*
sincalirider's Avatar
Feedback Score: 27 reviews
From what I remember, some people were going with an RC51 or an 07+ 600RR ignition starter to give them more room on the bar.
sincalirider is offline
post #4 of 26 (permalink) Old 11-14-2012, 08:04 PM
FlipDiver79's Avatar
Images: 3
Feedback Score: 12 reviews
some guys that run the rcs with the stock setup just dont go lock to lock, that just means that 3 point turn becomes like 5 or 6. Thats what i did before my bike had track glass.
Originally Posted by Knightslugger View Post
Flip Diver's gotta be a bot!
Originally Posted by phatstud View Post
flip posts bewbies everywhere!
Originally Posted by djacksoncbr600 View Post
No flipdiver posts newbies everywhere.
FlipDiver79 is offline
post #5 of 26 (permalink) Old 11-14-2012, 08:11 PM Thread Starter
Mina's Avatar
^ Bike is strictly for track, so I'm not concerned about rubbing on the fairings...
I don't want to break the adjuster if I turn the bars too hard.
Mina is offline
post #6 of 26 (permalink) Old 11-14-2012, 08:14 PM
Images: 3
well in that case you wont go full lock anyway so either change to aftermarket clipons or dont worry about it ImO...
post #7 of 26 (permalink) Old 11-14-2012, 08:40 PM
mountainRRing's Avatar
My rcs is on stock bars and I can turn to full lock both ways without rubbing..
mountainRRing is offline
post #8 of 26 (permalink) Old 11-14-2012, 11:41 PM
Azn-Sensation's Avatar
Feedback Score: 34 reviews
Yeah true on not needing to go lock to lock on a track bike, however what I did was add well weights to the limiters so I wouldn't damage anything while going lock to lock.
Azn-Sensation is offline
post #9 of 26 (permalink) Old 11-15-2012, 12:24 AM Thread Starter
Mina's Avatar
Mind posting a picture?
Mina is offline
post #10 of 26 (permalink) Old 11-15-2012, 12:25 AM Thread Starter
Mina's Avatar
Can you expand on that a little? I can't really picture your set up.
Mina is offline
post #11 of 26 (permalink) Old 11-15-2012, 09:08 AM
I'll try and get a pic after work. All I did was buy a ladybird bracket to hold the brake fluid resivour out of the way. The rcs never hit my fairings just the resivour
post #12 of 26 (permalink) Old 11-15-2012, 09:45 AM Thread Starter
Mina's Avatar
I bought a ladybird bracket, already.
Here are a couple of pictures to show you what I mean.
Mina is offline
post #13 of 26 (permalink) Old 11-15-2012, 08:33 PM
Ah just realized you have an 06 . Mine is 07 that's why I have room..
post #14 of 26 (permalink) Old 11-15-2012, 08:56 PM Thread Starter
Mina's Avatar
lol... you got my hopes up man!!!
Mina is offline
post #15 of 26 (permalink) Old 11-15-2012, 11:52 PM
I currently dont have access to my bikes at the moment. But I stuck wheel weights on the frame where the forks meet at full lock to limit its travel.
post #16 of 26 (permalink) Old 11-16-2012, 12:04 AM
So...... I'm guessing you didn't want to go this route?
From Zack600's build thread
Zack600 Build *UPDATE* Ohlins ,Galfer
Edit: Just noticed he was running a/f clip-ons too. lol I know somebody else did the ignition switch for sure though to remedy the clearance.
post #17 of 26 (permalink) Old 11-16-2012, 08:24 AM Thread Starter
Mina's Avatar
^ so would aftermarket clipons be the way to go?
Mina is offline
post #18 of 26 (permalink) Old 11-16-2012, 09:07 AM
post #19 of 26 (permalink) Old 11-16-2012, 09:25 AM Thread Starter
Mina's Avatar
What about the throttle housing and the cables?
Is it a direct bolt on or do I need to purchase the throttle housing separately?
Mina is offline
post #20 of 26 (permalink) Old 11-16-2012, 09:54 AM
I have an 07 and the rcs19, what I did was move the starter and ignition to the inside of the handle bar. Worked for me.
DynastySS is offline
post #21 of 26 (permalink) Old 11-27-2012, 07:50 AM
OveRReV's Avatar
Images: 16
that would work but i want the switch to be within reach of my thumb if something unexpected happens like the throttle getting stuck or worse.
even with clip-on bars the damn knob still hits, it's impossible to put a remote adjuster on the RCS with our setup.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #22 of 26 (permalink) Old 11-27-2012, 03:54 PM
Just add a bolt to your stopper so the bike wont have as much lock to lock.
Rick
rick_b is offline
post #23 of 26 (permalink) Old 11-27-2012, 06:49 PM
White RepsoL's Avatar
I have brembo MC with woodcraft 1.5" rise with slight issue at full lock to the left, but had the no rise before with no issues. Riding position is the reason I went to risers. I bet 1" risers would be tits...
Another option is get tape weight's like used to balance wheels and use them as stoppers.
White RepsoL is offline
The Following 2 Users Say Thank You to White RepsoL For This Useful Post:
Mina (12-12-2012), OveRReV (11-27-2012)
post #24 of 26 (permalink) Old 11-27-2012, 06:55 PM
Here's some pics...
ID:	31014   Click image for larger version
ID:	31015   Click image for larger version
post #25 of 26 (permalink) Old 12-12-2012, 10:01 AM Thread Starter
Mina's Avatar
Thanks!
I ordered a standard set of Woodcraft 48mm clip ons and the Brembo RCS adjuster no longer hits the dash. BUT, the stock clip ons have a 1" rise so the standard Woodcraft's allowed very little clearance with the ram air covers.
I will exchange them for 1" rise clip ons and see if that will make the difference. I'll report back with my findings.
Hope this thread helps out anyone whose looking for a solution!
Mina is offline
post #26 of 26 (permalink) Old 12-12-2012, 10:20 PM
CNI Dawg's Avatar
Feedback Score: 11 reviews
We had the same problem when we bought our backup endurance bike
Bought an 19x18 so both the A & B bikes have same parts
Since levers are different we have to stock fewer parts for crash repair running same MC on both bikes
PLUS the friggin RCS doesn't bump the speedo !
You can set the RCS up with clip-ons to not hit but if you crash & bend the upper fairing stay you could be in trouble with the RCS hitting again
My advice - sell it & buy a 19x18 !
spend the money saved on clip-ons
Oh - it's also easier to run the TMV (brembo style) remote lever adjuster on the 19x18 on our vintage 600RR's
No room for it with the RCS
63 and still having FUN !!
#737 BK Racing - CMRA
Sponsors- Dallas Honda, Impact Safety Armor
"The road to Hell is really grippy with loads of run off & some wicked lefthanders"
CNI Dawg is offline
Human Verification
