Not starting after fuel pump replacement - 600RR.net
03-06 RR Modifications 2003, 2004, 2005 and 2006 Modifications
post #1 of 21 (permalink) Old 03-18-2017, 03:28 AM Thread Starter
Another issue guys. I rebuilt my fuel pump with a new motor and now my bike is cranking but not starting.
Reason I rebuilt it is because I wasnt able to rev past 10000rpms.
Ive tried holding the throttle open with no luck.
Also I have a charger hooked up and my battery is full.
Is it possible I wired the pump in reverse. If the bottom of the pump is on the floor with the terminals facing you, to which side does the pink wire from the motor go?
I dont know what else it could be.
The bike started up just fine before.
rickyjhutty is offline
post #2 of 21 (permalink) Old 03-18-2017, 03:39 AM Thread Starter
Forgot to mention I can hear the pump priming.
post #3 of 21 (permalink) Old 03-18-2017, 11:39 AM
Lifetime Premium
dixon cider's Avatar
I checked my manual for 07-12. The wiring diagram only shows a green and a brown wire to the fuel pump.
First time rider over 40. Finally made it!
dixon cider is offline
post #4 of 21 (permalink) Old 03-18-2017, 01:34 PM Thread Starter
I have a 04 model. Tried starting again today. Still not turning over.
Any advice would be greatly appreciated.
post #5 of 21 (permalink) Old 03-18-2017, 10:12 PM Thread Starter
So I swapped in the original pump motor and am having the same issue.
I will be changing out the spark plugs this week.
Is it possible that all the plugs have gone bad?
post #6 of 21 (permalink) Old 03-19-2017, 02:41 AM Thread Starter
No spark after fuel pump replacement
Hey guys I made another thread in the wrong section. Im hoping ill get more help here.
Title pretty much sums it up. After I replaced my fuel pump motor my bike wont start.
It cranks but dosent turn over. The fuel pump is priming and I can smell fuel from the exhaust. I dont know whats going on. Is it possible all the spark plugs have gone bad? I put in new gas after the pump rebuild. I even put the old pump motor in and still same problem.
Reason I replaced the motor is because I wasnt able to rev past 10k rpms.
Please help me.
post #7 of 21 (permalink) Old 03-19-2017, 02:48 AM
OzMoto's Avatar
Merged the threads, hopefully someone will know.
Have you searched OTF regarding not revving high?
Ride carefully - You are invisible.
FB | YT
Current: 2012 Street Triple R
Sold: 2001 NSR150SP | 2012 CBR250R
RIP: 2003 CBR600RR
Mods:
OzMoto is offline
The Following User Says Thank You to OzMoto For This Useful Post:
dixon cider (03-19-2017)
post #8 of 21 (permalink) Old 03-19-2017, 03:59 AM Thread Starter
yes thats why I rebuilt the fuel pump.
post #9 of 21 (permalink) Old 03-19-2017, 05:29 PM Thread Starter
I ordered a tool kit and new spark plugs. Hoping that resolves the issue.
post #10 of 21 (permalink) Old 03-20-2017, 01:39 AM Thread Starter
If i disconnect my fuel line from the tank to injectors, should fuel come squirting out? My pump is priming but im not sure if its actually delivering fuel.
post #11 of 21 (permalink) Old 03-20-2017, 06:17 AM
Feedback Score: 13 reviews
Why don't you just take this "rebuild" pump out and hook up the battery directly to it and see if it even work? Are you 100% sure that you rebuilt it correctly?
So much stuffs I wanted to buy, so little money...Damn it! :D
randomwalk101 is offline
post #12 of 21 (permalink) Old 03-20-2017, 02:54 PM Thread Starter
Ill try that today to ensure its working correctly. Ill report back shortly.
post #13 of 21 (permalink) Old 03-20-2017, 05:53 PM Thread Starter
fuel pump appears to be functioning correctly.
Is it possible for the spark plugs to suddenly go bad?
Also im getting to FI codes.
post #14 of 21 (permalink) Old 03-20-2017, 09:30 PM
get the codes and post them.
tary preisser is offline
post #15 of 21 (permalink) Old 03-20-2017, 10:06 PM Thread Starter
sorry was a spelling error. Im getting no codes. Ill be changing out spark plugs when they arrive and report back.
post #16 of 21 (permalink) Old 04-16-2017, 10:40 PM
NewRedRider's Avatar
Images: 24
Before you go replacing parts find out the problem. Throwing money at spark plugs probably wont fix it. Pull one plug and ground the threads on the header pipe. Try to crank it and see if you have spark. The plugs last forever.
How old is the fuel? Did it sit for awhile? Did you replace the screen on the pump?
Remember, you need 50 psi of pressure as well as a minimum flow of 6 ozs in 10 seconds. Even though you may have flow you may not have enough pressure and vice versa.
Sent from my LG-V495 using Tapatalk
NewRedRider is offline
post #17 of 21 (permalink) Old 04-16-2017, 10:46 PM
Images: 24
Fuel cut off relay inspection...
Sent from my XT1097 using Tapatalk
post #18 of 21 (permalink) Old 04-17-2017, 01:09 AM Thread Starter
Solved. I replaced the fuel pump and it fired right up.
Thanks for the help guys.
post #19 of 21 (permalink) Old 04-17-2017, 08:29 AM
Images: 24
I'm curious. What rebuild kit did you use? Did you figure out why the rebuild failed? My fuel pump just went out so I'm weighing my options.
post #20 of 21 (permalink) Old 04-21-2017, 11:54 PM Thread Starter
It was a direct fit ebay motor. It was over 100 sold.
post #21 of 21 (permalink) Old 04-22-2017, 02:16 PM
Images: 24
For anyone else that comes along looking for a fuel pump motor, I found this listing for a Kenro motor out of Japan. It also has a lifetime warranty and is rated at 43psi but supposedly has a higher flow rate than the OEM.
Look at this on eBay http://www.ebay.com/itm/302288049669
Human Verification
