Gearing/Speed Calculator for all bikes - 600RR.net
Tires, Suspension & Handling Sticky to slippery tire talk
post #1 of 34 (permalink) Old 06-17-2005, 09:58 PM Thread Starter
NewRedRider's Avatar
Images: 24
Ok guys. I know a lot of us have been wanting a speed calculator since the switch over to the new forum software. So today I happen to be over at 600RR.com and found one for the 600RR. I took that and did some tweaking so you can use it for any bike. All you have to do is get the gearing ratio and tire size from the manufacturer.
Enjoy!
*Requires MS Excel.
**EDIT - Metric conversions added
NewRedRider is offline
The Following 4 Users Say Thank You to NewRedRider For This Useful Post:
1PhatRR (09-17-2012), GConn (07-08-2013), legiteuphoria (04-10-2013), Lonewolf (11-03-2012)
post #2 of 34 (permalink) Old 06-19-2005, 01:24 AM
Lucky's Avatar
Thanks I've been looking for this !
Lucky is offline
post #3 of 34 (permalink) Old 06-19-2005, 01:55 AM
hotskate's Avatar
whats the difference between the bluye and yellow?
Two Brothers Exhaust, PCIII, 520 Conversion Sidewinder, 15 front, 45 rear, & chain, Comp Werks F/E, Greggs Flush Mounts, Michelin Pilot Power (F&R), C/A Integrated T.L., Blasters Horn, Flush Mount Rear Signals, LED Running light, Zero Gravity Screen, K&N Air filter, Polished lips on the wheels’, Gafler SS Brake Lines F&R., LED Tripage third eye light C/F Rear Hugger, Boomerang Sprocket Cover, Frame sliders, CRG Gold Shorties
hotskate is offline
post #4 of 34 (permalink) Old 06-19-2005, 09:45 AM Thread Starter
Images: 24
I just highlighted common highway speeds. The blue is interstate average for me.
There's also this one that Mianus posted that's pretty cool. Check it out.
post #5 of 34 (permalink) Old 06-19-2005, 11:37 AM
Resident Leg-Humper Females Beware
BlueBlur's Avatar
Images: 25
Feedback Score: 18 reviews
that's a slick little spreadsheet NewRed. thanks
HOOORRRAAAYYYY FOR BOOOOOTTIEES!!!
BALALALALALA OMG TERRORIST!!
BlueBlur is offline
post #6 of 34 (permalink) Old 06-19-2005, 11:43 AM
Vaep0r's Avatar
Images: 6
thanx man, that helps
Vaep0r
05 600RR Silver, w/ black tribal graphics
PC3 usb
Stainless, Yoshimura RS-5
15t renthal front sprocket
K&N Filter
Pazzo Short Levers
Harris Grips
Harris Tank Pad
Led Peg Turn Sigs, courtesy of Tripage
Fendereliminator Flushmount front sigs
Vortex Swingarm Spools
http://sportbikes.meetup.com/200/
www.orlandocycleriders.com
"wit, is educated insolence" - socrates
Vaep0r is offline
post #7 of 34 (permalink) Old 06-19-2005, 12:19 PM
hotskate's Avatar
yYea its nice!!
hotskate is offline
post #8 of 34 (permalink) Old 06-23-2005, 06:38 PM
Over the berm, and thru the woods, to grandmothers house we go...
flamedRRider's Avatar
Images: 70
Is that spreadsheet based on actual calculations or the speedometer readings. What I mean is does the spreadsheet give what speed the speedo is supposed to read (without error)?
04' 600rr function over fashion at this point.
flamedRRider is offline
post #9 of 34 (permalink) Old 06-23-2005, 07:32 PM Thread Starter
Images: 24
Yes. The calculations are based on the actual gearing ratios in the tranny, the tire profiles, and the sprockets. True speed.
post #10 of 34 (permalink) Old 06-24-2005, 09:02 AM
ZARR's Avatar
Images: 2
cool sheet - how can i change to kms - i see it's protected fields :(
The brave might not live forever but the cautious never lived at all...
2006 Red/Black 1000RR (Euro...yes the one with the black swingarm)
Full Arata Matte Ti
Arata rearsets
PCIII - Custom map
DNA Race filters
Puig clear racing screen
Clear alternatives integrated rear
ZARR is offline
post #11 of 34 (permalink) Old 06-24-2005, 10:43 AM
Images: 30
wow! with a 16/20 my top speed is 359mph! Im calling sprocket specialists!
very nice, thanks for sharing.
Mulligan is offline
post #12 of 34 (permalink) Old 06-24-2005, 12:12 PM
"he didn't clip me, he Body Slammed Me"
tiltedworld's Avatar
What tire did you use in the assumption? New, used etc.? Because different manufacturers will use different profiles and will change the equation slightly. I.E. GPA's are taller than Powers, etc.
tiltedworld is offline
post #13 of 34 (permalink) Old 06-24-2005, 02:19 PM
coolaid's Avatar
is this the same calculations to tweek the speedo healer? if so how do you apply that to the speedo healer?
coolaid is offline
post #14 of 34 (permalink) Old 06-25-2005, 12:15 PM Thread Starter
Images: 24
I added a Metric (KPH) spreadsheet for you guys. You really didn't want KPS did you? I assumed you meant KPH.
post #15 of 34 (permalink) Old 06-25-2005, 12:34 PM Thread Starter
Images: 24
Good question. Because each manufacturer's idea of what tire profile sizes really are, the calculations are based on standard measurements (mm). If you want to be exact on your calculations break out your micrometer and measure your tire profile. Let's say you measure 180 (mm) width and 105 (mm) hieght/depth. Divide 105 by 180 and you get .583333. Multiply by 100 and you get 58%. So your ACTUAL tire profile would be a 180/58/17. Put these numbers into the sheet and you get your corrected speed for your tire.
However, this would only equate to a 1.6% difference in speed at 15K rpm. Your talking about 3 mph. Not enough for the common rider to worry about.
post #16 of 34 (permalink) Old 06-25-2005, 12:37 PM Thread Starter
Images: 24
I haven't used the speedo healer so I don't know how to calibrate it. Now that you have the spreadsheet to verify, maybe someone with the knowledge will post up. You could always send the manufacturer an email and ask them how to calibrate it.
post #17 of 34 (permalink) Old 11-15-2005, 06:01 PM
whtdvl's Avatar
that is cool..thanks for sharing
05 Black- Devil SB2, BMC Race, FP v-stacks, Sportbike Creations FE, Clear Alt., Puig DB, Clear Greggs, Pazzo blk/blk shorties -Dynoed w/only slip-on 102.5hp/42.6tq
http://www.myspace.com/18284823
whtdvl is offline
post #18 of 34 (permalink) Old 05-11-2006, 12:52 PM Thread Starter
Images: 24
post #19 of 34 (permalink) Old 08-02-2006, 12:01 PM Thread Starter
Images: 24
Lots of people asking about gearing changes soooo....
post #20 of 34 (permalink) Old 08-20-2006, 02:46 AM
Crass Tengu's Avatar
Was looking for this, thanks!
www.Tengu.ca
Bike Artist
Crass Tengu is offline
post #21 of 34 (permalink) Old 03-12-2007, 06:41 PM
S VEEEEEEEEEEEEE Thrasher
~BLACK ICE~'s Avatar
Images: 5
Thank god for the SEARCH option on these forums!!!
Bring it back from the dead.
Thanks NewRedRider!
~BLACK ICE~ is offline
post #22 of 34 (permalink) Old 10-27-2008, 12:05 PM
scotty v's Avatar
My friend's bike is waaaaaay off. It's geared so high that you can run it in 6th gear around town without a problem. I'll show him this.
scotty v is offline
post #23 of 34 (permalink) Old 03-30-2009, 03:55 PM
Joszer's Avatar
I think this should be "Sticky'ed"
Joszer is offline
post #24 of 34 (permalink) Old 04-07-2009, 07:54 PM Thread Starter
Images: 24
^I thought it was....
post #25 of 34 (permalink) Old 11-17-2009, 08:37 PM
varicella's Avatar
sheet is cool but it doesn't let me change the final drive and my F3 is not 2.688, it's 2.866, why all the protection?
varicella is offline
post #26 of 34 (permalink) Old 11-17-2009, 11:16 PM
varicella's Avatar
sorry for my ignorance, i've figured out that the final drive is nothing more than the rear sprocket teeth / front sprocket teeth and knowing that i've duplicated your spreadsheet, the math is really simple. Thanks for the idea, it's cool to look at this data for different bikes and comparing sprockets for different tracks.
post #27 of 34 (permalink) Old 11-18-2009, 09:53 PM Thread Starter
Images: 24
NP bro....Glad you figured it out! The protection was to keep people from screwing up the sheet and getting unreliable data. Let me know if you need any help.
post #28 of 34 (permalink) Old 03-07-2010, 10:30 PM
Banned
gearingcommander.com much?
RedEIKO0713 is offline
post #29 of 34 (permalink) Old 03-11-2010, 09:33 PM
LowBlow's Avatar
Images: 31
Feedback Score: 5 reviews
anybody have problems unzipping the file?
I'm using winzip and it says I'm trying to unzip an unrecognized file :(
LowBlow is offline
post #30 of 34 (permalink) Old 09-20-2011, 12:25 AM
cr80rb's Avatar
Thank YOu!!!
cr80rb is offline
Human Verification
Similar Threads
Thread Thread Starter Forum Replies Last Post
caught in the rain...and undercover cop nailing bikes and sending away on flatbeds.. cbrkid11 General Discussion 18 06-13-2005 02:00 AM
Pocket Bikes? vr4_vet Off Topic & Flame Thrower 18 06-04-2005 11:58 PM
Bikes knocked over in parking lot JoshAZ600RR General Discussion 61 05-02-2005 06:38 PM
05 bikes My opinion *which means nothing wolfpac52 General Discussion 14 04-19-2005 10:26 AM
Rode a few different bikes the past few days.... Audi 600rr General Discussion 8 06-28-2004 09:17 PM
