Tire pumps - 600RR.net
Tires, Suspension & Handling Sticky to slippery tire talk
post #1 of 17 (permalink) Old 12-02-2012, 06:10 PM Thread Starter
Tire pumps
My tyre pump recently went, was using a double barrelled foot pump by Michelin to pump of my Michelins, it still seals find, but now doesnt pump any air in, so none is lost bit it doesnt add any, thankfully i found another pump in my room in time but just wondering what everyone is using?
Petrol station pump?(how often are they checked) Foot pump? Hand pump?
brmoore is offline
post #2 of 17 (permalink) Old 12-02-2012, 06:22 PM
swan-rr5's Avatar
I use a mini compressor that plugs into a car cigarette lighter & a digital gauge. similar to this but not as fancy
http://www.halfords.com/webapp/wcs/s...Id_255241#tab3
petrol station pump if I'm stuck
swan-rr5 is offline
post #3 of 17 (permalink) Old 12-02-2012, 06:42 PM
X-treme1's Avatar
Feedback Score: 5 reviews
I use a small pancake style electric compressor. They hold a lot of air and ate small enough to carry around. About $50-$60 at Lowe's.
You start the game with a full pot of luck and an empty pot of experience. The object is to fill the pot of experience before you empty the pot of luck.
2010 Leyla
X-treme1 is offline
post #4 of 17 (permalink) Old 12-02-2012, 06:50 PM
good quality bicycle pump works for me.
then good psi check.
easy+cheap+reliable.
tary preisser is offline
post #5 of 17 (permalink) Old 12-02-2012, 08:11 PM
AF600RR's Avatar
+1, have the same set up.
you dont know what sort of tool has abused the petrol station ones. plus at least you can use your own one at home when he tyres are cold and whenever you want.
AF600RR is offline
post #6 of 17 (permalink) Old 12-03-2012, 11:50 PM
PattyK's Avatar
I have an air compressor and love it. Before that I would just go to the gas station if needed.
PattyK is offline
post #7 of 17 (permalink) Old 12-04-2012, 03:41 AM
BOTY 2013 Winner & BOTM Winner 11/14 & 4/13
Ry6rr's Avatar
Images: 2
Feedback Score: 6 reviews
Tyre Pump
I use a Michelin double barrel foot pump and I have an accurate Sealey digital tyre pressure gauge. I only ever use the garage forecourt air hoses if its an emergency. They are not always accurate and by the time I have rode there my tyres will have some heat in them so any reading is going to differ to my usual cold road pressures.
Ry6rr is offline
post #8 of 17 (permalink) Old 12-04-2012, 05:26 AM
SmuRRf's Avatar
I use a mini compressor I used for 4x4 trips. Works a treat but my main concern is presure gauge. The ones at the petrol stations are not calibrated and I would not know where to find a decent one to carry as a portable.
SmuRRf is offline
post #9 of 17 (permalink) Old 12-04-2012, 06:31 AM Thread Starter
good point so nobody should be using the garage one!
brmoore is offline
post #10 of 17 (permalink) Old 12-04-2012, 08:35 AM
i also use a mini compressor plugged into cig lighter on bike like most of the above
works great,compressors got a gauge on it but also have a decent seeley gauge
ash2020 is offline
post #11 of 17 (permalink) Old 12-04-2012, 09:03 AM
clx
i have the 12volt compressor but the gas station is just easier
2005 600rr 36300km
2001 Isuzu kb 320 V6 LX double cab 212000km
clx is offline
post #12 of 17 (permalink) Old 12-04-2012, 09:08 AM
Sponger's Avatar
I use a track pump and a digital pressure gauge.
RIP Marco Simoncelli #58
Sponger is offline
post #13 of 17 (permalink) Old 12-06-2012, 01:24 AM
+1 works for me too
ebag600 is offline
post #14 of 17 (permalink) Old 12-08-2012, 07:52 AM
Raj24v's Avatar
I have an electric air pump and then a digital tire pressure gauge to be accurate and to make necessary adjustments.
Do the same for the cars too.
Raj24v is offline
post #15 of 17 (permalink) Old 12-10-2012, 06:08 PM
fallingbomb's Avatar
I use my Specialized bicycle pump.
2007 CBR600RR -- CVMA #270 -- Pictures -- Build Thread
fallingbomb is offline
post #16 of 17 (permalink) Old 12-13-2012, 05:35 PM Thread Starter
yea im thinking a footpump is the way forward, i had one for my bike, hand pumping and pedal ones are effort...its nice and simple with the ones with footrests and a handle you push down
brmoore is offline
post #17 of 17 (permalink) Old 12-17-2012, 09:35 PM
etxx's Avatar
x17 for bicycle pump WITH integrated gauge here. I also have a separate gauge for checking pressures.. be it routine check or track w/e.
Just takes a few pumps. Seems like it would take longer to setup the electric one pump and then put it away.
etxx is offline
Human Verification
