OEM brake lines are better? - 600RR.net
Tires, Suspension & Handling Sticky to slippery tire talk
post #1 of 28 (permalink) Old 12-31-2012, 06:57 AM Thread Starter
Rad Rage's Avatar
This is a straight copy paste from the fireblades.org forum, what do you guys think?
I caught this while surfing another board and decided to pose the question to Fireblades. The question will be evident by the time you read the paragraph.
Why one would want a stiffer brake feel on a road bike? I know that I like the stiff feel that my steel braided hoses provide on my track bike, but I use it only on the track and thus I do frequent high-effort braking and I seldom encounter "emergency" braking situations. On my road bike, however, from time to time I encounter situations where I quickly and unexpectedly apply a lot of brake. In these situations, I have a tendency to stab the brake (because I wasn't planning, for example, to have that elk run out into the road ahead of me). For me, the additional compliance provided by the OEM lines compared to steel-braided lines is a safety mechanism -- it helps buffer the shock of brake application so I get a smoother, more controlled application of the brake. I can still get all the brake power I could ever want, because even at full-effort I cannot pull the brake lever all the way to the grip. I just get that initial application in a smoother, more controlled fashion even when I'm panicked.
I think the OEM lines are safer than aftermarket steel braided lines on a street bike.
Any thoughts on this? Bunk? Sensible? Somewhere in between?
I've now run my bike on a track. I will never race it competitively, thus the trackday duty my brake system saw was as extreme as it will ever see ... and I didn't long for a different lever feel, nor did my brakes ever fade despite sessions that lasted as many as a dozen fairly brisk laps in a row.
So for me, maybe SS lines are frivolous but for the way they look?
Input?
TIA
-Chain
2011 CBR600RR 'X-Ray' Build Thread
http://www.600rr.net/vb/176-rr-other-brands-bike-build/294795-rads-600rrb-x-ray-build-thread.html
Co-President of Team46
"My bike is too fast for the track" Ubercool ZX-14R rider.
Rad Rage is offline
post #2 of 28 (permalink) Old 12-31-2012, 11:16 AM
03cbr-rider's Avatar
I think that's stupid. It's not the bike, it's the rider that cannot safely roll on his brakes with better brake lines. You don't slam on the brakes in an emergency situation anyways unless you feel like locking up the brakes or diving over the front end. I think this is like saying, "a cruiser is more comfortable, because it's not as sporty or as much like a race bike". Basically what it comes down to is it's a performance modification on a race bike, not designed to help riders avoid emergencies on the street, it's designed to avoid expansion over excessive temperatures with more breaking power over higher stress to reduce fade while retaining the same feel. This is yet another person overlooking the fact he has a race bike on the road...
03cbr-rider is offline
The Following User Says Thank You to 03cbr-rider For This Useful Post:
Nuttynu (01-02-2013)
post #3 of 28 (permalink) Old 01-02-2013, 12:33 AM
BOTM Winner 1/13
Nuttynu's Avatar
Sounds like jimmy ....
My Ride Report :
-Alaska,The Last Frontier
Nuttynu is offline
post #4 of 28 (permalink) Old 01-02-2013, 05:30 AM Thread Starter
Rad Rage's Avatar
Did you have to so abruptly kill the thread ?
I like they way you put it, there is complacency in that OP's reasoning. That is why you are always encouraged to practice emergency braking so that it is second nature to you and you end up applying the brakes properly rather than stabbing at them. Hell if you practice a little bit you will notice that real braking power kicks in not as soon as you squeeze the lever (And the pads make contact with the rotors) but a split second after that. It is during that time you need to modulate the lever, and maintaining good feel provided by steel lines will help you achieve that rather than trying to compensate for the rubber lines expanding. So in essence once you get over the hurdle of stabbing at the brakes in an emergency, using steel line makes it easier and more efficient.
Guess that's that.
http://www.600rr.net/vb/showthread.php?t=294795
Rad Rage is offline
post #5 of 28 (permalink) Old 01-02-2013, 06:15 AM
TheX's Avatar
Images: 2
Feedback Score: 5 reviews
Most people over exaggerate the difference they feel with aftermarket lines when discussing them.
Iím jealous of all the people that haven't met you.
TheX is offline
The Following 2 Users Say Thank You to TheX For This Useful Post:
MachRider (01-02-2013), n3dmax (01-02-2013)
post #6 of 28 (permalink) Old 01-02-2013, 06:57 AM Thread Starter
Rad Rage's Avatar
So you are saying you have never felt enough of a difference to warrant buying aftermarket lines given that the OEM ones are in good condition?
Rad Rage is offline
post #7 of 28 (permalink) Old 01-02-2013, 07:12 AM
Ryansgotacbr's Avatar
I think if youre getting brake fade on the street you need to get your ass off the road
Sent from my XT555C using Motorcycle.com Free App
Ryansgotacbr is offline
post #8 of 28 (permalink) Old 01-02-2013, 07:24 AM Thread Starter
Rad Rage's Avatar
The reason being.....
Rad Rage is offline
post #9 of 28 (permalink) Old 01-02-2013, 09:38 AM
TheX's Avatar
Images: 2
Brake fade is more an issue with fluid. The stock brake components work VERY well if properly setup. Use a good fluid and bleed them properly. I flush my brake systems at least twice a year, and more depending on mileage.
TheX is offline
post #10 of 28 (permalink) Old 01-02-2013, 10:05 AM
the reason being is that youre pushing too hard....im not the best rider but i can put down 20 fast paced laps at the track and i dont get too much brake fade to be honest
post #11 of 28 (permalink) Old 01-02-2013, 10:51 AM
Drick's Avatar
I honestly think its more of a looks thing for the street and people over exaggerate the difference they feel like X said.
I used to frequent mustang forums because im a Mustang guy (even more so than I am a bike guy, I just ride for fun) and for awhile about 3-4 years ago. Underdrive pullies where kind of like that. They offered a slight horsepower gain but when I bought them I didn't notice the difference at all. And some people will say. "Oh yeah I definitely felt a difference, not much of a difference but you could tell there was an increase" I think its the same concept. People imagine they feel something that isn't really there to justify the money they spent on something
That said, I'm still buying braided brake lines. They look cool! Lol
"I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think can respond with a good deal of pride and satisfaction: 'I served in the United States Navy.'"
President John F. Kennedy
Drick is offline
post #12 of 28 (permalink) Old 01-02-2013, 01:37 PM
Official Dealer
Honda East Toledo's Avatar
Honda has always had great brakes,from the Dirt bikes up to the Gold wing,the components they use seem to be better then most other companies,the master cylinders,fluid,lines etc,Honda never seemed to shy away from spending a little extra coin on brakes.
Honda East Toledo is offline
post #13 of 28 (permalink) Old 01-02-2013, 07:55 PM
FightingChance's Avatar
Feedback Score: 10 reviews
Car forums are the worst.
"All I got is a CHIP and a PULLEY and now I run LOW 10's while getting 89MPG, anyone else that drives any other sports car is STUPID"
FightingChance is offline
post #14 of 28 (permalink) Old 01-02-2013, 07:56 PM
This is true - Honda OEM suppliers are higher tier, more often, than other makes. It's the extra 10% MSRP in their products.
post #15 of 28 (permalink) Old 01-02-2013, 08:37 PM
Drick's Avatar
For sure. About a week later there was some "lightly used under drive pullys" on eBay for sale lol
The ones I've been on aren't to bad with the brand loyalty. But if you go on Ls1 tech (suck btw :D haha) those are some mean SOBs over there. If it doesn't have an lS1 in it then its worthless......even if the mustang they hate so much stomped them 10 times over they always have an excuse as to why they still suck lol
Drick is offline
post #16 of 28 (permalink) Old 01-03-2013, 12:49 AM
onEsimus's Avatar
For me, honda's motorcycle are already equipped with capable brake system. . . . at least compare to yamaha's oem brake system, honda's are way better!
onEsimus is offline
post #17 of 28 (permalink) Old 01-03-2013, 02:18 AM Thread Starter
Rad Rage's Avatar
Sometimes you live in a country without a single track, sometimes you learn to ride in a disciplined manner after you accustom yourself to certain roads to pursue your passion, and sometimes you are willing to accept the risk. As a result I do experience brake feed, especially when I practice emergency braking and ride hard in general.
Interesting, so in what way are Yamaha's brake systems inferior to the rest?
Rad Rage is offline
Old 01-03-2013, 08:26 AM
brmoore
This message has been deleted by Moeman. Reason: Spam and/or unwanted content
post #18 of 28 (permalink) Old 01-03-2013, 10:54 AM
Nico's Avatar
Not this little black duck... to be perfectly honest I can't feel any difference at all. I did however buy braided lines when I replaced mine because they look good, they were cheaper than OEM in Australia and because I just wanted to...
I also haven't been to the track so that may account for my lack of noticing the difference...
Nico is offline
post #19 of 28 (permalink) Old 01-03-2013, 11:30 AM
BOTY 2013 Winner & BOTM Winner 11/14 & 4/13
Ry6rr's Avatar
Images: 2
Feedback Score: 6 reviews
Braided Brake Lines
I posted this last month about braided brake lines. The common misconception with braided brake lines is that they offer better braking performance. What they do offer is better feel and consistency as they are not prone to fade. OEM rubber lines expand under heat and bulge resulting in a loss of brake fluid pressure which translates to a sensation of brake fade and a 'sponginess' felt at the lever after prolonged use. Hence you feel like you need to apply more and more pressure at the brake lever for the same amount of braking performance over time. Braided lines alleviate this problem as they do not expand and therefore maintain strong braking performance and offer a more progressive and consistent feel at the lever particularly when the brakes are being used extensively for example on track. They are an extremely worthwhile upgrade particularly if you intend to ride on track. However, on the road where you are highly unlikely to be exerting the same amount of braking force, and therefore generating as much heat, so you are unlikely to feel any difference to a well maintained set of OEM lines. For road only use you will feel more benefit simply changing the fluid periodically and thoroughly bleeding the system.
Ry6rr is offline
post #20 of 28 (permalink) Old 01-03-2013, 11:38 AM
MikeyP's Avatar
Braided lines have no use on the street other than looks.
The OEM setup is enough to flip your bike on the street, or the track.
You get brake fade on the street?
I guarantee you I can ride the street a lot faster than you, and I find your statement ridiculous. You either have a fluid or mechanical problem with your brakes, or you're embellishing the truth.
If you want braided lines get them. It's your money.
To say that they will help you in an emergency braking situation more than OEM is false.
...oh, and OEM Honda brake lines are steel reinforced...so, whatcha gotta say now?
2008 CBR 600RR #1 (Graffiti) street
2008 CBR 600RR #2 track
CMRA #599
Originally Posted by MikeyP View Post
Unfortunately bikes fall over. It's in their nature.
It's our job to keep them upright, but we are only men.
MikeyP is offline
post #21 of 28 (permalink) Old 01-03-2013, 02:19 PM
Truf!
Originally Posted by ry6rr View Post
i posted this last month about braided brake lines. The common misconception with braided brake lines is that they offer better braking performance. What they do offer is better feel and consistency as they are not prone to fade. Oem rubber lines expand under heat and bulge resulting in a loss of brake fluid pressure which translates to a sensation of brake fade and a 'sponginess' felt at the lever after prolonged use. Hence you feel like you need to apply more and more pressure at the brake lever for the same amount of braking performance over time. Braided lines alleviate this problem as they do not expand and therefore maintain strong braking performance and offer a more progressive and consistent feel at the lever particularly when the brakes are being used extensively for example on track. They are an extremely worthwhile upgrade particularly if you intend to ride on track. However, on the road where you are highly unlikely to be exerting the same amount of braking force, and therefore generating as much heat, so you are unlikely to feel any difference to a well maintained set of oem lines. For road only use you will feel more benefit simply changing the fluid periodically and thoroughly bleeding the system.
post #22 of 28 (permalink) Old 01-03-2013, 02:21 PM
In the past, I heard the same (though I have never ridden a Yamaha) - that their bikes had 'wooden' feeling brakes. No clue why reviewers would seem to mention this, I do know that Yamaha used some slightly different caliper style than anyone else for a while. I know that R6's now have a Brembo master cylinder which is cool (it's off-angle and cast, so it's probably comparable to any modern Nissin OEM, but still.)
post #23 of 28 (permalink) Old 01-03-2013, 03:36 PM
AF600RR's Avatar
LOL
10char
AF600RR is offline
post #24 of 28 (permalink) Old 01-03-2013, 05:14 PM
MikeyP's Avatar
Originally Posted by ahmedf View Post
LOL
10char
Funny?
Did you go and look yet?
I'll be here all day. Let me know after you check, then tell me what you see.
CMRA #599
MikeyP is offline
post #25 of 28 (permalink) Old 01-03-2013, 05:46 PM
He is right, they are steel reinforced and most brake lines are steel reinforced. The ones on my car are as well, it rare to not find a line thats steal reinforced, and he is right about them being over rated for street use.
Flickr Vimeo
DC/VA/MD and want a photoshoot? PM me!
2010 Black Volkswagen GTi
2012 Red/White CBR600rr
I love them too much.
JC593 is offline
The Following User Says Thank You to JC593 For This Useful Post:
MikeyP (01-03-2013)
post #26 of 28 (permalink) Old 01-03-2013, 06:17 PM
AF600RR's Avatar
Funny?
no i know you're right, im laughing more at the statement at the end and the emoticon
AF600RR is offline
post #27 of 28 (permalink) Old 01-03-2013, 06:27 PM
MikeyP's Avatar
No worries :)
Never heard that before either. Isn't a common mod to use an R6 MC on other bikes?
CMRA #599
MikeyP is offline
post #28 of 28 (permalink) Old 01-07-2013, 06:19 AM Thread Starter
Rad Rage's Avatar
Firstly, didn't know OEM lines were reinforced.
Secondly, you guarantee me you can ride the street a lot faster than me because......this is a pissing contest now? I know when I feel brake fade, it might be my fluid, nontheless braided lines are still better. It was an assumption that they would perform better in an emergency braking situation because of the improved feedback you would be getting. One I still hold; the fact that you can flip your bike with OEM lines is irrelevant. I am not talking about braking power as Ry6rr posts illustrates, I am talking about the braking experience as a whole.
By in the past, do you mean 10 or 3 years ago?
I have heard of this and that is why I am wondering what's with the ripping on Yamaha's brakes.
Rad Rage is offline
Human Verification
