Hi just doing some research and looking at the 2013 front shock, structurally it looks the same. Also most of the 600rr is unchanged sinced 07, so I was wondering if it can work.
Yes, I do believe the uppers are all the same size (48mm). There's not really a function upgrade in this though, as it's still compression, rebound, and preload and the same rate springs. Compression on one fork and rebound on the other is nice (I think it's like this? Can someone confirm?)
Yes they will work without question. Different design but straight swap. The stock BPF aren't the greatest tough. Aftermarket cartridges are more expensive too then the previous generation. Also, as stated parts can be harder to come by for the 13+
I thought the 2012 and older model shock tubes are smaller in diameter than the newer ones?
Related Threads
Honda CBR 600RR Forum
3.9M posts
92.7K members
Since 2003
