Hi guys! i have a little bit of an issue... I went to the ground last night (left side of the bike)... at the moment the bike started, but today not. After dissembling and looking for broken parts (which couldn't found none) decided to check the battery, with the bike running the multi tester showed 12v... so my battery isn't charging. What fuses o relay should i check? The cover of the stator looks fine, maybe the hit could affect it? HELP!
:salute:
:salute:
