Swapped 06 engine into 03 Model but no ECU
873 views 1 reply 2 participants last post by  OveRReV
#1 ·
Hi there,
I installed the 06 engine into a 03 600 RR. The engine is running but I did not change the wiring loom or ECU. Can this cause damage down the line?
Thank you
#2 ·
Nope, i have an 05 engine in my 03 600RR with an 03-04 HRC AMA ECU, no problems yet after tuning with PCV.
