water cooled helmet/jacket/pants - 600RR.net
Helmets, Leathers, Boots & Gloves Discuss and ask questions about your gear here
Sponsored by SportbikeTrackGear
post #1 of 19 (permalink) Old 11-15-2012, 06:50 AM Thread Starter
clx
there has got to be a water cooled helmet/jacket or similar on the market. small pipes throughout the jacket, small pump moving it around to cool it off in the wind, or through ice pack.
im dissapointed the motorcycle manufacturers havent done this yet?
2005 600rr 36300km
2001 Isuzu kb 320 V6 LX double cab 212000km
clx is offline
post #2 of 19 (permalink) Old 11-15-2012, 06:52 AM
fonix36's Avatar
sound uncomfortable and rather dangerous.
if that bitch popps on you while riding that couple be potentially hazardous,
also its cold as **** balls, why are you even thinking about this
01 cbr600f4i - sold
06 cbr600rr - totaled rip
fonix36 is offline
post #3 of 19 (permalink) Old 11-15-2012, 06:57 AM
AF600RR's Avatar
what about the extra added weight.
impractical really on all levels
AF600RR is offline
post #4 of 19 (permalink) Old 11-15-2012, 07:10 AM Thread Starter
clx
its summer where i am. i get to work all sweaty in the morning. it shouldnt be any mor euncomfortable than a jacket anyway. the pipes should be really soft and small so as to not becoem a hassle.
if it pops, youll be just as wet as when you were sweaty.
2005 600rr 36300km
clx is offline
post #5 of 19 (permalink) Old 11-15-2012, 07:11 AM Thread Starter
clx
i dont want to cool down a race horse, just reduce my discomfort a little, so im not talking a swimming pool here, just probasbly a littre of water moving around your body.
to make it more effective, let it flow through dry ice somewhere on the bike
2005 600rr 36300km
clx is offline
post #6 of 19 (permalink) Old 11-15-2012, 07:16 AM Thread Starter
clx
it can be either the jacket or the helmet, but if both can be included that would be great.
2005 600rr 36300km
clx is offline
post #7 of 19 (permalink) Old 11-15-2012, 09:49 AM
AF600RR's Avatar
you do realise, that the human body has its own cooling system...sweat.
works on the exact same principle as a water cooling system, say in our bikes/cars.
hence i can only assume leathers are vented to utilise this.
AF600RR is offline
post #8 of 19 (permalink) Old 11-15-2012, 10:03 AM
Lifetime Premium
Minx's Avatar
So you want to add a motor, hoses, power source, heat exchanger, and the mass of the water to a helmet and/ or jacket without worrying about added weight or bulkiness.
Ok.
Helmets already have vents for cooling and jackets are perforated to allow airflow. Get some warm weather base layers to help regulate body temp.
Sent from my DROID RAZR using Motorcycle.com App
-Minx
My Modification Memoir - GOLDEN EYES
FS: 07+ Stock Exhaust + Heat Shield ($75)
FS: Dainese Delta Pro Pants (38 Long) - $300+
Complete: Li Ion Battery, HID Gold Eyes, Radiator Guard, SSR Rearsets and RC2 Levers, Type 4 / 3 Brake Lines, 8149B Slip-On, FE, IT, Cluster LEDs, and LED Pegs, Sliders, Brake Pads, Corsa Screen.
Up Next: TTX MkII Rear Shock
Minx is offline
post #9 of 19 (permalink) Old 11-15-2012, 10:07 AM
Lifetime Premium
Minx's Avatar
Trying to use tiny hoses would limit the thermal exchange from your head to the water and would decrease the impact absorbency of the helmet if the same size shell is used.
-Minx
Minx is offline
post #10 of 19 (permalink) Old 11-17-2012, 04:12 PM
ALG
It would really only be needed approaching high 30 degrees centigrade. And at that point, you should probably take a car.
ALG is offline
post #11 of 19 (permalink) Old 11-17-2012, 04:23 PM
HI OFECR's Avatar
Its called a camel pack, drop it in the fridge before hot ride.
Spidi makes a suit that hold one in the hump.
HI OFECR is offline
post #12 of 19 (permalink) Old 11-17-2012, 04:45 PM
as above ,
if you are really serious about it a tshirt then the refrigerated camelback with some ice cubes thrown in.....is about as good as it gets. (under the jacket as close to the skin as possible)
motogp does not seem to much more advanced than above in its cooling tech....
riding with a wet long sleeve tshirt on helps also for about 15 mins....used to spray myself with a water bottle while riding when in SE Asia.
anyway, riding to work gives you a "presentation" problem if the above is tried.
tary preisser is offline
post #13 of 19 (permalink) Old 11-19-2012, 02:08 AM Thread Starter
clx
hi all thanks for the feedback. water smells better than sweat, hence id like to avoid using my body's natural coolant. the camel pack is an option, even it if means i put a ton of ice and some nice juice in there and sip on it when it gets really hot. of my 25 minute commute i need to cool down for the last 10 minutes, so that should still work.
to trim my suggestion down a bit, lets leave out the helmet, lets only focus on the jacket. its already heavy so the impact is reduced.
how about putting crushed dry ice in my pockets?
2005 600rr 36300km
clx is offline
post #14 of 19 (permalink) Old 11-19-2012, 06:52 AM
Lifetime Premium
Minx's Avatar
Just thought of this (just woke up and catching up on threads) - buy a mini fridge and keep your jacket in there over night and then when you ride in the morning it's nice a cool already. No cooling tubes, no drenching yourself before hand.
You chilled the first bit of the ride so that by the middle to end, you're normal or just a little warm. Plus in the cooler days, you still have a mini fridge to store tasty beverages.
So what I'm trying to say is: that camelpack idea seems like a good one.
-Minx
Minx is offline
post #15 of 19 (permalink) Old 11-19-2012, 08:48 AM
daisoman's Avatar
If i was that uncomfortable I'd Take my car.
Technically of you move dry ice on public roads you'll need a DG sign on all four corners. Lol
daisoman is offline
post #16 of 19 (permalink) Old 11-21-2012, 02:54 AM
Okay...what about a jacket that has tubes inside of it, all over, with a liquid such as antifreeze that can get really cold without freezing. So you can put your jacket in the freezer the night before and have maybe 45 min of cool riding until the antifreeze in the tubes warms up??
Lol
toronto.cbr is offline
post #17 of 19 (permalink) Old 11-21-2012, 03:05 AM Thread Starter
clx
^^^ creativity rocks guys. ok so wont the jacket becvome moist when it starts heating up?
2005 600rr 36300km
clx is offline
post #18 of 19 (permalink) Old 11-21-2012, 04:36 AM
dreamzboy's Avatar
I think what you're missing is the under armour suit. The one that absorbs sweats while keeping you cool. Alpinestars sells them. riding with it on and my jacket helps by a few degree. I wouldn't see myself riding in 90+ degree without it.
I agreed with the previous comment. If you can't handle it, take the car. Gotta pay to play.
dreamzboy is offline
post #19 of 19 (permalink) Old 11-22-2012, 12:56 AM
panda's Avatar
Cool Shirt makes what your talking about.
They have a few portable systems here. LINK
panda is offline
Human Verification
