Brake fluid bleeding query. - 600RR.net
Maintenance Maintenance advice and questions are here
post #1 of 32 (permalink) Old 05-26-2010, 04:53 PM Thread Starter
NwcCBR's Avatar
Images: 3
So i've just changed the oil and replaced the air filter for the 18000km service and now it's onto the brakes.
All, or most of the how-to threads i've serched for so far state that to bleed the the brakes you should just pump the lever till it's air only. But what I would like to know is - doesn't any fluid stay over in the calipers because the pistons are extended out? Don't you have you remove the calipers, push in the pistons to force all fluid back into the lines and then bleed using a vacuum?
Thanks,
99% of bikers give the rest a bad name..
NwcCBR is offline
post #2 of 32 (permalink) Old 05-26-2010, 05:45 PM
Demented
Posts: n/a
Do not pump the brakes until it's air only. That will only make bleeding the brakes much more of a headache.
Just bleed the conventional way by applying pressure to the brake lever, then opening the bleed valve and closing it, then repeating that for each side and at the master cylinder until the fluid comes out clean. A vacuum bleeder will work as well with that method.
post #3 of 32 (permalink) Old 05-26-2010, 06:36 PM
NIGHT_STALKER's Avatar
Or just got get the one man bleeder kit from auto parts store. +1 on what Demented said bleed tell the fluid is clean, just make sure the system does not get any air.
My fav. Quote!!!!
Originally Posted by bluremi View Post
Listen, a--hole, if I wanna do wheelies in the driveway to impress my son's classmates I'm gonna damn well do it and you safety fascists better stay outta my way cuz the driveway's pretty short and you have to hit the brakes pretty hard to avoid those damn kids
Nothing more, nothing less
The guy with the bigger gun wins
NIGHT_STALKER is offline
post #4 of 32 (permalink) Old 05-26-2010, 06:55 PM
c5jetmech81's Avatar
Do it with 2 people...makes it sooooo much easier. You can do it with one but trust me.......2 is better.
05CBR600RR Blk Tribal
Scotts Damper, Harris "CBR" Grips, Hotbodies Flushmounts, Micron Slipon, Vortex Sliders/Spools, Sportec Windscreen (Red), Stomp Grips(Clear), Galindo Delrin Bar Ends(Red), PCIIIusb, DIY Velocity Stacks(Short), BMC Air Filter, Tripage Evil Eyes & 3rd Eye(Red), Rim Tape(Red),
BrowningBuck MOTY Gear Indicator Mod(Red)
, HEL SS Brakelines(Red), Vesrah RJL pads
Coming Soon
Powdercoating, Shorty Pazzo Levers(Red w/Blk Adjuster)
c5jetmech81 is offline
The Following User Says Thank You to c5jetmech81 For This Useful Post:
eserr (12-03-2011)
post #5 of 32 (permalink) Old 05-26-2010, 07:12 PM
Sadt3arZ's Avatar
Feedback Score: 14 reviews
the point of bleeding is to get the air out. why would u pump until there's nothing but air left in there? once u fill it with fluid again, you'll have a ton of air trapped in there. the key to the whole thing is to never let ur reservoir go empty or you'll be starting all over. you want the air out so that when u brake you don't get that mushy feeling. you want a solid feel. with regular oem lines, the rubber will expand under pressure. if air's in there it will make this worse. more air = squeeze a lot harder on the lever in order for enough pressure to be applied to pads. this is why people switch to steel braided lines. heres what you do.
1) get wrench that will fit nut on bleeder (don't lossen the nut yet)
2) attach hose to bleeder nozzle
3) pump ur brake lever a few times and on the last time keep pressure on the lever (hold the brake lever in) and losen bleeder nut. You'll see a little fluid come out along with air bubbles.
4) with the brake lever still pressed in, tighten the bleeder nut.
5) repeat this until you don't see anymore bubbles come out.
** bubbles are bad, you don't want those in there
** MAKE SURE THAT YOUR RESERVOIR DOESN'T GO EMPTY OR YOU'RE GONNA BE DOING THIS FOR A VERY LONG TIME
remember you have 2 callipers in the front and one in the back. bleed them all. if you have no bubbles initially then you're good
Sadt3arZ is offline
The Following User Says Thank You to Sadt3arZ For This Useful Post:
Biscuits (02-13-2011)
post #6 of 32 (permalink) Old 05-27-2010, 02:45 PM Thread Starter
NwcCBR's Avatar
Images: 3
thanks guys, especially Sadt3arZ on that last post.
If I were to change the fluid for a higher rating one, which method should I use to remove all of the old brake fluid and to refill the new fluid? If I were to use this method, surely the fluid would get mixed, ye?
NwcCBR is offline
post #7 of 32 (permalink) Old 05-27-2010, 02:58 PM
Demented
Posts: n/a
DOT 3, 4, and 5.1 are all compatible, so you don't have to worry about them mixing. The higher the number, the dryer it is and hotter it can be before it boils.
post #8 of 32 (permalink) Old 05-28-2010, 05:11 PM
xHECKSHERx's Avatar
Feedback Score: 13 reviews
Here is a video from sportbiketrackgear.com they helped me a bunch! I did my first bleeding about 2 weeks ago with no problems.
03' 600rr- sold
07' 600rr-
sold
05' 636- sold
Currently searching
xHECKSHERx is offline
The Following User Says Thank You to xHECKSHERx For This Useful Post:
post #9 of 32 (permalink) Old 05-29-2010, 05:23 PM Thread Starter
NwcCBR's Avatar
Images: 3
yeah, I used that video too! found it a few days ago. Thanks though.
Anyone know the capacity of the system? Is there any sure way to know I've flushed out all(most) of the old fluid and have the new one in.
I've just done a bleed and the old fluid wasn't dark and although I removed a few air bubbles at the front(hardly any at the rear), the lever isn't any stronger than before.
I've used about 3 * the fluid in the rear reservoir and 3* the front reservoir at each nipple at the front(left, right, master). All in all about 300ml of brake fluid.
Just asking because now that it's done it seemed too easy.
Oh, and I see that some guys remove the rubber thingy from inside of the reservoir? And when refilling, I fill till just above the LOWER line so that after installing the rubber seal and close it up, the level shows just below the upper line, ye?
NwcCBR is offline
post #10 of 32 (permalink) Old 05-29-2010, 07:13 PM
Images: 17
You should have a color difference right? I just keep bleeding until the fluid color from the caliper is close enough to the fresh brake fluid.
And I fill all the way up to the top line. The rubber seal won't cause your fluid to spill out when you put it back in.
ApexChasing is offline
post #11 of 32 (permalink) Old 06-01-2010, 02:30 AM
xHECKSHERx's Avatar
You can tell your brakes are done bleeding when there isn't any air bubbles coming out of the lines anymore when pumping the brake levers. Also you should feel a good amount of pressure on the levers now when bled right. You will know what I'm talking about if you emptied all the fluid.
03' 600rr- sold
07' 600rr-
sold
05' 636- sold
Currently searching
post #12 of 32 (permalink) Old 08-10-2010, 03:48 PM
tab112302's Avatar
I just replaced all the brake fluid in my bike. Thanks to the help I found in this forum I realized it is much easier than I thought. I also can't believe the difference it has made in my braking ability. I will be changing my brake fluid more often than the 2 year / 12000 mile recommendation due to the high humidity here. When I looked at the fluid in the reservoir I saw there was water in it and it was much darker than new fluid, that's when I knew that that was why my brakes were feeling spongy. Not anymore though, thanks again.
tab112302 is offline
post #13 of 32 (permalink) Old 01-11-2011, 12:29 PM
Location: from miami FL stationed in yakima, washington
on the front brakes does it matter where you start? is there any specific order?
Curbstomp1006 is offline
post #14 of 32 (permalink) Old 01-11-2011, 01:18 PM
crashkid85's Avatar
start at the top on the master...then i normally go right caliper then left..then all over again, like the vid on this thread shows
07 CBR600RR
crashkid85 is offline
post #15 of 32 (permalink) Old 01-12-2011, 02:48 AM
thanks crash
post #16 of 32 (permalink) Old 01-13-2011, 03:37 PM
BOTM Winner 03/13
Sun-Zoom-Spark's Avatar
Images: 175
Correct me if I'm wrong but there isn't a bleed nipple on the stock m/c of an '05-'06 RR is there? There certainly isn't on an '03 anyway.
It's just a case of bleeding each caliper. If you're running stock lines then you'd want to go right caliper first then left; top down (with stock lines, the right caliper feeds the left one). With the 2 line setup it'd be whichever line comes from the m/c first, then the other.
I can highly recommend giving the calipers a full overhaul now and then too though. Did mines just before the winter and, although they aren't perfect, it made a hell of a difference!
Sun-Zoom-Spark is offline
post #17 of 32 (permalink) Old 01-13-2011, 03:41 PM
BOTM Winner 03/13
Images: 175
Sorry, just noticed it's an '05 1Krr that curbstomp has; and an '08 600rr.
post #18 of 32 (permalink) Old 01-13-2011, 06:31 PM
crashkid85's Avatar
i know my 07 has one at the master, cant speak for the previous years tho
07 CBR600RR
post #19 of 32 (permalink) Old 10-07-2013, 06:04 AM
clx
bump (sorry).
wont the air move up in the line, thus id have to pump quite a bit to get all the air out. so if i don't see bubbles initially i need to keep going?
2005 600rr 36300km
2001 Isuzu kb 320 V6 LX double cab 212000km
clx is offline
post #20 of 32 (permalink) Old 02-21-2015, 07:38 PM
If you want a quick way to bleed front brakes on a CBR600 definitely go to Sportbike TrackGear .com. Quick and easy-one person operation.
dragontailjunkie is offline
post #21 of 32 (permalink) Old 02-21-2015, 10:37 PM
mran556's Avatar
Just a fyi brake bleeding sucks imo.. id rather adjust my valves!. I just always feel like theres some air left in the system. Reverse bleed is an option too. Seems much better imo buy ive never done it.
2007 Cbr600rr Black
mran556 is offline
post #22 of 32 (permalink) Old 02-21-2015, 11:09 PM
flush and bleeding is simple and quick with a vacuum bleeder......
think it took an less than an hour for front and rear
tary preisser is offline
post #23 of 32 (permalink) Old 02-22-2015, 02:20 PM
Rad Rage's Avatar
I bled two reservoirs worth of brake fluid, one through each caliper the old fashioned way, never had a problem at the lever. It really isn't too difficult even if you are doing it solo.
2011 CBR600RR 'X-Ray' Build Thread
http://www.600rr.net/vb/176-rr-other-brands-bike-build/294795-rads-600rrb-x-ray-build-thread.html
Co-President of Team46
"My bike is too fast for the track" Ubercool ZX-14R rider.
Rad Rage is offline
post #24 of 32 (permalink) Old 02-22-2015, 04:51 PM
kfox's Avatar
I replace my brake fluid a few times a year (x2 track bikes), plus I bleed them after every other track weekend (so about 6-8 times a year x2 track bikes). Always a pain, until I found these - http://www.ebay.com/itm/221606621426...%3AMEBIDX%3AIT.
Now I can do it one-person and relatively quickly. They also included pretty easy to understand instructions.
I don't typically endorse products, but this one is damn good.
CMRA #914
2009 CBR600RR (parting out)
2012 CBR250R (track)
2012 CBR600RR (track)
kfox is offline
post #25 of 32 (permalink) Old 02-22-2015, 06:56 PM
what do those exactly do or make easier than doing it w/ a kit or any other way? i have to bleed mine but going to do it friday so gotta make sure have all the supplies ready
Basslake20 is offline
post #26 of 32 (permalink) Old 02-23-2015, 10:31 AM
kfox's Avatar
These tools allow you to use the brake lever to pump out the air, or flush the system. There's a ball valve that suits right next to the nipple, so when you pump the brakes air or fluid is forced out but air can't get back in. Slicker and easier than having to create suction with another tool.
Also, the wrench is part if the same tool, so you don't have to deal with both a wrench and a diction kit.
Again, this just makes bleeding easier, not better. But if you don't yet have the tools and/or you will do this single handed a lot, these are the way to go in my experience.
kfox is offline
post #27 of 32 (permalink) Old 02-23-2015, 01:43 PM
ya I've been trying to do a little research and videos before so i kinda know what I'm in for, its going to be my first time doing it so i might just pick up that tool if i can get it shipped here in time looks like its out of stock atm
post #28 of 32 (permalink) Old 02-23-2015, 02:56 PM
kfox's Avatar
Do a google search of Motion Pro Brake Bleeder Tool - it's available in a lot of places. Or buy direct - http://www.motionpro.com/motorcycle/..._mini_bleeder/. Cool video at the link also.
CMRA #914
kfox is offline
post #29 of 32 (permalink) Old 02-23-2015, 10:51 PM
OzHonda's Avatar
Brake bleeding is simple. Connect hose from nipple, into bottle. Pump fluid through, top up, don't let any air in. Couldn't be easier.
Ride carefully - You are invisible.
FB | YT
Current: 2003 CBR600RR - Fuelly
Sold: 2012 CBR250R
Mods:
OzHonda is offline
post #30 of 32 (permalink) Old 02-25-2015, 10:59 AM
I'm just naturally a over cautious /prepared person lol
Human Verification
