oil pan gasket? - 600RR.net
Maintenance Maintenance advice and questions are here
post #1 of 12 (permalink) Old 11-23-2011, 07:20 PM Thread Starter
oil pan gasket?
had to removed my oil pan to patch a hole. now thats it has been patched and ready to install, needing to know if theres a specific gasket for the oil pan?
much appreciated!
omgLOL is offline
post #2 of 12 (permalink) Old 11-23-2011, 07:25 PM
caRRot's Avatar
was there one to begin with lol?
what year is your bike?
WhatWouldCaRRotDo? that. just. happened.
caRRot is offline
post #3 of 12 (permalink) Old 11-23-2011, 08:20 PM
-Rizzo-'s Avatar
Feedback Score: 26 reviews
There's a crush washer isn't there?
03 600RR, 07 Jeep Wrangler Sahara & 14 Subaru WRX
(Lapeer,
MI)
September 2012 BOTM Winner
My Build
-Rizzo- is offline
post #4 of 12 (permalink) Old 11-23-2011, 08:47 PM
Bullast's Avatar
Images: 19
Feedback Score: 10 reviews
A crush washer on the oil pan?
OP,
If the old gasket isn't torn up it'll be fine to reuse.
Bullast is offline
post #5 of 12 (permalink) Old 11-24-2011, 10:25 AM Thread Starter
i have a 2006. i cant tell if its rtv or an actual gasket. i could use rtv, but i rather use a gasket if there is one?
omgLOL is offline
post #6 of 12 (permalink) Old 11-24-2011, 11:44 AM
-Rizzo-'s Avatar
OP,
Woops I was talking about the oil bolt. Brain fart
(Lapeer,
MI)
My Build
-Rizzo- is offline
post #7 of 12 (permalink) Old 11-25-2011, 11:16 PM
Nico's Avatar
It looks like RTV because it is... there is no gasket. Just use permatex ultra grey on it...
Nico is offline
post #8 of 12 (permalink) Old 11-25-2011, 11:41 PM
Feedback Score: 6 reviews
or rtv black. thats what i've used on my s2k and bike
'12 CBR1000RR - Streets
'09 ZX6R - Track only
Rinzler is offline
post #9 of 12 (permalink) Old 11-26-2011, 06:04 PM
02gsxxr's Avatar
Feedback Score: 7 reviews
yea clean the surface with brake clean and apply a small amount of RTV let dry for a couple mins and fill back up and ride
02gsxxr is offline
post #10 of 12 (permalink) Old 11-26-2011, 06:55 PM
Bullast's Avatar
Images: 19
RTV should have a good 24 hours to dry before running hot engine oil through the motor. Last thing you want is RTV balls in the motor.
Clean the surface areas well and apply a uniform bead. Tighten the bolts a little bit and let it dry as recommended on the tube. Torque to spec and let it sit for the 24.
Fill it with oil and ride. Hope it works for you.
Tasha
Phatty
Super Sic
FOR SALE
05/06 OEM Body Parts (Red/Black) Price Drophttp://www.600rr.net/vb/showthread.php?t=468281
Track Day/ Race Gearhttp://www.600rr.net/vb/showthread.php?t=470449
Leupold 1" Unimounthttp://www.600rr.net/vb/showthread.p...66#post6155866
Bullast is offline
post #11 of 12 (permalink) Old 11-26-2011, 07:25 PM
Nico's Avatar
There you are again with advice on saving time, but doing the job wrong. It may be fine to do it that way when you know exactly how much sealant to put on but remember that anybody that is asking the question will not have the experience to get it right. They are almost certainly going to put way to much on.
OP: As Bullast said, thin bead, throw it on with the bolts a little over hand tight, give it a few hours to flash off then torque it up to spec and let it set overnight.
Nico is offline
post #12 of 12 (permalink) Old 11-26-2011, 09:10 PM
You will need to remove old gasket sealant from both the surfaces. Oil pan and its mating surface on the engine block. You will not be able to do it in 10 minutes. How successfully it will seal will depend on how well you clean the surfaces. If you do not clean the surfaces, then the new sealant will not seal properly. Take your time and do it right. You will have to use something like steel wool to make the surfaces look almost brand new. Or, you will have leaks again. Good luck.
sportsluvr is offline
Human Verification
