I just installed a Brembo RCS on the stock clip-ons.
As I'm sure, most of you already know about the adjuster hitting the dash when the bars are turned all the way to the left.
If I were to get a set of Woodcraft 48mm clip-on with no rise, will this fix the issue?
some guys that run the rcs with the stock setup just dont go lock to lock, that just means that 3 point turn becomes like 5 or 6. Thats what i did before my bike had track glass.
I'll try and get a pic after work. All I did was buy a ladybird bracket to hold the brake fluid resivour out of the way. The rcs never hit my fairings just the resivour
Yeah true on not needing to go lock to lock on a track bike, however what I did was add well weights to the limiters so I wouldn't damage anything while going lock to lock.
I have brembo MC with woodcraft 1.5" rise with slight issue at full lock to the left, but had the no rise before with no issues. Riding position is the reason I went to risers. I bet 1" risers would be tits...
Another option is get tape weight's like used to balance wheels and use them as stoppers.
I ordered a standard set of Woodcraft 48mm clip ons and the Brembo RCS adjuster no longer hits the dash. BUT, the stock clip ons have a 1" rise so the standard Woodcraft's allowed very little clearance with the ram air covers.
I will exchange them for 1" rise clip ons and see if that will make the difference. I'll report back with my findings.
Hope this thread helps out anyone whose looking for a solution!
We had the same problem when we bought our backup endurance bike
Bought an 19x18 so both the A & B bikes have same parts
Since levers are different we have to stock fewer parts for crash repair running same MC on both bikes
PLUS the friggin RCS doesn't bump the speedo !
You can set the RCS up with clip-ons to not hit but if you crash & bend the upper fairing stay you could be in trouble with the RCS hitting again
My advice - sell it & buy a 19x18 !
spend the money saved on clip-ons
Oh - it's also easier to run the TMV (brembo style) remote lever adjuster on the 19x18 on our vintage 600RR's
No room for it with the RCS
Related Threads
Honda CBR 600RR Forum
3.9M posts
92.7K members
Since 2003
