FI code help - 600RR.net
post #1 of 6 (permalink) Old 05-09-2009, 07:56 PM Thread Starter
FI code help
I replaced the Pair valve with the block offs... and put on some new velocity stacks.. now i'm throwing a FI code.. how can i research this to find the problem ?
Also i was going to install my HRC 1/6th turn... anyone have a how to ? i can figure out how to get the bottom cable off
looking at next years options
ckyhimself is offline
post #2 of 6 (permalink) Old 05-09-2009, 08:26 PM
**Miss O'Seven BOTY 2011**----- Triumph for Tarek
Moeman's Avatar
Images: 647
Feedback Score: 148 reviews
There's a "test plug that you need to ground, and count the flashes of the FI light. The plug is under the seat, right side of the bike, near the ECM , at the right rear of the battery. There are 2 wires to the plug, and you need to jump them, then turn the key "on", with the kill switch on "run".
If there's a code, the FI will flash your code(s). Count the flashes.
There's long blinks amd short blinks.
Long = 1.3 seconds
Short = .5 seconds
If you have a long blink, the 3 short ones.....that's 13.
A long blink = 10
A short blink = 1
9 short blinks = 9....and so on.
Let us know....
CODES:
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
Honrary Chairman
Deafet may serve as well as victory to shake the soul & let the glory out
A great deal of intelligence can be invested in ignorance when the need for illusion is deep
Moeman is offline
post #3 of 6 (permalink) Old 05-10-2009, 01:30 AM Thread Starter
awsome thanks :) i'll do that tomorrow if its not raining.. i'll post results :) and see where i can go from there
post #4 of 6 (permalink) Old 04-27-2010, 03:34 AM
Ok, so I know this thread is kind of old, but it helped me out a lot just now, thought I'd update with a few pictures to help out someone else if they need it!
The throttle varied +/-500RPM and would cut on the freeway when engine breaking. Gave Code #1 to start with and then later Code #2.
The problem I had is First the Map sensor was not plugged in correctly and giving a code #1, but after that was plugged back in it was throwing a code #2. This turns out because there was a vacuum hose that was not reconnected. It comes off of the throttle bodies and connects to the bottom of the MAP sensor (right lower side of the air box, 3pin and black)
Map Sensor Location
Where the throttle bodies are and where the Map Sensor Vacuum hose should be near
The vacuum hose
Well I hope this helps SOMEONE!!
CorollaGTX is offline
post #5 of 6 (permalink) Old 04-30-2012, 03:30 AM
Did helped a lot thanks! my hose was in but bent so much it was blocked :)
kadimka is offline
post #6 of 6 (permalink) Old 05-30-2012, 06:50 PM
thanks.. that was exactly my prob.. tedious but easy
mettler is offline
Human Verification
