Brake light doesn't work - Page 2 - 600RR.net
post #31 of 54 (permalink) Old 01-13-2010, 03:34 PM
BeeRanDen's Avatar
Images: 3
I have this problem now..... I unplugged the Front and the Rear brake plugs and the tail light is still bright
Any help will be greatly appreciated
I was thinking i need to replace the front switch but when I unplugged the plug the light was still bright
BeeRanDen is offline
post #32 of 54 (permalink) Old 01-13-2010, 03:35 PM
ccs907's Avatar
and you checked the rear brake switch for proper adjustment?
ccs907
ccs907 is offline
post #33 of 54 (permalink) Old 01-13-2010, 03:52 PM
tripage's Avatar
Feedback Score: 91 reviews
Those that are having this problem.. Remove your front brake lever and reset the plastic pin "switch" sounds like the levers were removed and not put back in properly and the switch is being held closed..
tripage is offline
post #34 of 54 (permalink) Old 01-13-2010, 04:22 PM
BeeRanDen's Avatar
Images: 3
Yea i have... took the whole thing off still nothing....thanks tho i thing the switch is the problem
Even if the front and rear plugs are unplugged this "switch" will still cause the brake light to light up..... Thanks
!!!!!MotoSykes UP!!!!!
post #35 of 54 (permalink) Old 01-13-2010, 04:51 PM
tripage's Avatar
If you are unplugging the switches and you still have brake light then you have a wiring problem. You are bypassing the switches and finding out the taillight is the problem..
tripage is offline
post #36 of 54 (permalink) Old 01-13-2010, 05:27 PM
BeeRanDen's Avatar
Images: 3
coo... Thanks T
post #37 of 54 (permalink) Old 01-14-2010, 02:32 PM
BeeRanDen's Avatar
Images: 3
ok so i took the front brake switch completely off the bike and still the light stays on. Rear switch is completely off as well. tail light stays the same. :(
could it be a faulty tail light ?? Its brand new off egay
post #38 of 54 (permalink) Old 01-14-2010, 02:45 PM
LucifeRR06's Avatar
My CA light plain out died.
Jardine RT-1 Dual Outlet Carbon Race Slip On
Vortex 520 conversion -1/+2
RK Gold Race X-Ring chain
Power Commander 3
Shogun Frame Slider Complete Kit
Proton Flushmounts
CA Smoked Integrated Tail Light
CBR Heaven USA F/E
Keiti "Grim Reaper" Tank Pad
Keiti "Grim Reaper" Gas Cap Pad
Reflective Red Rim Stripes
Originally Posted by Jim Moore View Post
OTOH, if you try to be the tough guy and it gets out of control, a few years from now you may be thinking, "Man, prison still sucks. I hope I don't get boned in the ass again today."
LucifeRR06 is offline
post #39 of 54 (permalink) Old 01-14-2010, 02:54 PM
tripage's Avatar
CA lights are known for the ground wire coming off the board. No relief strain on the wiring. Solder can pull off the board. T
tripage is offline
post #40 of 54 (permalink) Old 01-18-2010, 02:41 PM
BeeRanDen's Avatar
Images: 3
Got it working. I had to cut the stock connector and rewire. So much for plug and play
Thanks for the help tho T
post #41 of 54 (permalink) Old 01-18-2010, 02:54 PM
tripage's Avatar
Had the pins wrong on the plug... Missed that one.. Glad you got it... T
tripage is offline
post #42 of 54 (permalink) Old 02-21-2010, 05:53 PM
Victor1702's Avatar
Having the same problem now...
Victor1702 is offline
post #43 of 54 (permalink) Old 02-25-2010, 02:11 AM
me too lol
i changed battery today and thought that i touched or disconnect a wire or something
now i read the thread i couldve been riding like this the whole time :(
kboy_CBR is offline
post #44 of 54 (permalink) Old 02-25-2010, 02:16 AM
rear noob question
whats a rear set?
kboy_CBR is offline
post #45 of 54 (permalink) Old 02-27-2010, 06:40 PM
SLAPS808's Avatar
Feedback Score: 56 reviews
Originally Posted by kboy_CBR View Post
rear noob question
whats a rear set?
the whole footpeg assembly on the left and right side of the bike,
that you rest your feet on when you ride. those are referred to as rear sets.
SLAPS808 is offline
post #46 of 54 (permalink) Old 02-27-2010, 08:53 PM
ahh thanks
anyways my problem was the the spring was not connected to the rear brake pedal
but when i grab front brake lever, light does not come on
do you guys think its the switch issue?
kboy_CBR is offline
post #47 of 54 (permalink) Old 02-27-2010, 10:57 PM
SLAPS808's Avatar
ahh thanks
yea its a switch problem. the switch to which the rear brake spring is attached to, can be adjusted.
SLAPS808 is offline
post #48 of 54 (permalink) Old 02-27-2010, 11:12 PM
thanks guys
i will take a look at it tomorrow
kboy_CBR is offline
post #49 of 54 (permalink) Old 03-11-2010, 02:24 AM
Just want to share my experience. i had the same problem with the brake light staying on all the time even after i disconnected both switches.
After taking the whole bike part i find out i made a very stupid mistake.
While installing my brake lever i pinched the wires for the front brake switch keeping the brake on all the time.
Maybe this will save some of you the trouble it caused me!!
zafar is offline
post #50 of 54 (permalink) Old 12-03-2012, 05:20 PM
miakae's Avatar
I just wanted to chime in and thank all of you for these types of threads. Saved me a major headache because I thought I had some faulty wiring somewhere (high sided a few months ago) since my rear light would stay on even with the front brake disconnected. Turns out the brake spring on the right rearset that I replaced wasn't adjusted correctly.
miakae is offline
post #51 of 54 (permalink) Old 05-27-2015, 03:39 PM
im having a problem where when i grab my front break, my break light just flashes on really quick then just turns off... i find that if i grab my break ever so slightly and hold it, the break light will stay on, but once i squeeze or put any more pressure on the break, the light turns off. any ideas???? rear break works fine.
jefftripz is offline
post #52 of 54 (permalink) Old 05-28-2015, 04:29 AM
Images: 30
Bad switch or aftermarket lever non compatible with brake switch I am guessing... I have a flickering brake light which for some time used to be steady after I switched lever to cheap chinas..my lever return spring also has weakened so it could be that...I didn't get around to fixing it though....
2009 cbr 600rr
sameh90 is offline
post #53 of 54 (permalink) Old 05-28-2015, 02:20 PM
ok cool, thanks. gonna look into the switch. thanks!
post #54 of 54 (permalink) Old 06-08-2015, 12:47 AM
BOTM Winner 10/16
George Type-S's Avatar
Originally Posted by SLAPS808 View Post
check your rear brake switch position.
Thanks for the info! I had a brake light issue and I thought it was related to my yellow box ground issue, turns out it was the rear brake switch.
Lots of good info in this thread!
George Type-S is offline
Human Verification
