RPM's hanging up/ lack of engine braking - 600RR.net
post #1 of 54 (permalink) Old 09-01-2010, 12:57 PM Thread Starter
RPM's hanging up/ lack of engine braking "Now w/ Video"
My 07 600rr has been having an issue of hanging up sometimes. more noticeable when its hotter out but it still doesn't do it all the time. no FI light. no modifications. 34K miles on it. suggestions? things to check or look for?
Thanks
Slickrick592 is offline
post #2 of 54 (permalink) Old 09-01-2010, 01:09 PM
Demented
Posts: n/a
What is this hanging up? Need more details.
post #3 of 54 (permalink) Old 09-01-2010, 02:08 PM Thread Starter
by hanging up i mean that i let off the throttle and the rpms stay about the same and very very slowly come down. and there is no engine braking at all. i've checked to see if the cable is binding and its not. if i pull in the clutch the rpms drop right back to idle, revs just fine. i can try to get a video of it if need be but its always kinda hit or miss. sometimes as it slowly comes back down i'll feel the engine braking kick in and out a bit like it'll kinda hiccup.
post #4 of 54 (permalink) Old 09-01-2010, 02:25 PM
Fulton16's Avatar
To much oil?
2008 600RR - Orange/Black
Mods:
Two Bro's Exahust
K&N Filter
Black "Zero Gravity" Wind Screen
Flush Mount Front Blinkers
Custom Tail Light/Running Light
Custom Rear Blinkers
Heat Sheild Delete
Rear Brake Res Relocation
Fulton16 is offline
post #5 of 54 (permalink) Old 09-01-2010, 02:31 PM Thread Starter
doubtful, its been doing this on and off for months.
post #6 of 54 (permalink) Old 09-01-2010, 04:25 PM
Demented
Posts: n/a
When you turn the throttle to WOT, does it snap back to full closed with no resistance?
post #7 of 54 (permalink) Old 09-01-2010, 04:26 PM Thread Starter
yes the throttle snaps back without resistance as it should
post #8 of 54 (permalink) Old 09-01-2010, 04:31 PM
Demented
Posts: n/a
Are you in a high or low gear when this happens? All maintenance has been done like checking valve clearance, etc?
post #9 of 54 (permalink) Old 09-01-2010, 05:11 PM Thread Starter
it happens in all gears
i'm due to check the valves again but they were good at 15k and i've been keeping up with all maintenance
post #10 of 54 (permalink) Old 09-14-2010, 09:33 AM Thread Starter
bike finally started doing it again yesterday and i was able to get a few videos. not the greatest vids but you can hear what the bike is doing and you can see the tach as well. i took 3 small vidoes. some show the problem better than others but heres the links.....any new ideas?
http://s4.photobucket.com/albums/y13...t=IMG_0367.mp4
http://s4.photobucket.com/albums/y13...t=IMG_0366.mp4
http://s4.photobucket.com/albums/y13...t=IMG_0369.mp4
post #11 of 54 (permalink) Old 09-14-2010, 02:07 PM
Demented
Posts: n/a
You haven't changed the gearing on the bike? What gear were you in when filming?
post #12 of 54 (permalink) Old 09-14-2010, 03:08 PM Thread Starter
it happens in all gears, 2 of those videos where in a higher gear and the one was in a parking lot
and i jumped to an assumption you meant gears 1-6 but the bike is regeared +1/-1 i forgot to mention that
post #13 of 54 (permalink) Old 09-14-2010, 03:12 PM
Demented
Posts: n/a
Well, engine braking works differently depending on the speed and the gear you're in. Yeah, the RPM's are hanging, but hard to know by how much without knowing the speed and gear, or if the gear ratio was changed.
post #14 of 54 (permalink) Old 09-14-2010, 03:22 PM Thread Starter
ok well why is it that it only does it from time to time? like i sat in traffic yesterday and during down shifting and slowing and stopping it was doing it and engine braking was nonexsistent and then later that day doing the same exact thing it was fine? i understand that the amount of braking will be different but in the vidoes posted it is not there at all.
post #15 of 54 (permalink) Old 09-14-2010, 03:31 PM
tenjin's Avatar
vaccume leak?
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #16 of 54 (permalink) Old 09-14-2010, 03:35 PM
ProWakeskater's Avatar
this is a pretty unique problem... wish I could provide some insight. Im thinking its a sensor going bad... good luck
ProWakeskater is offline
post #17 of 54 (permalink) Old 09-14-2010, 03:39 PM
Demented
Posts: n/a
That's what's hard to figure out without knowing all of the factors. Only thing I can think of without more info is that the PAIR valve is being stuck fully open.
post #18 of 54 (permalink) Old 09-14-2010, 04:25 PM Thread Starter
i'm gonna pull the tank hopefully this weekend and check all the hose's and the pair valve. i thought pair initially but then wasn't so sure because of it only doing it during hotter days. i'll let you guys know what i find
post #19 of 54 (permalink) Old 09-18-2010, 08:08 PM
I am having this same issue with my bike. 07 600rr. Still can not find what the problem is.
joey rocket is offline
post #20 of 54 (permalink) Old 04-19-2011, 02:19 PM
I have the same exact problem with my bike- 2007 cbr600rr any body fix this yet?
vwcbr is offline
post #21 of 54 (permalink) Old 04-19-2011, 05:48 PM
Well thought i had it fixed. tucked the PCIII wires up under the tank so that they were not picking up any voltage from ant power wires. Worked for about 4 rides worth and its back again. This time it happened when I stopped to fill up for gas.... then it went away once my fel level got down to about 3/4 full?!? No idea now. Help please.
post #22 of 54 (permalink) Old 04-19-2011, 06:15 PM
Is your FI light on when it has this problem?
vwcbr is offline
post #23 of 54 (permalink) Old 04-19-2011, 07:03 PM
salsaleh's Avatar
i have the same issue, 06 600rr 25k km, does it in bad weather conditions only, (dusty, hot, humid, etc), after riding for at least half an hour
top speed becomes 110kph in sixth gear
stock, just slip on
i read on one of the threads that it cud hav to do with the tcp (throttle body) sensor
when on neutral, revving the engine at first would feel normal, but after a while rpm wud reach 10k nd then max at 7k
kill engine and switch bike on right after and it revs to 15k normally, which IMO could suggest that it is a sensor not a mechanical issue
bike is at a local bike shop, checking my injectors
i sent it to honda for service and they told me it was perfectly fine, idiots...
hope we find a solution to this issue
salsaleh is offline
post #24 of 54 (permalink) Old 04-19-2011, 10:51 PM
no idiot lights. PCIII reads 0% throttle position.
post #25 of 54 (permalink) Old 04-20-2011, 10:53 AM
Nico's Avatar
Do you guys want to create your own threads, and describe exactly what your symptoms are... makes it a LOT easier to keep track of the various issues people are having :)
Nico is offline
post #26 of 54 (permalink) Old 07-27-2011, 11:09 AM
I am havin the same issue, anyone every figure this out??
Go Big or Go Home
bmmballer07 is offline
post #27 of 54 (permalink) Old 04-06-2012, 02:59 PM Thread Starter
I am still having the issue from time to time and have not found a good solution yet. I was planning on doing a tear down here soon for maintenace again as i'm at about 45k now and want to check the valves again. I'm thinking i might block off the Pair system. There is NO FI light on at all when this happens but it really only happens during warmer days 75+ and its not every time but its a pretty regualr occurance. i've also noticed it sometimes happens after i'll restart the bike after running into a store real quick. sometimes it goes away on its own and others it just never goes away until after it fully cools down.
post #28 of 54 (permalink) Old 04-06-2012, 03:02 PM
I resolved the issue by replacing the throttle body. Apparently the guy who had it before me messed with the fuel ratio screws on the throttle body. Inside each valve there is a screw that adjust the amount of fuel and air I believe and that jacked up the idle on the bike. After I replaced it, it has run like a champ for over a year!
Go Big or Go Home
post #29 of 54 (permalink) Old 04-06-2012, 03:03 PM
Or it was a bad IACV. I checked it also but couldn't get any different results. Afterwards I was able to get one on ebay for $75
Go Big or Go Home
post #30 of 54 (permalink) Old 04-06-2012, 03:37 PM Thread Starter
I am the only owner of my bike since brand new out of the crate. and i have never messed with anything on the throttle bodies.
Human Verification
