Limp gear shifter. What did I do ** Don't tap the Shifter Arm ** - 600RR.net
post #1 of 16 (permalink) Old 09-02-2010, 11:36 PM Thread Starter
My bike has 24k kmhs on it now and the chain and sprockets are getting a little tired. Tonight I wanted to better inspect the front sprocket and in order to pull the front sprocket cover off I had to remove the shift linkage. I loosened the pinch bolt on the gearshift arm and even after removing the bolt completely the gear shift arm would still not budge so I resorted to a small puller, which did the trick nicely.
After inspecting the sprocket I started putting it all back together. Since the gearshift arm was stiff coming off it was stiff putting back on so I grabbed a small hammer and started tapping it on. As the gearshift arm (#1, see below) was half on I noticed the gearshift spindle (#3, see below) was now pushed about 1/2 inch further into the motor and the gear shifter was completely limp. I then pulled the gear shift spindle back out 1/2 an inch and the gear shifter felt 'normal' again, I then pushed it back in and it went limp again (just floats up and down, makes no contact with anything).
So now this gear shift spindle freely moves in and out of the motor 1/2 an inch where as it never did before. When its pushed in it spins freely, when its pulled out (normal) it shifts fine.
I did some research on line with shop manuals and put together what I think might be happening below. I suspect the Setting Plate (#2, see below) is either bent or broken, or possibly the bolt that holds it is gone. I have no idea though, just a guess.
Anyone seen this before? What the hell did I do!?
ID:	16871   Click image for larger version
tylerwaugh is offline
post #2 of 16 (permalink) Old 09-02-2010, 11:41 PM
tenjin's Avatar
you now get to take the clutch side engine cover off, behind the clutch basket, there is a small metal tab that is now bent from the shift rod thingy being tapped back
replace said piece and your golden.
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #3 of 16 (permalink) Old 09-02-2010, 11:42 PM
tenjin's Avatar
oh ... durp, yea, you did you reasearch, and found your own problem, now to replace it.
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #4 of 16 (permalink) Old 09-03-2010, 12:11 AM
Demented
Posts: n/a
That is reason #1 why you do not bang on the shifter rod. The metal plate in there is very fragile and likes to bend.
post #5 of 16 (permalink) Old 09-03-2010, 12:25 AM
Lifetime Premium
Darke99's Avatar
Images: 8
Can I ask a question, did you take the bolt all the way out of the linkage before trying to remove the linkage, or did you just loosen it? If you didn't take the bolt out, that would explain why it is/was so tight.
2006 600RR for the track. 2011 Merida OneTwenty for the dirt!
And for those on Google+ gplus.to/Darke99
Darke99 is offline
post #6 of 16 (permalink) Old 09-03-2010, 12:26 AM
tenjin's Avatar
edzackerly ...
the rod is notched so as long as that bolt doesnt jump out of the linkage, the linkage wont fall off, the bolt must be 100% removed from the linkage.
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #7 of 16 (permalink) Old 09-03-2010, 06:39 AM Thread Starter
Thanks for the replies.
Originally Posted by tylerwaugh View Post
... I loosened the pinch bolt on the gearshift arm and even after removing the bolt completely the gear shift arm would still not budge so I resorted to a small puller, which did the trick nicely...
Yes I removed the bolt completely from the gear shift arm. I am pretty mechanically inclined and thats pretty basic stuff. It was still very tight to slide on so I use a flat hear screw driver between the groove and tapped with a hammer (Before reinstalling) in hopes it would make it slide on easier, still no go.
There was also some locktite on the bolt and that was all over the inner splines of the gear shift arm. I tried removing it but was still stiff to slide on.
The fix doesn't appear to indepth, and I have been meaning to check/replace my clutch plates anyways as the clutch is starting to feel notchy.
Thanks again.
post #8 of 16 (permalink) Old 12-04-2012, 09:26 PM
BOTM Winner 1/13
Nuttynu's Avatar
just wanted to bump this , cause i did the exact same thing as OP did, i will be changing the setting plate out and hopefully this will resolve it.
NOTE: NEVER BANG ON THE SHIFTER ROD WHEN INSTALL YOUR SHIFT ROD LINKAGE, NEVER EVER DO IT
My Ride Report :
-Alaska,The Last Frontier
Nuttynu is offline
post #9 of 16 (permalink) Old 12-04-2012, 09:51 PM
BOTM Winner 11/13
sk33m101's Avatar
Feedback Score: 12 reviews
Make sure you do a write up on how to replace it probably going to happen to someone else along the line
Sent from my SCH-I535 using Motorcycle.com Free App
sk33m101 is offline
post #10 of 16 (permalink) Old 12-04-2012, 11:56 PM
BOTM Winner 1/13
Nuttynu's Avatar
will do, i take much picture and take notes. seems very self explanatory. i also have my manual with me so that helps a ton .
also spoke with another member who did the same thing and he said it was cause of that PLATE, after replacing it , everything was back to normal. much relief now cause i thought i had to drop the whole engine and get to the shift forks. :(
My Ride Report :
Nuttynu is offline
post #11 of 16 (permalink) Old 01-01-2013, 08:23 PM
story028's Avatar
Same thing happened to me. I replaced the chain and sprockets on my bike very recently. Removing it was easy as I remove the bolt entirely. When I was putting it back together my dumb as forget and had the bolt slightly screwed in. I pushed the rod in by hand and sure enough it went limp.
I pulled it back out and it worked normally. Only now when I start the bike it makes a wierd noise when leaned to the left. Everything else works fine. That noise is bugging the hell outta me so I found this. Now here I am.
When nothing goes right... go left
story028 is offline
post #12 of 16 (permalink) Old 01-02-2013, 02:29 PM
I was lucky to not have to pry/tap the shift linkage when I changed my sprockets but as a precaution I put anti-seize compound on the teeth of the shift rod going into the motor so next time it would come off just as easy.
"It sounds like a Ferrari having an orgasm"
Handyman is offline
post #13 of 16 (permalink) Old 01-02-2013, 02:44 PM
SmuRRf's Avatar
Am I glad I read the dotnet.... This is on my todo list and now I will be careful not to be to rough with the gear shifter rod.
CBR600RR(04)
Diablo Rosso Corsa
Yoshi RS5 Slipon
Puig DB
SmuRRf is offline
The Following User Says Thank You to SmuRRf For This Useful Post:
Nuttynu (01-03-2013)
post #14 of 16 (permalink) Old 01-02-2013, 11:31 PM
story028's Avatar
This is why the bolt needs to be completely removed.
story028 is offline
post #15 of 16 (permalink) Old 05-12-2013, 02:17 PM
Images: 30
Omg i might have done this.... While inspecting the drive sprocket i wanted to shift from 1st to neutral put the linkage on.. Gave it a few taps with a cloth and ratchet.. After something like 5 gentle taps it didnt go nd i felt not that rigid axially ...so i just pulled the linkage down to get gear back to neutral.. And removed it ?... I dont remember the the spindle pushed in.. Maybe 1-2 mm max..am i good?
sameh90 is offline
post #16 of 16 (permalink) Old 06-05-2013, 11:28 PM
Did the same thing here but I didn't replace the plate. If I remember correctly a copper pipe fit almost perfect over the rod. So I bought a piece of hard PVC pipe the same size, cut it to size and put a washer on the end so the rod couldn't push in or dig against anything. 12k+ miles later I've had zero problems.
Justjohn320 is offline
Human Verification
