Need Help with bar ends! - 600RR.net
post #1 of 3 (permalink) Old 10-28-2012, 11:59 PM Thread Starter
Owns24's Avatar
I am trying to install bar ends and the receptacle is just spinning... I can't get the screw out...any help would be appreciated.
I never had this issue with my old '04
Owns24 is offline
post #2 of 3 (permalink) Old 10-29-2012, 12:02 AM Thread Starter
Owns24's Avatar
Sorry I realized I posted this in how to...my bad, trying to delete this post
Owns24 is offline
Old 10-29-2012, 11:49 AM
brmoore
This message has been deleted by Moeman. Reason: Spam and/or unwanted content
post #3 of 3 (permalink) Old 11-05-2012, 09:29 PM
If you have alot of trouble you can use something like a strap wrench or channel locks/vise grips and rags to keep from scratching the bar ends.
If they are installed correctly there is a lip on the bar end that indexes with the weights in the handlebars that should keep it from rotating if the bar end is fixed somehow and the screw is turned.
You might find it easier to remove the whole assembly. Peel back the grips at the bar end side and push down on the clip that holds the internal handle bar weight inside the handlebar. Then pull on the weight and disassemble the assembly off the bike. You might need to spray some lubricant in the handlebar to get the assembly out.
07 600RR
Arrow Ti/CF, Protons, Tripage Tail-light and Tag Bracket, Speigler Custom Lines, Puig DB, PCV, 1kRR Monoblocks, CL XBK5 pads...whats next?
WTB - Annitori Quickshifter
Rheology is offline
Human Verification
