06 cbr 600rr headlight problem - 600RR.net
post #1 of 10 (permalink) Old 11-12-2012, 03:26 PM Thread Starter
My 06 600rr headlights will not turn on. I have checked the fuse and the on swithc to make sure the wires were still connected. i also swapped fan relay with headlight relay and still neither turned on. It also wont show the brights light when the switch is on brights. The turn signals will show up on gauge cluster though. I know it isnt the bulbs because i put a paper clip in the harness and got the headlight to turn on but not sure which pin. My tailight also doesnt get brighter when pressing brakes. Even after adjusting the sensors.
blaine0407 is offline
post #2 of 10 (permalink) Old 11-12-2012, 04:29 PM
Is the connection for controls connected???
"It sounds like a Ferrari having an orgasm"
Handyman is offline
post #3 of 10 (permalink) Old 11-12-2012, 06:08 PM Thread Starter
Yes its connected. If i disconnect and jump the blue and black the headlight will turn on so i know its not the bulb. Could the switch be broken just for the lights because the turn signals work. The highbeam light on cluster doesnt come on either
post #4 of 10 (permalink) Old 11-12-2012, 06:13 PM
dreamzboy's Avatar
What was the last electrical thing you've installed on your bike? Some aftermarket parts short out your electrical system.
dreamzboy is offline
post #5 of 10 (permalink) Old 11-12-2012, 06:18 PM Thread Starter
I havent installed any. I just got it a few weeks ago. It has a power commander and none of the lights or anything were on because it was gonna be a race bike. Im more concerened with the tailight right now. It stays lit (both bulbs) even with both sensors unplugged. It is the stock light.
post #6 of 10 (permalink) Old 11-12-2012, 06:45 PM
open up the right control housing and look at the wireing to the starter switch....there have been a few links about the headlights not working because of a wire int he housing...
it's weird the turnsignals work but the brake light doesn't....they are on the same fuse... have you checked all the connections for the tail/brake light?? I know there are 3 or 4 connections back there and I had to mess with mine to get everything to work.
Handyman is offline
post #7 of 10 (permalink) Old 11-12-2012, 07:18 PM Thread Starter
I mean the turn signals show up on the Cluster unlike the light for the brights. I have no turn signals at all plugged in on the bike. All fuses are good though. The brake light fuse was out at first but I replaced it. Could it be a faulty tail light that's making it stay bright? It can't be a short can it, if the light is on?
post #8 of 10 (permalink) Old 11-12-2012, 07:32 PM Thread Starter
Is their a way to rewire rear light, or check with volt meter to figure out problem?
post #9 of 10 (permalink) Old 11-12-2012, 09:48 PM
so you have no turn signals plugged in but the indicator on the dash blinks like you have turnsignals plugged in??
Handyman is offline
post #10 of 10 (permalink) Old 11-12-2012, 11:15 PM Thread Starter
Ya it indicates left and right but I just don't have turn signals to plug In. How would I go about rewirng the tail light without using stock harness.
Human Verification
