No fuel prime and no spark - Page 2 - 600RR.net
post #31 of 52 (permalink) Old 11-19-2012, 11:58 PM Thread Starter
foxracing06's Avatar
Feedback Score: 7 reviews
Tripage and I have come to the conclusion that I should replace the ECM. I will hopefully have it next week.
12 Hayabusa
09 600RR
06 1000RR
03 RVT 1000R RC51 SP2
foxracing06 is offline
post #32 of 52 (permalink) Old 11-20-2012, 12:05 AM
awesome! let us know when it works.
bejbis is offline
post #33 of 52 (permalink) Old 11-20-2012, 12:08 AM Thread Starter
I like your optimism! "When" not "if"
12 Hayabusa
09 600RR
06 1000RR
post #34 of 52 (permalink) Old 11-20-2012, 12:44 AM
Haha, chin up!
The way I see it is you've got another 4 months before you can actually ride the bike when it warms up again.
on a side note, my 07 1krr was much quicker than a buddies rc51. Such a great mount.
bejbis is offline
post #35 of 52 (permalink) Old 11-20-2012, 01:04 AM Thread Starter
I've had a mint/low mileage 06 1000rr a year or so ago and yeah they are MUCH faster than the rc51s. I bought my rc just because I wanted one strictly for the street lol. The sound and look do it for me. My 1krr will definitely see the track and I am sure is much easier to ride faster on as well.
12 Hayabusa
09 600RR
06 1000RR
post #36 of 52 (permalink) Old 11-20-2012, 01:22 AM
As much as i LOVE the rc51, i would never get one as a street bike. its like hanging onto a barrel. from what limited experience ive had on them it felt like it would be at home on a track though.
bejbis is offline
post #37 of 52 (permalink) Old 11-20-2012, 02:03 AM Thread Starter
I couldn't bring myself to put mine on the track. 7k miles with not even a scratch on it. I wouldn't be able to live with myself if I went down with it. On the street I am good on it because I am taller/bigger. Could be a little more comfy though.
12 Hayabusa
09 600RR
06 1000RR
post #38 of 52 (permalink) Old 11-29-2012, 03:27 PM Thread Starter
Well here's my update.
I put a known working ECM from the correct year and still no prime. Also tried a different upper headlight harness with a known good bas and still nothing. I am stumped!
12 Hayabusa
09 600RR
06 1000RR
post #39 of 52 (permalink) Old 11-30-2012, 08:47 AM
tripage's Avatar
Feedback Score: 91 reviews
Is the bas pointed correctly? Key cycled after the wiring has been installed?
tripage is offline
post #40 of 52 (permalink) Old 11-30-2012, 12:03 PM Thread Starter
Yes the bas was pointed correctly and I jumped it as well. The gauges do cycle normally when the key is turned.
12 Hayabusa
09 600RR
06 1000RR
post #41 of 52 (permalink) Old 11-30-2012, 01:44 PM
tripage's Avatar
If you manually trigger the fuel pump relay can you get it to start?
tripage is offline
post #42 of 52 (permalink) Old 12-01-2012, 12:34 PM Thread Starter
I haven't tried but I doubt it considering I don't have spark either?
12 Hayabusa
09 600RR
06 1000RR
post #43 of 52 (permalink) Old 12-01-2012, 12:48 PM
tripage's Avatar
Originally Posted by tuck and roll View Post
Once you get 12v to the f-pump, also check cam and crank signals to the ecm, i believe it needs both for spark and pump prime. A volt meter, connected in parrallel to the two wires at each sensor, on a low AC volts scale, while cranking should read over .7v AC Let us know what you found.
try this.......
tripage is offline
post #44 of 52 (permalink) Old 12-01-2012, 01:43 PM Thread Starter
How would i connect them in parallel? I am new to this and am not understanding how I should have the volt meter connected for the test? I am starting to think it's a bad crank sensor, I just remembered that the bike sat outside for probably a year under a cover and the guy had I believe the crank sensor just hanging outside of the right crankcase cover (it's supposed to be mounted inside it, and now is)
12 Hayabusa
09 600RR
06 1000RR
post #45 of 52 (permalink) Old 12-01-2012, 02:02 PM
tripage's Avatar
I haven't done this, but check the manual for crank sensor troubleshooting. Should say how to check to make sure it's working.
tripage is offline
post #46 of 52 (permalink) Old 12-07-2012, 05:02 PM Thread Starter
Replaced the pulse generator sensor with a brand new Oem one and still nothing. Sadly I think I have two options. Take it in, or part it out.
12 Hayabusa
09 600RR
06 1000RR
post #47 of 52 (permalink) Old 12-07-2012, 05:37 PM
MachRider's Avatar
Images: 8
I didn't look back, but has there been any issue with the kill switch? No spark and no fuel pump is the only thing aside from kick stand that I can think would be a KISS component. (Keep It Simple, Stupid)
EDIT: I see you played with the killswitch... but kickstand? May be easily overlooked and I've seen the push-pin get stuck and cause unbelievable headaches.
93
MachRider is offline
post #48 of 52 (permalink) Old 12-07-2012, 06:00 PM Thread Starter
I did unplug that and I jumped the two wires to eliminate any problem with that. No mil light. It's in neutral.
12 Hayabusa
09 600RR
06 1000RR
post #49 of 52 (permalink) Old 12-10-2012, 12:48 PM Thread Starter
Well I am pleased to tell you that I woke up early this morning and decided to swap out wiring harnesses. When I unplugged the cam sensor I found that the wiring was messed up. I continued to swap harnesses. Turned the key and the pump primed. Hit the ignition and it fired right up. Thanks for all your help guys!!!
12 Hayabusa
09 600RR
06 1000RR
post #50 of 52 (permalink) Old 12-10-2012, 12:54 PM
tripage's Avatar
Glad you got it.
tripage is offline
post #51 of 52 (permalink) Old 12-10-2012, 01:02 PM Thread Starter
You and me both! Thank you again for your help.
12 Hayabusa
09 600RR
06 1000RR
post #52 of 52 (permalink) Old 12-10-2012, 01:55 PM
MachRider's Avatar
Images: 8
Problem solved shortly after I propose a possible solution.
Of course by suggesting kickstand and killswitch, I meant cam position sensor.
Glad you caught on. It's one of those "Don't give the answer, let the grasshopper search for it."
*Insert smiley of choice here*
Happy you found it! Unfortunate you had to pull the harness, but better knowing you've found the problem! I just noticed you have an RC51. You're an alright guy in my book! (I've got an 06)
93
Human Verification
