No fuel prime and no spark - 600RR.net
post #1 of 52 (permalink) Old 11-18-2012, 12:18 AM Thread Starter
foxracing06's Avatar
Feedback Score: 7 reviews
Ok let me start off by saying that I am not troubleshooting a 600rr, but the bike is very similar. (06 1000rr) I am very desperate to figure out the problem, so ANY help will be greatly appreciated. I tried posting on 1000rr.net but have had no help, please 600rr brothers, prove to me for the 100th time why this site is the best!
The information: I bought the bike wrecked. I completely disassembled it and put it back together. It didn't run when I took it apart because I didn't have the headlight harness. I now have it back together and I cannot get it to spark or prime the fuel system. First I bought a new battery because the one that was in it was completely dead.
I put a multimeter on the negative battery terminal to the grounding spot on the frame that has two grounds going to it. It was good.
I tested all of the relays, and they all tested good. (I did this by following the instructions in the service manual.) You can hear it click when you flip the kill switch.
The kill switch is good and was verified with the multimeter.
I jumped the outer wires for the bank angle sensor.
There are no blown fuses.
I replaced the fuel pump because that tested bad. I jumped it and it wouldn't turn on. I also checked for voltage going to it and there was none when I turned the key. New pump when jumped turned on, but still no voltage to it.
The MIL does not blink.
This isn't making sense to me. I am about to buy a different ecm and wiring harness. I am hoping that it is something simple but it's not looking that way. Sorry for the long post, and thanks in advance!
12 Hayabusa
09 600RR
06 1000RR
03 RVT 1000R RC51 SP2
foxracing06 is offline
post #2 of 52 (permalink) Old 11-18-2012, 09:14 AM
tripage's Avatar
Feedback Score: 91 reviews
Check the voltage at the fuel pump with run position on. Just to make sure it's turning on power. kickstand is down/bike in neutral/ Make sure the outer wires are the same on the 1000rr, not sure about the bas on 1000. No power at fuel pump with kickstand up and bas correctly mounted or bypassed next is your relay and your ecm. If you didn't already replace the spark plug. New is always better than used and unknown.
tripage is offline
The Following User Says Thank You to tripage For This Useful Post:
foxracing06 (11-18-2012)
post #3 of 52 (permalink) Old 11-18-2012, 12:00 PM Thread Starter
There is definitely no voltage going to the pump when the key is on and the kill switch is set to run. Kickstand is down and bike is in neutral. Bypassing the bas is the same method on the 1000rr as the 600rr so that's good. I tested all four relays that the bike has, and all tested good per instructions in the service manual. I can try a new plug again but with the no fuel pump prime issue I am guessing it is something else that is giving me no fuel or spark. It sounds like ecu is definitely next. Either way THANK YOU for your help Tri, even if it's stuff I already did any help is a positive towards fixing this.
I am open to any other ideas as well, even if you think it's dumb. You won't offend me! At this point it could really be anything little or dumb!
12 Hayabusa
09 600RR
06 1000RR
post #4 of 52 (permalink) Old 11-18-2012, 12:38 PM
how many wires are coming out of your lock cylinder? is it just two red ones? or does it have 2 red and a small pink?
bejbis is offline
post #5 of 52 (permalink) Old 11-18-2012, 12:56 PM Thread Starter
Just two red ones coming out of the ignition lock cylinder.
12 Hayabusa
09 600RR
06 1000RR
post #6 of 52 (permalink) Old 11-18-2012, 01:14 PM
you may want to bypass the clutch switch and kickstand switch. just run a jumper and connect them together to make sure they are bypassed.
honestly, it sounds like your BAS isnt correctly bypassed.
bejbis is offline
post #7 of 52 (permalink) Old 11-18-2012, 01:28 PM Thread Starter
I just jumped out the kickstand switch, and the clutch switch like you said. Still no prime. I played around with the bas jumper and the second I unplugged one of my leads I heard the relay click off, so when connected again the relay clicked back on. I believe that is telling me that it was correctly jumped, right?
12 Hayabusa
09 600RR
06 1000RR
post #8 of 52 (permalink) Old 11-18-2012, 01:50 PM
yea, sounds like it. I just went through the same problem with my 600rr but mine didnt give me much problems.
are you able to turn the motor over fine? all the gauges and everything works?
bejbis is offline
The Following User Says Thank You to bejbis For This Useful Post:
post #9 of 52 (permalink) Old 11-18-2012, 01:55 PM Thread Starter
The starter motor engages and turns the motor over with no problem. Gauges cycle through like normal. Headlights function normally.
12 Hayabusa
09 600RR
06 1000RR
post #10 of 52 (permalink) Old 11-18-2012, 02:08 PM
tripage's Avatar
If the 1000 is the same as the 600 the ecu is sending a ground to the relay to engage it. Check the relays and get the fuel pump relay and manually trigger it as the ecu does. If it turns on this way then it's definitely your ecu
tripage is offline
post #11 of 52 (permalink) Old 11-18-2012, 02:55 PM Thread Starter
I somewhat understand what you are saying but I am confused on how to execute it. Do I run a ground to a lead on the relay?
12 Hayabusa
09 600RR
06 1000RR
post #12 of 52 (permalink) Old 11-18-2012, 02:58 PM
tripage's Avatar
Guessing you have a 1000rr manual so you can see the wiring? Each relay has different color wires, find the one that is for the fuel pump. In the troubleshooting section it will say how to test the ecu if you are not getting the fuel pump to turn on. You will see the "trigger" wire coming from the ecu to the relay to turn it on. On the 600rr this is a ground. If it's the same on the 1000rr you will turn on the key/run and then run a jumper from the - on the battery to that trigger wire. if your fuel pump turns on your ecu is bad because it's not sending the ground it's supposed to when turned on.
tripage is offline
post #13 of 52 (permalink) Old 11-18-2012, 03:25 PM Thread Starter
Ok I get it. I do have the service manual and when looking at the wiring diagram I cannot find the trigger wire you are talking about. I looked at the ecu troubleshooting and their pin layout is different. The manual is 04-05 and my bike is an 06. People all say the ECM is the same basically though. ::crazy::
12 Hayabusa
09 600RR
06 1000RR
post #14 of 52 (permalink) Old 11-18-2012, 03:28 PM
tripage's Avatar
It doesn't have a full page of wiring layout in the back?
Trace the relay wire back to the ecm.
tripage is offline
post #15 of 52 (permalink) Old 11-18-2012, 03:30 PM Thread Starter
12 Hayabusa
09 600RR
06 1000RR
post #16 of 52 (permalink) Old 11-18-2012, 03:34 PM Thread Starter
I believe it's the br/y wire, so I would ground that lead on the relay and if the pump turns on its the ECM?
12 Hayabusa
09 600RR
06 1000RR
post #17 of 52 (permalink) Old 11-18-2012, 03:38 PM
tripage's Avatar
Hard to see but looks like brown/yellow is the wire you are looking for on the relay.
Look at the relays diagram and check the common wire between them. I am going to guess it's a + but check this with a volt meter before trying it. If it's a + on all three of the relays then the brw/yellow is a negative. You can continuity this with the key on/run on to see if it's a negative.
tripage is offline
post #18 of 52 (permalink) Old 11-18-2012, 03:49 PM Thread Starter
Alright when I jumped a positive from the battery to the brown wire on the fuel pump relay the fuel pump turned on. When jumping it from the positive to the brown/yellow wire, I get the relay to click but no fuel pump.
12 Hayabusa
09 600RR
06 1000RR
post #19 of 52 (permalink) Old 11-18-2012, 03:53 PM
tripage's Avatar
Most likely because either the relay isn't turning on or it's not getting power/ground to turn on.
tripage is offline
post #20 of 52 (permalink) Old 11-18-2012, 03:54 PM Thread Starter
Just edited the last post. When jumped to the brown/yellow wire from ECM the relay clicks but no fuel pump.
12 Hayabusa
09 600RR
06 1000RR
post #21 of 52 (permalink) Old 11-18-2012, 04:01 PM
tripage's Avatar
Sorry, read that wrong. Have you changed the relays? Sounds like it's not turning on because you can bypass it and it works
tripage is offline
post #22 of 52 (permalink) Old 11-18-2012, 04:04 PM
tripage's Avatar
You metered brw/yellow to make sure it's a + trigger?
tripage is offline
post #23 of 52 (permalink) Old 11-18-2012, 04:06 PM Thread Starter
When the relay engages there is 3 volts at the pump. When it is not engaged there is no voltage.
12 Hayabusa
09 600RR
06 1000RR
post #24 of 52 (permalink) Old 11-18-2012, 04:10 PM
tripage's Avatar
If you manually trigger the relay from the battery you are only getting 3 volts?
Doesn't sound like that relay is working properly.
tripage is offline
post #25 of 52 (permalink) Old 11-18-2012, 04:15 PM Thread Starter
I wasn't clear on how to find if the trigger is + or - should I just go buy a relay at the auto store and see if it changes?
12 Hayabusa
09 600RR
06 1000RR
post #26 of 52 (permalink) Old 11-18-2012, 04:35 PM
tripage's Avatar
Hey fox give me a call 352-978-7287
tripage is offline
post #27 of 52 (permalink) Old 11-18-2012, 05:50 PM Thread Starter
Thanks Tri! Really appreciate the help!
12 Hayabusa
09 600RR
06 1000RR
post #28 of 52 (permalink) Old 11-18-2012, 06:20 PM
tripage's Avatar
No problem, that should get you fixed up. T
tripage is offline
post #29 of 52 (permalink) Old 11-18-2012, 06:28 PM
tuck and roll's Avatar
Once you get 12v to the f-pump, also check cam and crank signals to the ecm, i believe it needs both for spark and pump prime. A volt meter, connected in parrallel to the two wires at each sensor, on a low AC volts scale, while cranking should read over .7v AC Let us know what you found.
tuck and roll is offline
post #30 of 52 (permalink) Old 11-19-2012, 05:56 PM
you ever this this thing sorted fox?
would like to know the outcome and what was wrong with it.
bejbis is offline
Human Verification
