vortex rearsets and maybe an issue ?..yikes**Shifter Arm bent as it was taped on ** - 600RR.net
post #1 of 38 (permalink) Old 12-02-2012, 10:32 PM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
Exclamation vortex rearsets and maybe an issue ?..yikes**Shifter Arm bent as it was taped on **
alright so check this out fellas,in the first picture, the gearing pin coming out of the engine, when i install the set, i was able pushed that pin inside the engine like 1/2 inch.. i then couldnt shift...scary
so is this normal or is there something wrong? it then shifts properly when i push it back out tho... never seen or even try this . are your guys like that too? and hopefully i'm making sense..
here is my bad drawing . but this i meant....
now here are they installed...
GP SHIFT
My Ride Report :
-Alaska,The Last Frontier
Nuttynu is offline
post #2 of 38 (permalink) Old 12-02-2012, 10:38 PM
BOTM Winner 8/12 / Super Moderator
CBR Time's Avatar
Images: 45
Feedback Score: 12 reviews
hmm no idea, but mine should be arriving soon, looks good though. Do you remember the play on it w your oem sets?
CBR Time is offline
post #3 of 38 (permalink) Old 12-02-2012, 10:40 PM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
no, not sure, thats why im hoping one of ya can find out. ...ill prolly go start the bike up and maybe let it run thru the gears..\
oh and FYI everyone, there is no issue with the vortex or the installing of it, its i just found that the pin slip inside and im hoping i aint going to get some motor issue..
My Ride Report :
Nuttynu is offline
post #4 of 38 (permalink) Old 12-02-2012, 10:44 PM
CBR Time's Avatar
Images: 45
well mines an 07 not sure if it would be made differently though? bike is stored and covered up :P im sure someone will chime in and let you know, let me check if i have an old pic at least
CBR Time is offline
post #5 of 38 (permalink) Old 12-02-2012, 10:44 PM
TheX's Avatar
Images: 2
Feedback Score: 5 reviews
That should not move like that, did you force the red arm back on (tap on it with something)? This is a common issue when people install rearsets, they tap that arm on and bend the shifter fork.
Im jealous of all the people that haven't met you.
TheX is offline
The Following User Says Thank You to TheX For This Useful Post:
Nuttynu (12-02-2012)
post #6 of 38 (permalink) Old 12-02-2012, 10:45 PM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
Unhappy
..... oh ****...well um i did actually. please tell me im ok.. shoot.
My Ride Report :
Nuttynu is offline
post #7 of 38 (permalink) Old 12-02-2012, 11:25 PM
Dynamic's Avatar
Mine doesn't have this issue and it's the same bike, although I didn't force/tap it on just kinda whispered sweet nothing's to it till it fit.
Dynamic is offline
post #8 of 38 (permalink) Old 12-02-2012, 11:35 PM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
thanks for comirming, well dont tap yours, cause i did to mines and now if i wanted to push it, it will slide into the casing... darmm
hoping its nothing major.... im reading about broken shift forks.. and if thats what i got . its going to be an big
My Ride Report :
Nuttynu is offline
post #9 of 38 (permalink) Old 12-02-2012, 11:49 PM
trackfreak's Avatar
Feedback Score: 10 reviews
Damn!!! Yea dude if you forced it on there like that the shift forks are cheap but the work is crazy pricey as you have to open the motor up. Best of luck man. Keep us updated. I have to do the shift forks on my dirtbike and its a pain I can imagine how it will be on a streetbike. Did you take the bolt completely off before trying to slide the mount in?
you can't buy happiness but having a racebike is close enough!!!
trackfreak is offline
post #10 of 38 (permalink) Old 12-03-2012, 12:07 AM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
dam stupud of me to do that,, well here, ill tell you exactly what i did. dont flame hha,
you all see how the oem rod is red and also the connect pieces is red right?
that cause i painted it. i just dip it on paint , so now the top linkage has an extra few layer of paint that's why it didnt go smoothly like how it should had. thats when i got the mallet and started tapping on it. and all sudden bloop it went in a bit...like 1/2 inch.
i not sure if i should go start it and run it thru the gears..
hopefully it aint a biggy. i just ask my buddy who had and rebuild his R1 this season.. he's saying it cant be that bad as ridng it..well see
My Ride Report :
Nuttynu is offline
post #11 of 38 (permalink) Old 12-03-2012, 12:24 AM
Dynamic's Avatar
I didn't know that piece is so fragile that slight tapping can cause a break. Good luck with the fix.
Side note but what about a temporary fix where you can put something on the end of the rod to prevent it from sliding?
Dynamic is offline
post #12 of 38 (permalink) Old 12-03-2012, 12:26 AM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
well when pushed back out to being normal, i dont think it'll slide in. im just worry about internal damage.
My Ride Report :
Nuttynu is offline
post #13 of 38 (permalink) Old 12-03-2012, 12:35 AM
trackfreak's Avatar
Hhmmm. 1/2 is quite a bit to sink in there. Try and find a diaphragm an see what could cause it to slide it in. Did run through the gears?
post #14 of 38 (permalink) Old 12-03-2012, 12:44 AM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
Haven't run the bike . Maybe in a few days or so.
My Ride Report :
Nuttynu is offline
post #15 of 38 (permalink) Old 12-03-2012, 06:59 AM
CBR Time's Avatar
Images: 45
Ok i was wondering about the Red paint, correct me if im wrong but the new Vortex linkage part that connects to the shift rod is the same as oem right? mine isnt painted, so i can assume that after loosening the bolt it should slide in. I remeber having to remove it for my woodcraft case cover install, when i was done i just slipped it back on (no taping or mallet) anyways i hope it all works out for you man
CBR Time is offline
post #16 of 38 (permalink) Old 12-03-2012, 07:03 AM
CBR Time's Avatar
Images: 45
Wait, does the Vortex Rearsets not come w a new shifter rod?? or did you paint that red?
Edit : after looking at your pic i see the new rod that came w the sets, wasnt sure you had to re use the main rod (your in red)
CBR Time is offline
post #17 of 38 (permalink) Old 12-03-2012, 07:18 AM
CBR Time's Avatar
Images: 45
Ok so reg shift you dont re use oem rod, GP you do im guessing, hondamotorco4life's pic of his Vortex Sets
CBR Time is offline
post #18 of 38 (permalink) Old 12-03-2012, 08:32 AM
^that pic's of V2's
Nuttynu's look like V1's
V2's come with 2 shift rods, you only use one.
Length determined by choice of shift setup.
^the pic of V2's is setup for regular shift pattern.
GP shift pattern would have the shift rod on top for the V2's.
Shoichiro_Honda is offline
post #19 of 38 (permalink) Old 12-03-2012, 10:39 AM
tripage's Avatar
Feedback Score: 91 reviews
The part you messed up is #1 on here.
http://www.ronayers.com/Fiche/TypeID...GEARSHIFT_DRUM
Very thin metal piece. We did this once and won't make this mistake again.
Make sure to take your bolt out all the way before installing the knuckle. Yours might be bend but it also might be broken off. You have to open up the cover, remove the clutch basket and that will give you room to replace this part.
tripage is offline
The Following 2 Users Say Thank You to tripage For This Useful Post:
MikeyP (12-03-2012), Nuttynu (12-03-2012)
post #20 of 38 (permalink) Old 12-03-2012, 11:28 AM
CBR Time's Avatar
Images: 45
Originally Posted by Shoichiro_Honda View Post
^that pic's of V2's
ok thx, i just ordered from Cycle Sector, so i assume ill be getting the V2's then? ill more and likely go w reg shift pattern anyways
CBR Time is offline
post #21 of 38 (permalink) Old 12-03-2012, 11:50 AM
**Miss O'Seven BOTY 2011**----- Triumph for Tarek
Moeman's Avatar
Images: 647
Feedback Score: 148 reviews
Dave
Still addicted to the mods remember I told you a while back modding never seems to cease
Congrats man awesome Rear sets make sure to use Blue Loctite when you asm them together and don't forget to post pictures
Honrary Chairman
Deafet may serve as well as victory to shake the soul & let the glory out
A great deal of intelligence can be invested in ignorance when the need for illusion is deep
Moeman is offline
post #22 of 38 (permalink) Old 12-03-2012, 12:49 PM
v-tec crx's Avatar
OP > from the sounds of it, when you installed the rearsets you used a hammer to put the shift linkage back on the shaft. This is a no no. On the other side of the shaft there is a very thin and fragile retaining washer. You broke/bent that washer unfortunately. and the engine needs to be opened back up to remove/replace that washer.
I am from CANADA, the land of poutine, back-bacon and GOOD BEER!!
2012 STREET BIKE OF THE YEAR
v-tec crx is offline
post #23 of 38 (permalink) Old 12-03-2012, 12:51 PM
CBR Time's Avatar
Images: 45
^@ Moe: haha yup, with "off seasons" what else is there to do? lol and i'm asking for Blue Loctite from the wife for a stocking stuffer :P
CBR Time is offline
post #24 of 38 (permalink) Old 12-03-2012, 12:54 PM
v-tec crx's Avatar
This right here
T to the rescue
post #25 of 38 (permalink) Old 12-03-2012, 12:56 PM
CBR Time's Avatar
Images: 45
Well Nu look at the brigtside dude, at least its NOT riding season; you have time on your hands
CBR Time is offline
The Following User Says Thank You to CBR Time For This Useful Post:
post #26 of 38 (permalink) Old 12-03-2012, 01:23 PM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
Ooo wee tha k you ! Gues I do have time to do this . Lesson learn . Don't hammer that gear pin
Can u explain a little more on what has to be open ? Do I have to drop the whole engine or jus open which casing ?.
My Ride Report :
Nuttynu is offline
post #27 of 38 (permalink) Old 12-03-2012, 01:33 PM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
yeah its a cheap parts, but timing and ...arg working in the cold!!
well ima tear it down and see what internal damage. and do a thread on it so everyone dont make my mistake
My Ride Report :
Nuttynu is offline
post #28 of 38 (permalink) Old 12-03-2012, 01:34 PM
CBR Time's Avatar
Images: 45
Nu have a look at this guys post in 2010, hes in AK as well lol
Clutch basket nut removal????
CBR Time is offline
post #29 of 38 (permalink) Old 12-03-2012, 01:36 PM
CBR Time's Avatar
Images: 45
yeah i hear ya, my bikes in cold storage as well, just get yourself a space heater and a case of beer, oh and plenty of light
CBR Time is offline
post #30 of 38 (permalink) Old 12-03-2012, 01:44 PM Thread Starter
BOTM Winner 1/13
Nuttynu's Avatar
hah thanks! guess all the cold and no riding makes us alskan hammer parts..shoot looks like he's an unactive member
My Ride Report :
Nuttynu is offline
Human Verification
