Please Help: Question about coolant. - 600RR.net
post #1 of 15 (permalink) Old 06-17-2017, 07:27 PM Thread Starter
BOTM Winner Jan 2015
shinfo's Avatar
I recently drained my coolant and replaced my water pump. I'm filling the system (2013 model) back up with coolant and as it works its way through the system it gets speckled. I haven't dealt with this before so I wondering if this is normal. I'm not sure if I'm being paranoid and it's just bubbles from it getting so hot, or it's something else. It got progressively worse as it went on.
Another question: the manual does not say how high to fill the coolant. As I'm pouring it in the access neck, how high should the level be?
This stuff wasn't present in my old coolant that I drained. It was pretty clean.
https://40.media.tumblr.com/68b9f92683e3e0506dd727af79363281/tumblr_ntyw0v9hrk1ufoouto1_500.jpg
shinfo is offline
post #2 of 15 (permalink) Old 06-17-2017, 07:49 PM
FightingChance's Avatar
Feedback Score: 10 reviews
I think that you are right in that it is just turbulence in the coolant, not something like metal shavings or something else. Besides, if a gasket is letting coolant into the oil, you will see and smell it in the engine exhaust.
Like a car, you basically just fill it up to the top. I tend to leave a couple cm from the neck top. Remember that warmer coolant expands so it will look fuller than it is, until it has had time to cool.
FightingChance is offline
post #3 of 15 (permalink) Old 06-17-2017, 08:44 PM Thread Starter
shinfo's Avatar
I drained it and am flushing it. There are a lot of metal shavings in my coolant.
shinfo is offline
post #4 of 15 (permalink) Old 06-17-2017, 08:52 PM
I forget; why did you replace the water pump?
post #5 of 15 (permalink) Old 06-17-2017, 09:21 PM Thread Starter
shinfo's Avatar
It was leaking at out of the weep hole and at the crank case o-ring, which had small metal flakes on it.
shinfo is offline
post #6 of 15 (permalink) Old 06-17-2017, 09:32 PM
Zo_zo's Avatar
Just give it a good flush, if it wasnt present before and has only just appeared then its been introduced surely
Flush, blast, flush, refill, check, goodluck
http://imgur.com/a/bPtdG - album of my bike
Zo_zo is offline
post #7 of 15 (permalink) Old 06-17-2017, 09:52 PM Thread Starter
shinfo's Avatar
So I'm on my third flush. Coolant is gone basically and I still have a lot of metal coming out. When I fill up the radiator cap, sh*t keeps showing up on the top, like what's pictured above.
shinfo is offline
post #8 of 15 (permalink) Old 06-17-2017, 10:14 PM
Maybe the previous water pump ate it's bearing and it's just the leftovers from that piece?
I don't know what to recommend, other than continuing to flush with distilled water until debris stops showing up in the water. Also, recommend charging your battery, many starts in a short period of time likes to eat up your battery
post #9 of 15 (permalink) Old 06-17-2017, 10:17 PM Thread Starter
shinfo's Avatar
I don't have a charger but thanks for the heads up. If it doesn't start I'll know why haha.
shinfo is offline
post #10 of 15 (permalink) Old 06-18-2017, 01:02 AM Thread Starter
shinfo's Avatar
Drained the oil to see if it had any metal shavings and it did not. However it was extremely frothy and has a green hue to it (I have oem green coolant / however the oil is Mobile 1 Racing 4T and only has a few rides on it). I did a little test of mixing my oil and coolant in a pan to see what it looks like and it turned into a thick brown substance with the consistency of honey, so I don't think I have much, if any, coolant in my oil. I would like to get an oil test performed on it though to be sure. Anyone have any suggestions on who to use?
shinfo is offline
post #11 of 15 (permalink) Old 06-18-2017, 02:51 AM Thread Starter
shinfo's Avatar
Took the radiator off and found a bunch of chipping paint on the inside of the low exit port. I believe that's causing the "floaters" on the top of whatever fluid goes in the system. I'm going to finish flushing the radiator by itself in the morning, along with each side that'll let water pour trough it. Then I'll put it all back together and flush it some more until the metal flakes stop coming out.
shinfo is offline
post #12 of 15 (permalink) Old 06-18-2017, 10:06 AM
Zo_zo's Avatar
good job :3 glad you found the root, flush flush flush. Dont leave any floaters
Zo_zo is offline
post #13 of 15 (permalink) Old 06-18-2017, 05:15 PM
C. Chaos's Avatar
Try flushing with distilled water and vinegar. The vinegar will help to carry all the particulates faster.
Just add a tiny bit (couple of ounces of vinegar) to the distilled water. Then I would flush with JUST distilled water 2-3 times to get it all out.
I did this with an 08 R6 I had after it had set for 3 years...pulled all sorts of junk out of the system...
C. Chaos is offline
post #14 of 15 (permalink) Old 06-18-2017, 06:03 PM
BOTM Winner 07/16
rinonz's Avatar
To answer the level.. Keep filling it until it's full on the neck, the burp it a couple of times to get rid of the air bubble (rev is sharply and release)
and also keep filling it until it's about 75 degrees celcius when the thermostat open as well.
You'll notice that when it hits the thermostat open, the level suddenly dropped :)
rinonz is offline
post #15 of 15 (permalink) Old 06-18-2017, 11:08 PM Thread Starter
shinfo's Avatar
So I flushed the system about 15 times. I was still getting a "metal flake" in the water. I did some more digging and found that it could be a product called Alumiseal that is put in the radiator at the factory. I was still having slivers and a couple larger metal pieces come out up until the 13th time. I took off the new water pump and took it apart to make sure there were no metal slivers on any o-rings or anything like that. I've got coolant in it now and will take it out for ride when I get the fairings back together. (I'm going back to orange)
If anyone wants a 600rr, I've got one I'm looking to sell hahah.
shinfo is offline
Human Verification
