Water temp. with Modified engines - 600RR.net
Racers All u racers and want to be racers
post #1 of 4 (permalink) Old 12-06-2012, 01:04 AM Thread Starter
tuck and roll's Avatar
I'm trying to figure out if i can use stock rad with my superbike build or will i need a better one. Could you racers out there share what rad your using, and the kind of max. temps. your seeing with your modified engines. Thanks.
tuck and roll is offline
post #2 of 4 (permalink) Old 12-06-2012, 09:35 AM
Like I said in my last post you will need a huge rad Hondas for some reason put off a ungodly amount of heat when moded. I use a bora normally and that works enough. But at a minimum a add on bottom rad and a oil cooler so then that way the oil doesn't heat the water any more.
I would Like to thank my sponsors:
Pirelli Tires
Chicken Hawk Racing
Spy Eyewear
AXO Leathers
Galfer Brakes
xbikeracer is offline
post #3 of 4 (permalink) Old 12-07-2012, 10:43 AM Thread Starter
Where would i find one of these Bora rads and how much ? I'd like to here what others are running also.
post #4 of 4 (permalink) Old 12-08-2012, 08:59 AM
Bora is hard to find but Febur might be alittle easier there bothe gonna run you some coin like 1500-2000 for the radiator
Pirelli Tires
Chicken Hawk Racing
Spy Eyewear
AXO Leathers
Galfer Brakes
Human Verification
