Need help - removing exhaust valve - 600RR.net
07-13 RR Modifications Modifications to the '07- to 013 600RR
post #1 of 13 (permalink) Old 01-07-2009, 06:45 AM Thread Starter
kordo's Avatar
Hey
I know there are posts out here for removing of the exhaust valve but I cant find any. I know how to trick the FI light but I need to know how to remove everything and tie off the valve.
Any help would be greatly appreciated.
Cheers
KORDO
'08 CBR600RR
- Puig light smoke double bubble, CRF 450 Mod w/ custom bracket, Sato Rearsets, Pazzo levers, Woodcraft Case Covers, oggy knobs, fork & swingarm sliders, PC'd gas cap, subframe and pillion pegs, garage door opener mod, gutted intake, stomp grips, caron Yosh RS-5 s/o
kordo is offline
post #2 of 13 (permalink) Old 01-08-2009, 09:18 AM
graffiti's Avatar
curious too, I believe peeps have been manually fastening them in the open position with wire or similar.
graffiti is offline
post #3 of 13 (permalink) Old 01-08-2009, 04:29 PM Thread Starter
kordo's Avatar
correct, and I've heard of posts out there for "how to" but cant find it...
doesnt seem that hard but, think I should steal a friends camera and make it:)
KORDO
'08 CBR600RR
kordo is offline
post #4 of 13 (permalink) Old 01-08-2009, 05:00 PM
the hooligan's Avatar
Feedback Score: 8 reviews
Originally Posted by kordo View Post
Hey
Cheers
go down to the valve and pull the cover off, i believe its two 8 or 10mm bolts. unhook the cables and put the cover back on.
next pull your seat off, unbolt the servo motor and take it out. then follow the writeup for the wiring to trick the computer. its really easy.
CustomFighters.com
the hooligan is offline
The Following User Says Thank You to the hooligan For This Useful Post:
dixon cider (10-22-2016)
post #5 of 13 (permalink) Old 01-08-2009, 05:04 PM Thread Starter
kordo's Avatar
cool. I thought I had to use wire to hold the valve open.
cheers
KORDO
'08 CBR600RR
kordo is offline
post #6 of 13 (permalink) Old 01-08-2009, 05:17 PM
graffiti's Avatar
cheers
Yes, I figure there should be something good installed to hold the valve open.
I have been looking at the valve and spring assembly for a while (bike is just going back together for a track bike). I am thinking of making a small bracket which will fasten the centre flapper valve bolt/shaft to both the small bolts where the cover bolts on. I believe the spring does not have enough tension to stop the valve from rattling or changing its position from wide open.
graffiti is offline
post #7 of 13 (permalink) Old 01-08-2009, 09:04 PM Thread Starter
kordo's Avatar
Some wire would probably also do the trick too:)
KORDO
'08 CBR600RR
kordo is offline
post #8 of 13 (permalink) Old 01-09-2009, 10:25 AM
no need to put anything on to hold the valve open, once you pull the cables off the valve it stays open full time
CustomFighters.com
post #9 of 13 (permalink) Old 01-10-2009, 05:54 PM
I did this mod to my exhuast valve and is was held in the closed position with the spring. What you have to do is take the whole assembly off so it is just the valve.... start the bike and rotate the valve to the open or closed position, you cand tell fairly easy by listing to the exhaust note. and mark it. If you marked it in the closed position rotate it 90 degrees. I saftey wired mine open by drilling a hole in the case and attaching it to the valve and the hole in the case. Then to delete the servo motor go here.....Decided to fix the servo removal problem for you guys *Quick and Easy FI Light Fix*
orangecbr is offline
post #10 of 13 (permalink) Old 10-22-2016, 01:53 AM
Lifetime Premium
dixon cider's Avatar
Can we cut the exhaust valve out entirely and weld a straight piece of pipe in? My bike sounds and runs like garbage until I hit 7k and I think its this valve.
dixon cider is offline
post #11 of 13 (permalink) Old 10-22-2016, 02:29 AM
Lifetime Premium
I am cutting that flapper valve off tomorrow. I only post pics if my welds don't look too crappy.
post #12 of 13 (permalink) Old 10-23-2016, 04:30 AM
Ldn
Ldn's Avatar
No need to remove or rig the valve in any way. Remove the servo-motor and the cables. That's it. The valve does not otherwise affect performance.
Also, keep in mind that your power band doesn't engage until 7k RPMs. That means your secondary injectors do not engage until then. This is working as intended. If you want to change this consider a sprocket change (cheapest) a tune (less cheap) or a full exhaust system + tune (not cheap).
"I don't want to burden you with my problems... but I think I've outgrown my yacht."
Ldn is offline
The Following User Says Thank You to Ldn For This Useful Post:
dixon cider (10-23-2016)
post #13 of 13 (permalink) Old 10-23-2016, 10:59 AM
Lifetime Premium
First of all, everyone was correct about the valve. Thanks @Ldn for the info about why the bike starts to run good at 7k. I had an irritating vibration that seemed to be coming from the exhaust and figured it was the valve, like it was loose and rattling in there. I cut the valve out yesterday and welded the pipe back up and no difference. So, like everybody says, just leave this thing alone. I bought the parts to do the servo motor delete and free up some room for some tools.
Human Verification
