Power commander question... - 600RR.net
07-13 RR Modifications Modifications to the '07- to 013 600RR
post #1 of 16 (permalink) Old 10-29-2012, 09:39 PM Thread Starter
hi,
someone please tell me what power commander is and what it does? i know its something to do with your air and fuel ratio and you can change it?
what are some benefits of getting one?
what can you do with it?
i ride a cbr600rr 2007, i dont do any track just street mainly year around?
any feedback is appreciated
ballanumber1 is offline
post #2 of 16 (permalink) Old 10-29-2012, 09:51 PM
ChrisR.Conley's Avatar
Similar to a space shuttle Commander, they send you to outer space
ChrisR.Conley is offline
post #3 of 16 (permalink) Old 10-29-2012, 10:07 PM
Feedback Score: 12 reviews
Post what other mods you have done in terms of your exhaust and people can tell you if it would be worth getting one. The more you change the intake or exhaust on your bike the more you will benefit by a powercommande, regardless of where or how you ride.
motomummy is offline
post #4 of 16 (permalink) Old 10-29-2012, 10:18 PM
iptydafool's Avatar
It's a fuel management module and allows you to increase or decrease the percentage of fuel going to the injectors from the ecu. Your bike is tuned by the factory with the proper air/fuel ratio and programmed to the ecu. If you install an after market part that alters the air ratio, you could be dumping too much fuel into your engine or not enough. The power commander allows you to adjust your fuel accordingly so that you have a good air/fuel ratio depending on the tuning to accommodate this modification. Do to popular belief it does not add horsepower by just installing it. I would not suggest it if your bike is stock as there would be no point.
Just going off of memory so please correct me if I'm wrong in any way. If all else fails there are plenty of threads here explaining this, just use the search box.
03' CBR 600RR
03' CBR 954RR
iptydafool is offline
post #5 of 16 (permalink) Old 10-29-2012, 10:25 PM
iptydafool's Avatar
Originally Posted by chrisr.conley View Post
similar to a space shuttle commander, they send you to outer space
0________0
03' CBR 600RR
03' CBR 954RR
post #6 of 16 (permalink) Old 10-29-2012, 10:33 PM
edelbrock231's Avatar
Perfect!
Sent from my SPH-D700 using Motorcycle.com Free App
edelbrock231 is offline
post #7 of 16 (permalink) Old 10-30-2012, 12:57 AM Thread Starter
in terms of exhaust i have yoshi rs5 slip on exhaust currently and thats about it.
i do have a problem, with my bikes fuel economy i get about 180KM (not milage) i live in canada...
somebody told me to get a power commander to get millage.
also whats dynotuning and stuff mean and do
sorry about all these questions im new to this stuff
post #8 of 16 (permalink) Old 10-30-2012, 12:59 AM Thread Starter
post #9 of 16 (permalink) Old 10-30-2012, 01:55 AM
smiley6111's Avatar
You should have tried google.... but like stated the power commander is a fuel programmer that piggy backs the ecu and is used to adjust fuel to get the correct A/F ratio which is helpful when you install exhaust/airfilter. and you would need to take your bike to a shop or person that has a dynometer to make you a custom fuel map to get that ratio as near to perfect as possible. you'll feel the difference in the throttle response and linear power output. I just got a pc-v and a dyno map for my 09 and i can feel a difference in 6th gear pull and lower gears. I have a K&N airfilter and two brothers exhaust. I feel it was worth the cost in my case. I commute alot and try to hit the tail of the dragon a few times a yr. your other option besides the dyno is the auto tune that will adjust the fuel while you ride. hope this helps.
2006 ninja 650r- Sold
2006 CBR600rr- Totaled
2009 CBR600rr- Stolen
2012 CBR600rr - Current
smiley6111 is offline
post #10 of 16 (permalink) Old 10-31-2012, 12:32 AM
Not even going to bite at that one...
post #11 of 16 (permalink) Old 10-31-2012, 01:48 PM
Lifetime Premium
SpdFrk's Avatar
I know I definitely need a pc with a full exhaust, but do you think I would need it with just a slip-on? or is stock sufficient?
2012 CBR600RR
OEM: Solo Seat Cowl ; CBR1000RR Rear Turn Signal Lenses
Akrapovic: Slip-On
Bazzaz: Z-Bomb
Cox Racing Group:
Radiator Guard
DDM Tuning: HID
Lawst Caws: Frame Plugs
Stompgrip: Frame Traction Pads
StreetSkinns: Custom Seat
TechSpec: Snake Skin Tank Grips ; Tank Pro
Tripage: Smoked REG IT ; 40-LED Pegs ; Knight Rider Third Light ; Brake Flasher ; LED Flasher Relay
Watsen Design: Micro Alloy LED Signals
Future Mods: Tripage LED Mirrors & Ultimate KR
SpdFrk is offline
post #12 of 16 (permalink) Old 10-31-2012, 02:05 PM
03cbr-rider's Avatar
No you don't. You can also do a search here, it has been covered probably hundreds of times (literally).
03cbr-rider is offline
post #13 of 16 (permalink) Old 11-01-2012, 11:54 PM
iptydafool's Avatar
+1
That's where I got my info.
03' CBR 600RR
03' CBR 954RR
post #14 of 16 (permalink) Old 11-02-2012, 03:43 AM Thread Starter
im still confused on getting it or not.
i do want a better fuel economy though
are their other alternatives to getting better mileage. air filter?
post #15 of 16 (permalink) Old 11-02-2012, 05:39 PM
iptydafool's Avatar
You could buy a Vespa :)
If you buy a high flow air filter, more air will be coming in, so you would want a power commander to adjust the fuel to match accordingly. Standard K&N's just replace your paper filter with one you can clean instead of purchasing a new one.
To find out your air/fuel ratio you would go to a place with a dyno, it's like a treadmill for motorcycles and measures everything from air/fuel ratio to horsepower. Once it's ran on a dyno they would tune the power commander to supply more or less fuel depending on the amount of air coming into the bike.
Seriously though, that search box is awesome. It's like Google, but for things on the site, and its been around since '94 so I'm sure someone has mentioned it.
03' CBR 600RR
03' CBR 954RR
post #16 of 16 (permalink) Old 11-26-2012, 11:50 AM
CProgrammer's Avatar
wow I mean I love the forum and all but how can we make people search if you keep answering their already answered questions?!!!!
OP Has 84 posts
Make him search
CProgrammer is offline
Human Verification
