Engine Software Interface Question - 600RR.net
07-13 RR Modifications Modifications to the '07- to 013 600RR
post #1 of 8 (permalink) Old 12-06-2012, 01:41 AM Thread Starter
So I hooked up a Powerlet adapter to the bike. Ran it along in the wire loom up the right side of the bike. From there I have the outlet adapter -> two cigarette lighter adapters. On one, I have a Powerlet USB adapter. I run an Ipad 3 (soon to be Mini Ipad), an iradar200 and iphone on the other. I interface it all through my helmet so I can get nav/directiions, take calls, listen to music or watch a movie (if i wanted).
Now, my question is...Is there some kit that plugs into the ECU port to a wifi module? I want to it to send engine parameter info wirelessly since the Mini Ipad still blocks my cluster. I have a unit like that on my car that sends it to the iphone but I dont know if there is such a thing for the bike world. Thanks...
10YR is offline
post #2 of 8 (permalink) Old 12-06-2012, 12:24 PM
wow.........!
tary preisser is offline
post #3 of 8 (permalink) Old 12-06-2012, 12:27 PM
mvisher's Avatar
I'm speechless. Sounds like the makings of a motorhome.
mvisher is offline
post #4 of 8 (permalink) Old 12-06-2012, 09:43 PM
Lifetime Premium
Minx's Avatar
Sounds like information overload.
Just look down at your cluster?
Sent from my DROID RAZR using Motorcycle.com App
-Minx
My Modification Memoir - GOLDEN EYES
FS: 07+ Stock Exhaust + Heat Shield ($75)
FS: Dainese Delta Pro Pants (38 Long) - $300+
Complete: Li Ion Battery, HID Gold Eyes, Radiator Guard, SSR Rearsets and RC2 Levers, Type 4 / 3 Brake Lines, 8149B Slip-On, FE, IT, Cluster LEDs, and LED Pegs, Sliders, Brake Pads, Corsa Screen.
Up Next: TTX MkII Rear Shock
Minx is offline
post #5 of 8 (permalink) Old 12-06-2012, 11:07 PM
fallingbomb's Avatar
Nothing like that exists.
2007 CBR600RR -- CVMA #270 -- Pictures -- Build Thread
fallingbomb is offline
The Following User Says Thank You to fallingbomb For This Useful Post:
10YR (12-07-2012)
post #6 of 8 (permalink) Old 12-07-2012, 02:50 AM Thread Starter
Not really since everything will be sent via bluetooth to the helmet. I may forget the Mini Ipad for now and just utilize my iphone since I have it mounted on a Techmount (stem). The only issue it radar detector mount location and Powerlet mounting location...
Thanks. Im already having a friend develop the software. The plug to bluetooth module is a piece of cake...
10YR is offline
post #7 of 8 (permalink) Old 12-07-2012, 08:57 AM
Lifetime Premium
Minx's Avatar
Reread what you're doing and didn't realize at first that you wanted to use your helmet as a hub for everything. I thought that you wanted to have all that info in a heads-up display or something.
You'll probably want to get a manual and look at the wires going to the cluster and see what you're going to want to be displayed on the virtual cluster and have some type of piggyback module that can interpret them and display them accordingly.
Look into data logging (since that's going to be the heart of the project) then have your friend make an app for the device.
-Minx
Minx is offline
The Following User Says Thank You to Minx For This Useful Post:
10YR (12-09-2012)
post #8 of 8 (permalink) Old 12-07-2012, 11:59 AM
for radar location just buy a factory 2nd double bubble and drill some small holes for mounting the detector.
Good luck!
The Following User Says Thank You to tary preisser For This Useful Post:
10YR (12-09-2012)
Human Verification
