I installed some drls inside the headlight while I was putting in some projectors. I am all done but once i wire the switchbacks to the turn signal lights the turn signals dim down as in the wires can not take sending the power to both turn signal lights. My question is there any way to solve this? Maybe let more current pass by or wire it differently?
Sounds like you have the signals wired in series with whatever you have going on inside the headlights. Wire them in parallel so you're not adding the resistances of each.
Thanks for replying back Lyoha. You thinj you can explain that to me a bit more. Like what do you mean i have them wired in a series? Maybe a link will help out better. Thanks again.:smile2:
Maybe I should have asked earlier but how did you wire the running lights in? I'm assuming to the running circuit of the turn signals? Is there a guide you followed?
Oh well actually i just spliced through it which probably wasnt the best idea im guessing. So maybe the circuit is the best place? Follow the turn signals all the way back to the circuit would be the right way?
Take a look at the image below. Top is the two components separately. The DRL LED strip probably has just two leads - one for the power (+) and another for ground (-). The turn signals with running lights have three leads - one for running (+), one for turn (+) and another for the common ground (-). The colors are probably not representative of what you have but I'm only trying to pass along the idea. What I imagine you did is the middle setup where you simply spliced the (+) and (-) of the DRL LED into a single power wire to the running light of the turn signal. This will make both dimmer. What you should do is the last setup and tap the DRL (+) into the running (+) wire for the signal and DRL (-) into the turn signal ground (-). This will let them both operate at full brightness.
Related Threads
Honda CBR 600RR Forum
3.9M posts
92.7K members
Since 2003
