DIY Installation Guide for Stomp Grips - 600RR.net
DIY Write up's This forum should be used for any step by step descriptions of a job you are tackling. Pictures are a big help to clarify the process
post #1 of 17 (permalink) Old 07-22-2009, 03:11 AM Thread Starter
kidnplay01's Avatar
Post DIY Installation Guide for Stomp Grips
Ok, I have read a few things on here in regard to fitment, ppl scared of the soap and water way, how to reduce air bubbles etc.
So here is a easy guide with proven working ability, and tips i wish i had :icon_lol:
1) Get your bike out in the sun, warm that tank area up one way or other (heat gun)
2) Clean the tank area with some cleaner / alcohol / whatever you have to get rid of the dirt/grease built in, unless like me you have fresh fairings where soapy water was enough.
3) get a few drops of detergent / soap into a bottle fill with water shake about or no spray just get a bowl with some soapy water as above.
4) Get 1 stomp grip ready by peeling it back, this was more difficult then you may think, as you dont want to get your fingerprints on it, as this may / will show later on with the install. So spray the parting area (grip/waste paper) and you can touch it now as its slippery and not sticking. The amount of water on it doesnt really matter, so dont stress.
BUT CAREFUL... HAVE A CLEAN AREA WIND FREE AS CRAP MAY FLY ONTO YOUR STICKY PAD AND NOT LOOK PRETTY ON YOUR TANK and getting rid of it may become a PIA and noticeable later on the tank.
5) Now apply to the tank, squeeze out as much water / air as possible (spend a few minutes) and place where you want to have it.
6) Now respray the other side of the tank as no doubt its dry by now, same process as the other one and have it aligned as the other
7) Now that they are both on, go to the one thats been on there the longest and press out any air / water still trapped, now repeat other side.
8) I only had very light bubbled area that i put down to still moisture, i just left it in the sun further to heat it right up, as when i came back to it later, i just kept pressing it to the tank and finally is stuck.
9) Use a heat gun / hair dryer if you can to really heat it up, as the glue works best with heat. Do this for about 5-10min each side to get it really going,
Careful not to MELT / BURN the Grip nor damage your bike, if you cant touch it, then its too HOT
Next Sit and Enjoy, It can take a few days to adhere properly as stated on the directions..But all and all Great Product..
Ohlins- Fork Springs, Shock, S.D, UES Kit 20mm, PCIII, Velocity Stack mod, RS-5 C.F Yoshi, Dynoed, K&N Air Filter, Cox Radiator Guard, Powers Race Railz mod, MOTY Battery, Pazzo Levers, Harris Grips, Stomp Grips, Ram mounting, Custom Fairings, Custom led gauges, C.F -Hugger-Sprocket cover,Exhaust,Heel, Chain, Engine,& clutch guards. Trippage led pegs, 520 Conv, -1 +2 Superlight Sprocket, Comp werkes FE, Dunlop Q2's, EBC Kevlar Heavy Duty Clutch/Springs, Vesrah RJL Pads,Braided brake lines
kidnplay01 is offline
The Following 2 Users Say Thank You to kidnplay01 For This Useful Post:
GConn (07-08-2013), YourNameHere (07-25-2011)
post #2 of 17 (permalink) Old 05-13-2010, 04:20 PM
Lifetime Premium
Feedback Score: 8 reviews
Has anyone else tried this way? How does it work? I'm trying to find the best/easiest way to install my grips.
2012 CBR600RR Black
2003 CBR600RR Playboy Race Replica - Sold
2007 CBR600RR Konica Minolta Race Replica - Stolen, Recovered, Rebuilt & Sold
2006 CBR1000RR Red/Black - Traded for Jeep Wrangler
2012 CBR600RR Build Thread: http://www.600rr.net/vb/176-rr-other-brands-bike-build/497201-fourth-times-charm.html
Workinboy is offline
post #3 of 17 (permalink) Old 05-14-2010, 03:30 PM
Standup's Avatar
I installed mine this way on Wednesday, still letting them fully cure but they came out great. No large air bubbles, it was really easy to posistion the pads were I wanted them. I just did one side at a time using the hair dryer and it took about 2 1/2 hours, could probably take other less but i'm very picky when it comes to my bike. This is a proven method though, I've installed dirt bike graphics this same way with no problems over 4-5 years of rough use.
Standup is offline
post #4 of 17 (permalink) Old 05-14-2010, 03:52 PM
BOTM Winner 04/14
GConn's Avatar
Thanks for the write up!
GConn is offline
post #5 of 17 (permalink) Old 05-14-2010, 09:48 PM
Lifetime Premium
I just installed my grips and tank pad using this method this afternoon and it turned out great. Had a friend of mine come over and it took us about 15-20 minutes for each side; not bad at all. Overall first impression is fantastic! No air bubbles, no nothing. Towards the top of my tank is a little black so it looks a little tacky, but not bad at all! Recommend wearing rubber gloves so no fingerprints show up.
2012 CBR600RR Black
2012 CBR600RR Build Thread: http://www.600rr.net/vb/showthread.php?t=497201
post #6 of 17 (permalink) Old 05-17-2010, 01:38 AM Thread Starter
kidnplay01's Avatar
No worries guys thanks, if i do things where i had no DIY to go by, i always take pics and do a write up, 600rr.net helped me in other areas so i give my own back
Wear gloves for insurance of no fingerprints, or as stated wet it first then play, sounds like directions for something else
post #7 of 17 (permalink) Old 05-17-2010, 07:02 AM
BOTM Winner 04/14
GConn's Avatar
So you could soak the back in soapy water and it would still stick?
GConn is offline
post #8 of 17 (permalink) Old 05-17-2010, 07:38 AM Thread Starter
kidnplay01's Avatar
No need to soak it, get a knife and seperate on the edge, then wet between the layers, pull and spray. or as stated wear gloves
post #9 of 17 (permalink) Old 06-11-2010, 02:35 PM
EWOKie's Avatar
Put my black ones with no probs, just cleaned the tank up with zipwax (wash and wax) and let dry to get rid of any dust/debris.
Started front the centre bottom (if looking at rhs of bike..nearest the seat)
Applied the grip and voila..done.
Let it sit overnight as it was cold when I did it with no bubbles and still holds well after 4 months.....
Went for black ones as I dont have decals on the tank.
EWOKie is offline
post #10 of 17 (permalink) Old 07-15-2010, 11:05 PM
Do the pros (i.e. Rossi, Lorenzo, SPies) use stomp grip. I don't see it on their bikes. Why?
rostam is offline
post #11 of 17 (permalink) Old 07-16-2010, 05:41 AM
BOTM Winner 04/14
GConn's Avatar
No...but I think they ride better than me...
GConn is offline
post #12 of 17 (permalink) Old 09-28-2010, 03:36 AM
Cheers for this thread, I put mine on yesterday and it turned out pretty good! The one on the right is slightly off, must've moved after I had it lined up.
atrang is offline
post #13 of 17 (permalink) Old 10-11-2010, 11:49 AM
MJ01's Avatar
Thank you.
Great !
MJ01 is offline
post #14 of 17 (permalink) Old 10-11-2010, 07:34 PM
I don't want to threadjack, as the OP is the real correct way to do it, but when I put mine on my last bike, I windexed the area in the sun and just stuck them right on, peeling the back away slowly, and rubbed them down with a tennis ball to remove air bubbles, and they stuck great for the 3 years I used them.
Slowstang is offline
post #15 of 17 (permalink) Old 11-16-2010, 12:00 AM
wish I would have found this thread last weekend.
I tried the stomp grips but it didn't turn out well.... I am experience applying graphics but i just could not get these to stick.
I cleaned the tank, heated the tank and grip... next morning... one side was laying on the ground.. the other was half pealed up..
not too impressed.
my lockhart tank pad had no problem staying on...
mxr64k is offline
post #16 of 17 (permalink) Old 12-29-2010, 07:38 PM
$trreetKing600's Avatar
nice writeup man, im gonna def do this next week when i get mine tech specs grip pads.
hyperflo carbon (love it)
just painted the rear sets/gas cap
pirelli corsa, driven d3 grips, rim stripes, double bubble windscreen, gutted intake, FE kit, flushmounts.
with more money will come more goodies.
$trreetKing600 is offline
post #17 of 17 (permalink) Old 11-07-2012, 12:53 AM
next bike i'll try stomp grip instead of techspecs.
Shadow6OORRider is offline
Closed Thread
Human Verification
