Garage Door Opener - 600RR.net
DIY Write up's This forum should be used for any step by step descriptions of a job you are tackling. Pictures are a big help to clarify the process
post #1 of 38 (permalink) Old 06-07-2010, 10:51 PM Thread Starter
kwanjuju's Avatar
Garage Door Opener
Well I thought I would do my first writeup on doing a garage door opener button since I don't think I've seen a thread like this. I used to keep the garage door opener in my jacket pocket until I bought a new Taichi jacket and was a little too snug to keep the bulky opener in the pocket.
Very simple to do for under about $5 if you have the soldering tools and already have a garage door opener. Sorry for the crappy phone picks.
First off, you'll need the garage door opener, some wire (mine was 18 ga. I think?), a push button switch, some solder, and a soldering iron. You'll also probably want some flux (helps the solder flow) and a way to remove any solder errors (the mesh solder remover).
Once I popped the opener apart, I removed the buttons. The main opener button clearly closed a single position switch with four legs (A). I used the continuity function on a little digital tester to determine which legs were the closed legs when the button was pushed (B,C). These are the legs that need to be extended to the pushbutton switch.
The rest is easy. Just solder a pair of wires to legs B and C (this will obviously look slightly different on your garage door opener of choice) and solder those to the pushbutton switch. You'll want to use connectors of some sort so the opener isn't permanently attached to the switch. I also drilled two small holes (3/32"?) into the top of the opener case to thread the wires out. Its been a while since I did any fine soldering, so dont bash my crappy soldering job!
After that, I drilled a 1/2" hole into the little box on the right side of the frame (not sure what this box is for, if someone knows what it is or what its name is feel free to correct me). You can drop the opener right into the box, screw the pushbutton into the hole, and you're done! Easy and unobtrusive.
Silver 2006 CBR 600RR
kwanjuju is offline
The Following User Says Thank You to kwanjuju For This Useful Post:
Biscuits (03-09-2011)
post #2 of 38 (permalink) Old 06-07-2010, 10:52 PM Thread Starter
kwanjuju's Avatar
Sorry those last two pictures are so bad...hard to see anything. I will take better ones tomorrow.
kwanjuju is offline
post #3 of 38 (permalink) Old 06-07-2010, 11:14 PM
Chingbo's Avatar
Feedback Score: 6 reviews
yes, more picture plz
someone else here did a garage door opener via hi-beam switch, but im interested in trying this too
_________________________________________
if you can believe it, and can conceive it,
you can achieve it,
period.
Chingbo is offline
post #4 of 38 (permalink) Old 06-08-2010, 09:11 AM Thread Starter
kwanjuju's Avatar
Pictures you can actually see now.
kwanjuju is offline
post #5 of 38 (permalink) Old 06-08-2010, 11:38 AM
That little box on the right side is supposed to hold your factory emergency toolkit. Apparently, a previous owner lost it or kept it.
qqac is offline
post #6 of 38 (permalink) Old 06-08-2010, 11:49 AM Thread Starter
kwanjuju's Avatar
Well its a convenient little location for switches. I saw someone use that location in a headlight switch write-up which I plan to do this weekend.
What kind of tools are in with the emergency kit?
kwanjuju is offline
post #7 of 38 (permalink) Old 06-08-2010, 03:26 PM
Death Dream's Avatar
Lol and here I was just using Velcro on my handle bars to hold my opener.
Death Dream is offline
post #8 of 38 (permalink) Old 06-08-2010, 03:42 PM
tdtRRiton's Avatar
Dear god, I wish I had a garage to facilitate a need for this mod.
Nice idea, nice writeup.
tdtRRiton is offline
post #9 of 38 (permalink) Old 06-08-2010, 09:52 PM
fteac70's Avatar
I just want the little box to put stuff in, like spare change. Nice write up. I have to rev the bike to get my kid to open the basement door. I don't have a garage.
"It only hurts till you die"
"No, that really wasn't just a hint it was a suggestion"
"Crash"
fteac70 is offline
post #10 of 38 (permalink) Old 06-08-2010, 10:17 PM
Chingbo's Avatar
My tool kit is out too, I took it out once to see what's in it, and I cant fit it all back in..
lol
here's whats in the kit..
i dont have the specs of each tool
you can achieve it,
period.
Chingbo is offline
post #11 of 38 (permalink) Old 06-08-2010, 10:32 PM
nice mod and handy hope this can help others. Ill keep this in mind for the future, but is there smaller boxes somewhere that can be sleeker or hide elsewhere incase someone happens to click it outside and bam ur garage is opened etc...
Hardcopy21 is offline
post #12 of 38 (permalink) Old 06-08-2010, 10:44 PM
HI OFECR's Avatar
Huummm id like to do this but i think ill locate the button on the bars.
HI OFECR is offline
post #13 of 38 (permalink) Old 06-08-2010, 11:01 PM
Shane'sRR's Avatar
I also did this mod on my bike! Installed the Garage door opener under drivers seat and mounted button on windsheid mount arm.
Shane'sRR is offline
The Following User Says Thank You to Shane'sRR For This Useful Post:
post #14 of 38 (permalink) Old 06-10-2010, 01:13 PM Thread Starter
kwanjuju's Avatar
That's pretty slick...good idea and nice subtle location.
kwanjuju is offline
post #15 of 38 (permalink) Old 06-18-2010, 11:27 AM
2010drive's Avatar
This is all you get with the new cbr's
2010drive is offline
post #16 of 38 (permalink) Old 06-28-2010, 02:58 AM
Gonna try this, i usually just shove that big box in my chest pocket.
3s1k is offline
post #17 of 38 (permalink) Old 06-28-2010, 07:08 AM
pawag's Avatar
Great idea! I wish they made a small one that you could easily attach on your bike.
2007 CBR 600rr Red/Black
Leovince SBK Oval Evo II Slip-on
Hotbodies Smoke Flushmounts
Red Rim Tape
HID Kit
Datatool Gear Indicator
Titax Shorty Levers
Puig DB Smoke Windscreen
Rizoma Brake Reservoir
Tripage Powdercoated Pegs
CA Smoke Integrated Tail Light
DIY FE Kit
Shogun Crash Kit
Stomp Grip
Scorpio i900 Alarm
Shoei Kiyonari
pawag is offline
post #18 of 38 (permalink) Old 07-07-2010, 09:41 PM
i have been planning on doing this for a long time.. just got motivated after reading this and went out and did it in under 15 min start to finish.. i mounted my button inside the fairing in the little panel that covers the right intake tube near the fork so i can just reach down and press it and it stays hidden came out great!
03sc350z is offline
post #19 of 38 (permalink) Old 07-15-2010, 10:02 PM
Anyone with a garage should have this mod. I do. It saves alot of hassle, both leaving and even better, coming back; especially when the cops are chasing you and you need to hide, QUICKly.
rostam is offline
post #20 of 38 (permalink) Old 07-16-2010, 05:49 AM
BenHart21's Avatar
I sure as hell hope you're not being serious.
05 600RR
05 Subaru Baja Turbo
95 Chevy Camaro Z28
BenHart21 is offline
post #21 of 38 (permalink) Old 09-10-2010, 05:02 AM
good ideal
meferd is offline
post #22 of 38 (permalink) Old 09-16-2010, 03:08 AM
Rendil's Avatar
Did this today but for my car, was sick of the opener on visor rattling every now and then, plan on doing highbeam opener for the bike. Good write up!
Rendil is offline
post #23 of 38 (permalink) Old 09-22-2010, 01:11 AM
Post Another option: Use horn switch!
I have modified the design described above in favor of using the HORN SWITCH to control the garage/gate OPENING DEVICE. For me it works flawlessly and is very convenient!
Here is what you'll need to do:
1. Remove the SEAT
2. Remove the LEFT MIDDLE COWL and the RIGHT MIDDLE COWL
3. Remove the FUEL TANK COVER
4. Locate the LEFT HANDLEBAR SWITCH CONNECTOR
5. Use a standard WIRE TAP and tap the BLACK and BROWN/WHITE wires individually. (These wires are located next to each other in one corner of the CONNECTOR. I tapped them on the side of the HANDLEBAR.)
6. Run appropriate spans of wire from each WIRE TAP to the BATTERY COMPARTMENT located under the seat. (This should be pretty easy with the FUEL TANK COVER removed.)
7. Connect a newly run wire to each of the 2 posts soldered on the OPENING DEVICE as described in the previous post(s). (I'm not sure if it matters which wire is connected to which post. If you have any issues try swapping them. I used quick-connects here to enable this and easy removal of the opening device.)
8. Tuck the OPENING DEVICE into the BATTER COMPARTMENT.
9. Disconnect the HORN as desired. (I'm sure I'll get some feedback here as to how potentially dangerous this is. Oh, well... I don't want to blast my horn each time I leave/return.)
10. Put the BIKE back together.
I've included here a diagram that should help clear up any confusion.
I've deployed this for a privacy gate opener that controls entry/exit for my neighborhood. It's been an awesome upgrade and not having to take my hands off the bars is a huge advantage! Enjoy!
Ripster is offline
post #24 of 38 (permalink) Old 09-22-2010, 01:22 AM
Rendil's Avatar
1. Remove the SEAT
Good idea but i'm gonna do mine to my highbeams, I like my horn especially for those assholes that cut you off
Rendil is offline
post #25 of 38 (permalink) Old 09-22-2010, 02:28 AM
Well, I have a middle finger for that! Besides I don't think these horns are all that audible with the engine revving.
Ripster is offline
post #26 of 38 (permalink) Old 09-22-2010, 02:29 AM
Nico's Avatar
I would suggest that instead of tapping the wires for the horn you cut them completely. Depending on the design of the opener you may or may not damage it by feeding 12V into it from the bike, if you plan on using the bike as the power source for your opener then it is almost certain that it either wont work or will damage the opener.
Otherwise, good idea.
As a side note, you could get a European switch unit, they have a highbeam flasher switch on them that you could use. The only downside is that you loose your indicator running lights...
Nico is offline
post #27 of 38 (permalink) Old 09-22-2010, 03:10 AM
SHORTSTACK's Avatar
Feedback Score: 15 reviews
cool, dude thanks. ill be doing this soon.
R.I.P. PHATTY
SHORTSTACK is offline
post #28 of 38 (permalink) Old 09-22-2010, 10:36 AM
As a side note, you could get a European switch unit, they have a high beam flasher switch on them that you could use. The only downside is that you loose your indicator running lights...
I thought about that but if I'm reading the wiring diagram correctly the power source to the horn switch is shared by the high/low light switch and the turn signal switch. If so, cutting it would kill those functions.
If the very occasional push of a few extra volts kills the opener I can simply replace it via my HOA.
Per the side note, I don't want to lose any of the bike's functionality. The intent was to add 'factory feel' functionality. Looking at, driving, and seeing the bike this is a completely 'hidden' mod including the lack of any aftermarket switches, buttons, etc...
Ripster is offline
post #29 of 38 (permalink) Old 09-23-2010, 02:06 AM
Nico's Avatar
If you cut it where you have indicated on the schematic in your post above it will have no affect on any other function in the bike.
If you want to keep the running lights you could also use a couple of relays to imitate the part of the switch your losing... and you get to keep your horn.
Nico is offline
post #30 of 38 (permalink) Old 03-09-2011, 05:26 PM
HI OFECR's Avatar
Just did mine but i fabricated my own mount on the bars. Not pretty but it works and its easy to push.
HI OFECR is offline
Human Verification
