How to Adjust Valve Clearance - 600RR.net
DIY Write up's This forum should be used for any step by step descriptions of a job you are tackling. Pictures are a big help to clarify the process
post #1 of 40 (permalink) Old 08-04-2011, 06:34 PM Thread Starter
dreamzboy's Avatar
Disclaimer: This is meant as a guide only, please purchase a service manual or take it to the shop if you're unsure of what you're doing. Cross reference helps, so watch the videos I posted under "reference" and another guide written for another bike also under the same section. I take no responsibility for any damages due to breaking, kicking, cursing, or even beating your wife while performing this process.
Finally, if you've come to this link, that means your engine valve clearance is out of specification and it needs to be adjusted. This how-to is a continuation of the adjustment process posted below. This guide is not for checking for valve clearance. Use the link below if it's your first time performing valve clearance.
How to check valve clearances for a 600RR ( write up by abadfish )
Tools Required:
  • Torque Wrench
  • Camshaft Tensioner Tool (Can be crafted, see below.)
  • Feeler Gauge
  • Shims
  • Micrometer or Caliper Measurement Tool
  • Magnetic Tool
  • All other standard mechanic tools
  • Chips, Beers, Soy Sauce, Ketchup, whatever keeps you full. It will take 1-2 days up to couple weeks depending on your knowledge and given you didn't order any replacement parts that you broke like I did.
If you refer to the link above to do your valve clearance measurements, DO NOT install the Cylinder Head Cover or the Timing Cap. Leave it there as you're going to work on the engine.
Step 1:
Line up the index mark T with the notch (figure 35) and make sure the "IN" and the "EX" line sits flush with the engine (figure 36). If you're having trouble lining up all three, just line up the index mark T. This means that the cylinder is at TDC (Top Dead Center - figure 37). The camshaft "IN" and "EX" can be adjusted to sit flush with the engine casing later.
Step 2:
Fabricate the Camshaft Chain Tensioner Tool with a sheet metal thickness of 1.0mm. If you don't have one handy, you'll need to find a small screw driver that fits inside the tensioner and somehow hold it in place. You can also order one at Honda Dealership, part #07ZMG-MCAA400.
Step 3:
Remove the toolbox, camshaft chain tensioner lifter sealing bolt, and the washer. Insert the Camshaft Chain Tensioner Tool into the tensioner and rotate it clockwise until it is fully retracted. It's a flat head bolt inside that you're trying to turn. You'll will feel the friction as the spring compresses and it will want to spin the opposite direction. Once fully retracted, lock the tensioner in position but leave the tensioner component on the engine. Do not remove it yet. Failure to do this might cause damages to the engine.
Locked position pictured below:
Step 4:
Remove the Chain Guide bolts and the Chain Guide.
dreamzboy is offline
The Following 12 Users Say Thank You to dreamzboy For This Useful Post:
600rr Rider (11-08-2012), Alerious (08-11-2011), carl22 (09-29-2011), crzie (06-09-2014), djfokis (06-19-2013), InterlagosBlue (02-24-2016), Nuttynu (03-07-2014), RCV600 (09-27-2011), Saeed14 (06-12-2013), Sun-Zoom-Spark (12-05-2011), Undisputed (10-17-2011), Waru (01-29-2014)
post #2 of 40 (permalink) Old 08-04-2011, 06:35 PM Thread Starter
dreamzboy's Avatar
Step 5:
Loosen all 20 bolts securing the camshaft in a crisscross pattern slowly and evenly. Do not loosen any one bolt all the way out. You will damage the camshaft holders and other components.
In a nutshell, bolt 1 - 8 are the ones with a copper washer. When removing these bolts, BE EXTRA CAREFUL. If the copper washer falls inside the engine, the magnetic tool will not help. Bolts 9, 10, 13, 15, 17, and 19 are short. Bolts 11, 12, 14, 16, 18, and 20 are long.
Step 6:
Note the label "L" for left and "R" for right on the camshaft holder. It will need to be in the exact position when reinstalling.
Lift both camshaft holders off. It might be hard to lift, but use a mullet or any soft hammer and gently tap on the casing to get it to budge. If you're going to use a flat head to lift, make sure you take proper care as you don't want to scratch the engine surface. Watch for the locating dowels as shown in figure 57 under step 7.
Step 7:
Remove the Right Side Locating Holder labeled as "B" in figure 44.
Step 8:
Use a permanent marker or any pen that will stick through oil and mark the position of the chain to the sprocket. This will save you from doing any guess work when you put everything back. I didn't label mine because it was my first time doing valve adjustment and lacking experience.
Step 9:
Use a rope, rubberband, or bungee cord to secure the chain to the bike's frame preventing it from dropping inside the engine. You'll need a miracle to fish it out if it is dropped inside.
Step 10:
Removing the camshafts are optional. After so many tries, I was able to get the shims out of the valves without removing the camshafts. I derailed the "IN" camshaft to one side while removing the valve lifter and the shims and did the same for the "EX" camshaft. If you can't get access to the shims, then remove the camshaft. Be sure to note which one is "IN" and which one is "EX" and its position.
Step 11:
Use the magnetic tool to lift the valve lifter bucket and the shims from the engine valves. Replace the shim with the correct size and install it back into the engine NOT on the valve lifter bucket. It will not stick!
Important: The valve lifter will need to be in the EXACT location where it was taken out. If you don't want to deal with the valve lifter being shuffled around, I suggest do one valve adjustment at a time and put it back.
*Refer to the excel sheet below for Valve Clearance, Old Shim Thickness, and New Shim Calculations.
Shim Calculation and Measurement Templates
Shim Replacement Notes:
Let's say my valve clearance is .002" or 5.08mm out of spec. The measured old shim thickness is .076" or 1.929mm. The new shim calculated by the formula, A = (B - C) + D, yields .080" or 2.035mm. The closest shim that they've manufactured is .0787" or 2.00mm. Inserting a 2.00mm which is labeled 200 will put my valve clearance out of specs. This is where you'll have to use your best judgment and take the average. Old shim's thickness is 1.929mm, new shim thickness suggested 2.00mm, your best bet is to use 1.95mm or 195. The average used here is not the exact average but manufacture only produce a .05 incremented shim, pick the one closer to the original shim thickness.
Places to buy shims:
Alerious (08-11-2011), Anik321 (05-02-2012), crzie (06-09-2014), fallout (09-28-2011), InterlagosBlue (02-24-2016), Moeman (09-20-2011), Nuttynu (10-27-2012), RCV600 (09-27-2011), Saeed14 (06-12-2013), Sun-Zoom-Spark (12-05-2011), Undisputed (10-17-2011), Waru (01-29-2014)
post #3 of 40 (permalink) Old 08-04-2011, 06:36 PM Thread Starter
dreamzboy's Avatar
Installation Procedure
Once all the shims are replaced, it's time to put back the camshaft, chains, camshaft holders, and etc...
Step 1:
Make sure the cylinder is at TDC. It shouldn't be moved during the the camshaft removal process. Install the labeled "EX" or exhaust camshaft toward the front of the engine. Line up the index mark "EX" with the engine casing and loop the chain around the sprocket. If you've initially marked a reference point as described in Step 8, line it up with the marks.
Step 2:
Instal the intake camshaft the same way as the exhaust camshaft and recheck to make sure the "T" index marked is at TDC. Adjust if necessary.
Step 3:
Install the right side camshaft holder. It is shown in Step 7 above. Push it down as far as you can and check to make sure the camshafts are locked into position. Do not bolt it down yet.
Step 4:
Install the two center camshaft holders in place. Note, they will not sit neatly on top of the cylinder head due to spring pressure.
Step 5:
Applied a bit of engine oil onto the bolts and hand screw all 8 center bolts and washers. Next, hand screw the remaining 12 bolts in the order shown in step 5. In this order, gradually tightened bolts 5, 6, 7, and 8 1/4 to 1/2 turn at a time to push the camshaft holder down evenly. Then, tighten the remaining bolts from 1/4 to 1/2 turn at a time in the correct order. Finally, torque the bolts to 12 Nm or 106 in.-lb. I broke one of the bolt because I over torque it and too cheap to buy a torque wrench. It cost me $8 for a new bolt and 1.5 weeks of waiting.
Step 6:
Slowly and carefully un-tension the tensioner by turning counter-clockwise. It will violently spring back so becareful.
Step 7:
Check for valve clearance again as described in the previous how-to guide. If any of the valves are not within specification, repeat this guide to change out the shim. Failure to do so will cause damage to the engine and it will not start. I had to redo this process at least 5 times, so again, choose the new shims closest to the original shim. Too close will put your valve clearance out of spec again. Make your best judgement.
Step 8:
Install the camshaft chain guide, timing hole cap, and cylinder head cover. Before reinstall the cylinder head cover, remove the old gasket sealant and apply a small amount of new gasket sealer into the cylinder head cover gasket, especially the half circle section. Torque the cylinder head cover bolts to 10 Nm or 88 in.-lb. Again, broke another bolt here. Cost another $8, 5 hours trying to remove the remaining piece, and 1.5 week for new parts. I went out and got a torque wrench immediately. You may get by without a torque wrench but some of these bolts have been under a lot of stress and it's old so it may not have the same strength as when it was new. Bottom line, get a torque wrench. I'm happy with it and all my installation has been worried free.
Step 9:
Check and double check for valve clearance; otherwise, you'll end up wasting a lot more time going back to fix the issue. If everything meet specification, reverse the installation step as described in this guide and the previous guide. Before slapping on all the fairings, make sure the bike does start first.
References:
http://www.fireblader.dk/i_files/valvejob/valvejob.htm
The Following 11 Users Say Thank You to dreamzboy For This Useful Post:
Alerious (08-11-2011), Anik321 (05-02-2012), InterlagosBlue (02-24-2016), Jhoney (08-17-2014), Moeman (09-20-2011), RCV600 (09-27-2011), rhariz21 (03-26-2014), Saeed14 (06-12-2013), Sun-Zoom-Spark (12-05-2011), Undisputed (10-17-2011), Waru (01-29-2014)
post #4 of 40 (permalink) Old 08-11-2011, 12:48 AM Thread Starter
dreamzboy's Avatar
Whow all those work and no one says thank you or provide any comment?
The Following 3 Users Say Thank You to dreamzboy For This Useful Post:
InterlagosBlue (02-24-2016), Moeman (09-20-2011), Waru (01-29-2014)
post #5 of 40 (permalink) Old 08-11-2011, 12:51 AM
1ofakindRR's Avatar
Epic writeup FTW. Thanks for the hard work dreamzboy. Maybe Moeman should sticky in the maintenance section.
Solar White RR6 "Pearl"
R.I.P. PHATTY!
Caution: Beware of whores.........
1ofakindRR is offline
The Following User Says Thank You to 1ofakindRR For This Useful Post:
post #6 of 40 (permalink) Old 08-11-2011, 11:39 PM
SLAPS808's Avatar
Feedback Score: 56 reviews
very informative post dreamz! thanks for sharing.
SLAPS808 is offline
The Following User Says Thank You to SLAPS808 For This Useful Post:
post #7 of 40 (permalink) Old 08-12-2011, 01:07 AM
v-tec crx's Avatar
Feedback Score: 10 reviews
^ werd!!!!!
I am from CANADA, the land of poutine, back-bacon and GOOD BEER!!
2012 STREET BIKE OF THE YEAR
v-tec crx is offline
post #8 of 40 (permalink) Old 08-12-2011, 02:54 PM Thread Starter
dreamzboy's Avatar
Lol. I knew you guys aren't as cold hearted.
Love the forum & it's a pleasure contributing to it.
post #9 of 40 (permalink) Old 09-20-2011, 05:13 AM
What's Honda spec for the service interval on valve adjustments? I just assumed it was like 50k or something stupid that I'd never see...
nick5446 is offline
post #10 of 40 (permalink) Old 09-20-2011, 05:58 AM
**Miss O'Seven BOTY 2011**
Moeman's Avatar
Images: 646
Feedback Score: 148 reviews
Awesoem detailed write up thanks man
Honrary Chairman
Moeman is offline
post #11 of 40 (permalink) Old 09-26-2011, 10:26 PM Thread Starter
dreamzboy's Avatar
Manual suggested inspection at every 16Kmi. I procrastinated to 50Kmi and of course all 14/16 valves needed to be adjusted. By how far? By 0.001" to 0.002".
....and thanks to everyone for the support.
The Following User Says Thank You to dreamzboy For This Useful Post:
post #12 of 40 (permalink) Old 09-26-2011, 11:55 PM
EP3hatch03's Avatar
Great write up and thanks for doing that! I will be doing valve adjustment this winter.
Sent from my Motorcycle iPad 2 app
I am Chris
2009 Honda CBR600RR
CCS #520
EP3hatch03 is offline
post #13 of 40 (permalink) Old 09-28-2011, 11:39 PM
fallout's Avatar
So you're saying it's not necessary even at 50k miles?
Great write up btw.
fallout is offline
post #14 of 40 (permalink) Old 09-28-2011, 11:58 PM
carl22's Avatar
OMG!!! MOST EPC THREAD EVER!!! I was going to do this and was waiting for this perfect write up, Thank you!!!
carl22 is offline
post #15 of 40 (permalink) Old 10-04-2011, 06:52 AM
kal1fornia's Avatar
Will definitely use this! Thanks
Sent from my HTC Wildfire S A510e using Motorcycle App
kal1fornia is offline
post #16 of 40 (permalink) Old 10-14-2011, 04:39 AM Thread Starter
dreamzboy's Avatar
I was waiting just like everyone else until my bike hit 50K and I cannot wait any longer. I had to bite the bullet and go at it.
post #17 of 40 (permalink) Old 10-14-2011, 04:44 AM Thread Starter
dreamzboy's Avatar
Great write up btw.
It IS necessary. I'm glad I did it after finding out that 14 out of 16 valves on my bike were out of spec. I feel safer and I would like to keep my bike running smoothly that's why I had to adjust it. I recommend you should check at 16/32Kmi per service manual, but I'm just giving you a rough idea of how long you can delay this project and by how much the shims fall out of spec.
For most people, they'll never get to 50Kmi to perform this adjustment. Just to be clear, 50Kmi is not a miracle number. I just happened to be that lazy. Other bike may get away with 60-80Kmi or fall short at 32kmi depending on how they ride, street or track, aggressive or not. If you're planning keep your bike for awhile, it doesn't hurt to adjust it.
post #18 of 40 (permalink) Old 10-14-2011, 09:01 AM
Nico's Avatar
Well done mate, very well written!
Nico is offline
Old 10-19-2011, 04:05 PM
mewtwo
This message has been deleted by Nico. Reason: Spam and/or unwanted content
post #19 of 40 (permalink) Old 12-03-2011, 01:54 PM
Westtt80's Avatar
this is the perfect thread for me! Thank you
03 CBR 600RR
Angel Eyes
Blue LED underglow
Blue LED gauges
Hot Bodies Flush Turns
Integrated Tail
Fender eliminator
Custom License plate mount
55w 10000K HID
Lowered
Yoshimura Rs-5
PC-3
Westtt80 is offline
post #20 of 40 (permalink) Old 08-28-2012, 04:58 PM
Very nice thread....So I measured all my valves after 33k miles - and Only 1 of this is off (1 of the cyc 2 intakes) but only by .001" ....Is it worth changing the shim? Will they have a shim just .001" larger than my current one?
Thanks
Mint is offline
post #21 of 40 (permalink) Old 08-31-2012, 01:55 AM
Nico's Avatar
So is it 0.001" more than the tolerance allows or 0.001" out from the nominal?
Nico is offline
post #22 of 40 (permalink) Old 08-31-2012, 07:12 PM
.001 out of tolerance...it was .006 clearance instead of the nominal .008
I changed the shim anyway - i was already that far into the bike I might as well have.
Waiting on throttle cables in the mail before i can see if I successfully put the bike back together without bending a valve from misaligned cams
Mint is offline
post #23 of 40 (permalink) Old 08-31-2012, 11:54 PM
Nico's Avatar
Good call. If it had have been in the tolerance I wouldn't have worried about it but once it's out... time to do something about it.
What did you shim it back to? I would have gone back to 0.008 - 0.009...
Nico is offline
post #24 of 40 (permalink) Old 09-03-2012, 11:09 AM
zbrasnsoutafrica's Avatar
kick arse write up... seems like the link to cbrworld.net isnt working on the work computers, but i stumbled on this write up!! saved me lots of money here. good detailed pics and tips. thanks!
zbrasnsoutafrica is offline
post #25 of 40 (permalink) Old 09-04-2012, 07:18 AM
Nico's Avatar
Doesn't work at all any more as far as I know...
Nico is offline
post #26 of 40 (permalink) Old 09-05-2012, 04:04 AM
I shimmed it back to .008 - just 1 shim size difference.
Kind of disappointed after all that work only 1 shim was off though after 33k miles
Mint is offline
post #27 of 40 (permalink) Old 09-19-2012, 06:10 PM Thread Starter
dreamzboy's Avatar
Well at least now people know how long they can ride before doing this.
The cbr forum link doesn't work but within Moeman's post, someone copied and pasted it in the thread. Should be in the same link toward the bottom.
post #28 of 40 (permalink) Old 09-23-2012, 06:53 PM
BOTM Winner 12/13
i want to to this, but im afraid i mess it up, it seems complicated. my bike has about 29,000 miles and im not sure if it was ever done
shylock is offline
post #29 of 40 (permalink) Old 06-09-2014, 11:12 PM
hey guys, if my clearances on my inlet valve are just within spec, is it worth doing the shims anyways?
my inlets are reading 0.18mm, specs say 0.20mm +/- 0.03mm
my exhaust are reading 0.20mm, specs say 0.28mm +/- 0.03mm, since i'm going to be doing my exhaust shims, should i just do the inlets since i have to rip out all the cam stuff?
crzie is offline
post #30 of 40 (permalink) Old 06-10-2014, 12:07 AM Thread Starter
dreamzboy's Avatar
If you're going to replace it mind as well get everything within spec. If it still is, then you don't need to. It's really your call. If mine were to sit at the border line, I would rather have it sit right at the middle of the spec. It will make you happy as well as the bike.
crzie (06-10-2014)
Human Verification
