HELP!Should I/Can I JB WELD my Lower crankcase bolt?? - 600RR.net
DIY Write up's This forum should be used for any step by step descriptions of a job you are tackling. Pictures are a big help to clarify the process
post #1 of 12 (permalink) Old 11-02-2012, 09:00 AM Thread Starter
Unhappy HELP!Should I/Can I JB WELD my Lower crankcase bolt??
yea the bolt hole from the right frame bolt (as seated) snapped in half during an accident and well im wondering if its ok to just put jb weld on it and mold the missing piece back as in packing tons of jb weld to ressemble the missing piece..... only problem is im wondering if ill be able to remove the bolt in the future if needed it be.
picture link of damage http://i576.photobucket.com/albums/s...guez/photo.jpg
Asiel is offline
post #2 of 12 (permalink) Old 11-02-2012, 09:12 AM
edelbrock231's Avatar
Take the bolt out. Brake clean the piss out of it. Use quick steel not jb weld. Retap it. Stronger then new. We use quick steel on intake mainfolds and crap when porting them out not problems at all. Guy w a rotary has fixed 4 blocks that I've seen with it no problems at al
Sent from my SPH-D700 using Motorcycle.com Free App
edelbrock231 is offline
The Following 3 Users Say Thank You to edelbrock231 For This Useful Post:
Asiel (11-02-2012), dixon cider (10-30-2016), PdubRR (01-10-2016)
post #3 of 12 (permalink) Old 11-02-2012, 09:17 AM
Pythonidae's Avatar
use a dowel the size of the bolt shaft without the thread, quick steel as mentioned, carve it out with a dremel to bring it back to the original shape (exterior) then remove the rod and tap a new thread. quick steel is the bomb for engine cases, as long as it is not structural. It also fills engine case rash damage like superglue :-)
edit: and get a new bolt, yours has red hair, and thus no soul.
Pythonidae is offline
The Following User Says Thank You to Pythonidae For This Useful Post:
Asiel (11-02-2012)
post #4 of 12 (permalink) Old 11-02-2012, 09:21 AM
Quick steel: the mans playdoh
post #5 of 12 (permalink) Old 11-02-2012, 09:37 AM Thread Starter
ok but how can i maintain the circumference of the hole when applying the quick steel since there wont be a bolt in there ?
can i just drill a hole? then retap?
nvm read the second reply. lol thanks! i feel alot better now.
Asiel is offline
post #6 of 12 (permalink) Old 11-02-2012, 09:57 AM Thread Starter
how do i prevent the quick steel from fusing to the dowel? or is there a sertain material dowel i can use?
Asiel is offline
post #7 of 12 (permalink) Old 11-02-2012, 10:53 AM
You can do a super light coat of liek grease or pertol jlly to it. But if yu get even slighly bit on case iwont stick there wiether.. if youkeep bolt in it maybe w wd40 on threads you could porbbly turn the bolt back out after and retap then
The Following User Says Thank You to edelbrock231 For This Useful Post:
Asiel (11-02-2012)
post #8 of 12 (permalink) Old 11-05-2012, 03:34 AM
Pythonidae's Avatar
Don't use metal to plug hole. It will become a permanent fixture, dowel can easily be drilled if necessary
post #9 of 12 (permalink) Old 11-26-2012, 04:19 PM
motoguy415's Avatar
Weld and retap !
motoguy415 is offline
The Following User Says Thank You to motoguy415 For This Useful Post:
post #10 of 12 (permalink) Old 01-09-2016, 11:59 PM
how did you solve the problem? i kinda have the same problem
jonarvayo is offline
post #11 of 12 (permalink) Old 01-10-2016, 08:50 PM
FightingChance's Avatar
Feedback Score: 10 reviews
This happened to my bike after a bad frame slider install.
I was fortunate to find a welder who could build up the area and re-tap it, with the engine in frame. The broken off chunk was not re-used.
This is a load bearing point; the frame twists slightly and the engine casing has to resist this. The torque is 40lb-ft for that bolt; I don't think JB weld would be good enough for that.
FightingChance is offline
The Following User Says Thank You to FightingChance For This Useful Post:
post #12 of 12 (permalink) Old 03-12-2016, 06:18 PM
Had the same problem a few days ago - it broke during removal of the bolt to fit crash bungs. Had it steel welded and re-tap- good as new!
RydaWillz is offline
The Following User Says Thank You to RydaWillz For This Useful Post:
Human Verification
