how much oil you put on the engine. - 600RR.net
post #1 of 25 (permalink) Old 05-06-2008, 01:27 AM Thread Starter
oswaldfik's Avatar
hey! i see that the engine say 599 cm3 so is not even a litter of oil? is that the right amount of oil? or i have to put some more. is my first time put in the oil to the engine, so that is just my doubt cos i was going to buy the gallon of oil.
'06 600rr orange tribal SOLD
'07 CBR600RR Black w/Red
Smoke WindScreen
2Wheels Short Levers Black
Shogun Bar ends
Renthal Grips
Swing Arm Sliders carbon look
Sliders Carbon look
Ebc Front double H brake pads
Ebc Rear double H brake pads
Ddm HID Kit 5k w/35 Slim B.
DNA AIR FILTER
GEAR.
Alpinestars Textile Jacket
Teknic Chicane Leather Jacket
Nexx XR1R Carbon White
AGV Ti Tech Rossi IL LAUREATO replica
AGV GP Tech Super Sic LE Replica
Shoei RF1000 Jocker
oswaldfik is offline
post #2 of 25 (permalink) Old 05-06-2008, 01:28 AM
Lifetime Premium
Just2EZ05's Avatar
Feedback Score: 14 reviews
Just2EZ05 is offline
post #3 of 25 (permalink) Old 05-06-2008, 01:31 AM
murphdog1411's Avatar
Images: 94
takes 3L of oil 599 cm3 is engine size ......... cm3 = cubic cenimeters = cc 599cc :-P
murphdog1411 is offline
post #4 of 25 (permalink) Old 05-06-2008, 02:11 AM Thread Starter
oswaldfik's Avatar
tooooooooooouuuuuuuuu!!! sorry guys LOL oooo my god!! i think was the amount of the oil cos in the MX bikes say the amount of oil there, sorry :S but thanx any way. i know hwta cm2 means. it was my big mistake ok.LOL
Smoke WindScreen
Shogun Bar ends
Renthal Grips
Sliders Carbon look
DNA AIR FILTER
GEAR.
Shoei RF1000 Jocker
post #5 of 25 (permalink) Old 05-06-2008, 03:41 AM
OveRReV's Avatar
Images: 16
oil capacity with filter change is 3 liters, 2.6 liters if you didn't change the filter.
599cm3 is the engine displacement.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #6 of 25 (permalink) Old 05-06-2008, 10:26 AM
maxpowers's Avatar
Feedback Score: 6 reviews
The manual has a good step-by-step for this (the owners manual that comes with the bike).
The step that some may skip (which is important), is running the bike after the change, letting it sit and re-checking the level.....it will go down a bit.
maxpowers is offline
The Following User Says Thank You to maxpowers For This Useful Post:
Rad Rage (11-04-2012)
post #7 of 25 (permalink) Old 05-06-2008, 10:06 PM
shraz's Avatar
is the oil capacity the same for 03-06 to 07-08?
I put 3 quarts in my 03 with the oil filter change and was perfect.
// ShraZ
F4i - Quick Maintenance
MSS - Review Your Gear
shraz is offline
post #8 of 25 (permalink) Old 05-06-2008, 10:46 PM
jjtraver's Avatar
The service manual says after oil and filter change.
2.8 liter (3.0 US qt, 2.5 Imp qt)
I would also recommend putting the oil inside the motor and not on it.
jjtraver is offline
post #9 of 25 (permalink) Old 05-06-2008, 11:07 PM
360jeepboy's Avatar
360jeepboy is offline
post #10 of 25 (permalink) Old 05-06-2008, 11:10 PM
Johnmark101's Avatar
Drain the old oil, install a new filter. Put in 3 quarts of the oil of your choice. Start the bike and let it run for a couple minutes. Shut it off and let it set for a bit. Then check the level in the sight glass and you should be fine. Add a bit if needed to bring the level to the full mark.
When checking the oil level, make sure the bike is upright.
Power is nothing without control.
2003 Honda VFR
2007 Honda CBR 600RR
Johnmark101 is offline
The Following User Says Thank You to Johnmark101 For This Useful Post:
MAEniac (10-25-2012)
post #11 of 25 (permalink) Old 05-07-2008, 12:24 AM
Upright but not on a stand; bike should be level. I made that folly when I changed my oil the first time.
Bike on rear stand, oil level perfect as described above. Take it off the stand, too much oil. eff !!!
CBR600RR07 (Blue)
- Scorpion EXO-700 Fury (White/Black) - A* SMX Airflo (Blue) - TourMaster Overpants (Black) -
- Held Phantoms (Black) - Oxtar TCS Evo RX (Grey/Black) -
- Leo Vince Exhaust - Woodcraft Framesliders & Spools - Tapeworks Dropshadow Kit - eBay Rim Stripes -
ettore is offline
post #12 of 25 (permalink) Old 05-07-2008, 12:27 AM
asewamu's Avatar
3 is too much in a 07! lol only takes about 2.8 qts with filter change at full operating temp.
BT016 front and rear tires
CBR Heaven FE
Lockhart Phillips Swingarm Spool/Sliders
Vortex Frame Sliders
Two Bros Slip on M2 custom chopped 3" shorter
http://www.myspace.com/monstertaco
http://www.youtube.com/watch?v=lNTqs4WXNgo
07 cbr600rr
05 colorado LS
asewamu is offline
post #13 of 25 (permalink) Old 05-07-2008, 03:23 PM
Lifetime Premium
Just2EZ05's Avatar
im sure you will be A OK with an even 3
post #14 of 25 (permalink) Old 05-07-2008, 11:56 PM
asewamu's Avatar
when I put three in it its quite a ways up from the top of the glass eye on my stands. they say its suppost to be in the middle. I put three and had to pump some out.. it sucked
CBR Heaven FE
07 cbr600rr
05 colorado LS
asewamu is offline
post #15 of 25 (permalink) Old 05-31-2008, 01:11 AM
Cbr6rydah's Avatar
Thanks. Good stuff here. 3 qts it is for my 06. Good look
Cbr6rydah is offline
post #16 of 25 (permalink) Old 05-31-2008, 01:56 AM
Knightslugger
Posts: n/a
that's all i buy is 3 qts and install it all. hell i dont even look at the window,
post #17 of 25 (permalink) Old 05-31-2008, 02:05 AM
Stevo600rr's Avatar
Just wondering how far are you filling the oil up in the oil gauge? Cause the manual says about 3 quarts of oil. I use that and it gets half way perfectly.
Stevo600rr is offline
post #18 of 25 (permalink) Old 06-01-2008, 09:33 PM
Cbr6rydah's Avatar
Hey quick comment. I went to my local dealer here in Laurel MD (Heyser Cycles) thinking that I would pick up 3 qts of 100% synthetic Amsoil and either an Amsoil or K&N filter. First up I told them I had an 06 and they all started screaming, I needed 4 quarts because 06's take 3.8 qts. Secondly, they didn't have any Amsoil. The only synthetic they had was Motul. I was going to settle (I had my mind set on the Amsoil) for the Motul, but then I go to get the filter behind the counter, and the only one they have for me is an original Honda filter. Needless to say, I was pissed and decided to wait to get the best I could for my baby. I just got her, and I must take care of her.
post #19 of 25 (permalink) Old 06-02-2008, 12:13 AM
Knightslugger
Posts: n/a
Holy shi t. are you serious? Who was the retard telling you this information?!! 2003-2006 motors take 3.1 US Qts, 2007-2008 take 3.0 US Qts both with a new Oil Filter. After a Full engine disassembly 2003-2008 motors take 3.7 US Qts.
If you feel like it, go back, buy your 3 qts of Motul (it's fine) and slap the bitch (that they are) who was telling you otherwise, and maybe drop the bomb that you'll be telling other people who use their shop to beware of overfilled crankcases (which can lead to massive or catastrophic engine failure), and the shop. The following is STRAIGHT from the CBR600RR Bible, Old and New Testaments:
2003-2006
2007-2008
post #20 of 25 (permalink) Old 06-02-2008, 03:06 AM
Cbr6rydah's Avatar
I knew you were right. I appreciate your help. I am just disappointed, that if I do need to get something done not covered on the forum, or that I can not do; I now have to find another service center. Oh well, at least I found out early with no pain donel. RAT BASTARDS tried to set me up for f*cking destruction. Good thing I was not influenced by them and their red cycle shirts. Appox on them! Talked to George at the Amsoil Group. Thanks again Knightslugger. C6r
post #21 of 25 (permalink) Old 06-02-2008, 04:01 AM
I know this is probably a stupid question, but do you use synthetic oil or mineral? I'm thinking synthetic, but my manual doesn't say ...
Captain. is offline
post #22 of 25 (permalink) Old 06-02-2008, 09:13 AM
Knightslugger
Posts: n/a
GN4 is mineral based, but is OK oil to about 1500 miles or so. YMMV so it's best to get an oil analysis done on whatever oil you want to stick with. Going to Amsoil from GN4 bumped my OCI (Oil Change Interval) from 1500 to 2500+. I'll be doing another UOA (Used Oil Analysys) at 2500 to see what they say!
post #23 of 25 (permalink) Old 06-07-2009, 09:41 PM
OnyxRR's Avatar
Yeah I talked to one of the mechanics of Heyser Cycle at a party back when. He didn't seem to know what he was talking about or at least when it came to sportbikes. I wouldn't recommend letting them work on your bike. But yeah the Honda oil filters for our bikes work just as good as any other filter in my opinion. And if you are gonna get Motul synthetic oil make sure you stay away from their "Double Ester" line. That stuff makes your clutch slip like crazy. Took me awhile to figure out what the culprit was. Switched back to honda oil and everything was ok, for the most part.
2006 600RR
50,000 miles
Painted Satin Flat Black (looping sucks)
Yoshimura RS-5 Slip-on
HID kit
Front flushmounts
DIY fender Eliminator
Intake gutted and resonators removed
-1 in the front.
OnyxRR is offline
post #24 of 25 (permalink) Old 06-07-2009, 09:45 PM
stevewfl's Avatar
removed
removed
2008 R1 YAMAHA in pornstar nipple red
2007 CBR600RR
stevewfl is offline
post #25 of 25 (permalink) Old 06-08-2009, 12:40 AM
LOL, stevewfl... weren't you the guy that was pushing Rotella T in all of the amsoil threads? Now you appear to be pushing Amsoil...
What's the deal? What made you switch?
pbeaul is offline
Human Verification
