Fram oil filter number?? - 600RR.net
post #1 of 26 (permalink) Old 05-12-2008, 06:42 PM Thread Starter
TRUTH's Avatar
Hey guys,
I looked in the Fram book at my local store and the 03 600 RR wasn't listed. I was wondering if anyone knew the number for the Fram oil filter for the 03? Thanks, Frank R.
2003 600RR-Jardine RT-1, PC III,520 Conversion
(more to come!)
2006 Polaris IQ440
1998 FZR600--FOR SALE
TRUTH is offline
post #2 of 26 (permalink) Old 05-12-2008, 06:56 PM
Knightslugger
Posts: n/a
I'll be polite. Don't use a Fram filter. Put the book down and grab a Pureolator PureONE Filter, PL14612 or PL14610 (which is a touch longer but will clear stock exhaust manifolds).
If you get the PL14610, grab the Gold colored one with the grippy stuff on the can. They even have a rebate program, you get $2 back on your purchase of 1 PureONE oil filter.
Oh look at that, a wisconsinite! ha!
wow look at that... 10k posts... holy sh*t.
post #3 of 26 (permalink) Old 05-12-2008, 07:36 PM
Originally Posted by TRUTH View Post
Hey guys,
Fram PH6607 I use the same filter works great. I am in need of an oil change as well.
01-06 F4i
03-08 600RR
datnguyen24 is offline
post #4 of 26 (permalink) Old 05-13-2008, 12:09 AM
Images: 58
K&N 204. K&N filters have the 17mm nut attached for easy removal.
ww73 is offline
post #5 of 26 (permalink) Old 05-13-2008, 06:56 PM Thread Starter
TRUTH's Avatar
Hey guys,
Thanks for the help. I always ran K&N in my 450 MXer. I went ahead and picked up the pureolater pl 14612. I will use a K&N for my next change. Thanks guys! Frank R.
(more to come!)
2006 Polaris IQ440
TRUTH is offline
post #6 of 26 (permalink) Old 05-13-2008, 09:48 PM
Feedback Score: 7 reviews
either that pure
or the mobil m108
hell even the plain oem filter is better than a fram
do a search on the internet for motorcycle oil filter reviews
Fram is noted for the famous quote
"this is an example of how not to build a filter"
RShackleford is offline
post #7 of 26 (permalink) Old 05-14-2008, 04:15 PM
ferax5's Avatar
I used the Mobil 1-m108 filter for my first oil change. Didn't hear any bad things about it and my bike didn't explode, so I'm assuming it is working well.
2008 Honda CBR 600RR Pearl Orange
2006 Kawasaki EX 250
ferax5 is offline
post #8 of 26 (permalink) Old 05-14-2008, 05:26 PM
Fram filters are garbage. I usually run a Wix oil filter in everything I own, but I do have a K&N on my bike. The attached nut is very handy for removing the oil filter. No more screw driver and hammer removals.
teamgreen02 is offline
post #9 of 26 (permalink) Old 05-14-2008, 05:34 PM
frams are junk period.
mobil is made by champ so any of the champ sister companies are good also (bosch, champ, mopar, supertech)
purulator are good also
wix is good
any of these three anything else is pretty much junk
now take in mind on what other filters these companies make
grindpunk16 is offline
post #10 of 26 (permalink) Old 05-14-2008, 09:00 PM
Amsoil Dealer Group's Avatar
What oil filter feature do you look for when buying an oil filter? Is it micron level, length of service, can thickness, type of material of the anti-drain back valve, PSID setting of the internal by-pass valve, nut on the end for removal, anti bursting pressure, color of can or what?
george
ADG
Amsoil Dealer Group is offline
post #11 of 26 (permalink) Old 05-14-2008, 09:17 PM
em2b96p's Avatar
01-06 F4i
03-08 600RR
agreed! i use the same filter number 6607. its also the same filter as my 2002 civic EX.
20k miles and 0 problems
em2b96p is offline
post #12 of 26 (permalink) Old 05-14-2008, 09:41 PM
george
ADG
i look for the one that has been recommended by people that have cut them open and looked at what is inside.
http://www.calsci.com/motorcycleinfo/FilterStudy.html
some quotes from above
amsoil-a flawed superior filter
Fram-cardboard
K&N-average filter with a 6$ nut on the end
mobil m108-nice filter media but not much of it, smaller unit (so it goes well behind headers)
Pure One PL14610- an example of fiters should be made
http://www.tobycreek.org/oil_filters/
quotes from this one
If anything, the Fram will show you how NOT to build a high performance oil filter
The Amsoil filter internally looks very similar to the Wix filter, but they are not the same. Semi-O ring gasket, well cut threads with no apparent burrs.
honda oem
This is how a high-performance oil filter should be built.
K&N
This could be my new favorite filter
mobil 1
This is a well-constructed filter, which Mobil 1 touts as having 98% single-pass particle filtration at 10 to 20 microns, and multiple-pass efficiency of 95% (vs. 80% for the average filter).
post #13 of 26 (permalink) Old 05-14-2008, 10:59 PM
ferax5's Avatar
Thanks for the links RShackleford. Looks like I'll be trying out the Pure One filter next. Half the price of Mobil 1 too. Sweet.
ferax5 is offline
post #14 of 26 (permalink) Old 05-14-2008, 11:01 PM
Knightslugger
Posts: n/a
more than half! Check it out!
http://www.pureoil.com/documents/reb...ebate_form.pdf
post #15 of 26 (permalink) Old 05-15-2008, 06:42 PM
Fram-cardboard
honda oem
K&N
mobil 1
The test on the Amsoil one is of the older version. There is no filters on the market that look like an Amsoil nano fiber filter. I cut many filters apart over the last 27 years and other than construction you can not tell how good a filter will perform while in service with the naked eye.
george
ADG
post #16 of 26 (permalink) Old 05-15-2008, 07:49 PM
george
ADG
so which one do you recommend ( i wonder)
post #17 of 26 (permalink) Old 05-20-2008, 02:59 PM
ferax5's Avatar
I ordered some Pure One filters (PL14612) on Amazon. $9.88 for a two pack. Free shipping if you spend $25+.
$2.94 per filter after rebate.
ferax5 is offline
post #18 of 26 (permalink) Old 05-21-2008, 10:03 PM
crvlvr's Avatar
I use nothing but OEM filters. Its just not worth trying to save a few bucks on one of the most important parts of your bike.
All filters have an excess pressure relief valve. as you engine revs and the pressure within the filter increases (due to a largeer volume of oil flowing through it), the relief valve inside the filter opens up allowing UNFILTERED oil to return to the engine. So, althogh the filter may "seem" to be working, it is not filtering any oil when the relief valve opens. you might aswell be throwing the money you spend on substandard filters in the trash can.
crvlvr is offline
post #19 of 26 (permalink) Old 05-22-2008, 12:15 AM
Knightslugger
Posts: n/a
^ all true if the relief valve psi's are different...
post #20 of 26 (permalink) Old 05-23-2008, 07:03 PM
Are Honda Civic Filters the same as Honda OEM '07 RR filters ?
Just wondering , cuz the Civic filters are not too overpriced.
bare is offline
post #21 of 26 (permalink) Old 05-23-2008, 08:40 PM
you do realize that the relief valve only comes on if the filter gets clogged.
the substandard filter is the honda that opens at a lower oil psi than the mobil.
even unfiltered oil is better than no oil
the mobil m108 relief valve opens when the engine oil pressure gets down to 17psi
the honda oil filter wont open until the oil pressure gets down to 8psi
do some research
Use the search, it wont bite you.
post #22 of 26 (permalink) Old 05-23-2008, 08:41 PM
what does this have to do with anything other than trying to get a post count up
post #23 of 26 (permalink) Old 05-23-2008, 10:08 PM
This copied from the 1000rr site.
Originally Posted by goracer
Is this a car filter or motorcycle as I can not find any Purolator motorcycle filter for any Honda newer then the 959?
(Quote) This is what I got from emailing the Purolator website contact: (Quote)
Unfortunately we do not manufacture PureOne oil filters for motorcycles. We do have a separate line of motorcycle filters that are equivalent to the OE filter. Your bike will take the ML16817. The PureOne has never been tested on bikes because of the restriction of oil flow. Therefore no warranty will be provided on it.
Kempf Stark
Technical Assistance Specialist
Filtration
Robert Bosch LLC
Purolator Division
800.526.4250
post #24 of 26 (permalink) Old 05-23-2008, 10:32 PM
well duh of course they are going to tell you that it wont work
that is called product liability
post #25 of 26 (permalink) Old 11-23-2014, 11:08 PM
tylerjoe167's Avatar
I have found luck with the fram and K&n, some people have to use several different brands until they find one that works best for them
tylerjoe167 is offline
post #26 of 26 (permalink) Old 11-24-2014, 02:01 AM
OzHonda's Avatar
Do it right, buy an OEM one. :)
Ride carefully - You are invisible.
FB | YT
Current: 2003 CBR600RR - Fuelly
Sold: 2012 CBR250R
Mods:
OzHonda is offline
Human Verification
