08 CBR oil change walk through. - 600RR.net
post #1 of 59 (permalink) Old 03-18-2010, 10:12 PM Thread Starter
live4ever83's Avatar
So I see a lot of write-ups about wether to take the fairing off or not and blah blah blah... so here is my step by step. I decided to take the clutch side fairing off which gives you really easy access to the oil filter. So here is what you need. Make sure you properly dispose of your oil... Flushing it down the toilet is not a good way of getting rid of oil! Honda 4-stroke 10w-40 motor oil, oem oil filter, oil catcher, funnel and tin foil
So the side fairing comes off easy enough this gives really easy access to the oil filter.
So lets drain us some oil
once oil is drained we'll move on to the oil filter. once the oil is drained remember to tighten the drain plug so oil actually stays in the motorcycle!
I always just have my oil filters hand tightened so with a little force it should come right off. This is where we want to use the tin foil I just placed the tin foil under the oil filter as I removed it and funneled it down in between the headers. This is optional, if you spill some oil on the headers it will burn of and stink but no use crying over spilled milk.
Next we will install the new oil filter make sure you dip your finger in the oil and run it around the edge of the new oil filter. New oil filter fits right in with no problem and looks much cleaner then the older one. :)
Honda calls for 3.1 quarts of oil, I only ended up using 3 and it filled it just fine.
I added about 3 quarts started it up and ran it for about 4 minutes. Remember to check the oil level window.
the photo above is with the Bike on the kick stand make sure you level out the bike so you actually see oil in the oil window, If you see oil filled up in the window while the bike is on its kick stand, you officially have to much oil in your Bike. Reinstall side fairing and your done! In total took me about 45 minutes and only cost be about 35 dollars. Well worth it! hope this helps if you have any questions just ask!
2008 Honda CBR 600RR Graffiti Edition
DDM 10000K HID
Flush mount turn signals
Jardine Dual Outlet Carbon Fiber Exhaust
live4ever83 is offline
The Following 9 Users Say Thank You to live4ever83 For This Useful Post:
Bwalton (07-02-2012), dcdomain (04-14-2011), Kit Fox (04-26-2011), Kostelnik (06-12-2013), Royal38 (03-19-2013), RR2D2 (05-02-2013), scruffydog (01-22-2012), Timbo4506 (06-08-2012), Treys (04-24-2013)
post #2 of 59 (permalink) Old 03-18-2010, 10:25 PM
**Miss O'Seven BOTY 2011**
Moeman's Avatar
Images: 647
Feedback Score: 148 reviews
Congrats on a brilliant write up man job well done you got your first sticky
Honrary Chairman
Deafet may serve as well as victory to shake the soul & let the glory out
A great deal of intelligence can be invested in ignorance when the need for illusion is deep
Moeman is offline
post #3 of 59 (permalink) Old 04-17-2010, 10:07 PM
dvl79's Avatar
part number on the oil filter?? are they all the same? i have the 09
dvl79 is offline
post #4 of 59 (permalink) Old 04-18-2010, 01:20 AM
Moeman's Avatar
Images: 647
All the same 03 to 09
Honrary Chairman
Moeman is offline
post #5 of 59 (permalink) Old 06-07-2010, 04:07 PM
Thanks for the help man.
jpmire is offline
post #6 of 59 (permalink) Old 06-21-2010, 10:22 PM
This just made everything alot easier. Thanks
jbennett4 is offline
post #7 of 59 (permalink) Old 06-21-2010, 10:23 PM
I hope its ok if a little oil gets on the headers.
post #8 of 59 (permalink) Old 06-23-2010, 02:05 AM
I changed my oil for the first time today and it was a piece of cake. Thanks for the sticky it was awesome.
post #9 of 59 (permalink) Old 06-26-2010, 11:34 PM Thread Starter
Glad I could help out. It's okay to get oil on the headers... it will just stink until it burns off. No harm no foul
DDM 10000K HID
post #10 of 59 (permalink) Old 06-27-2010, 12:12 AM
KooL4444's Avatar
Honda calls for 3 quarts with the change of the oil filter. But great write up otherwise.
08 CBR600RR Red/Black
Akrapovik Slip-On
Scorpio SR-i900R
1000RR Mirrors w/Signals
Proton Flushmounts
CNR Shorty Levers
Shogun Crash Kit
eGay FE Kit
KooL4444 is offline
post #11 of 59 (permalink) Old 07-13-2010, 05:56 AM
whoa you took your whole fairings off...isnt the bottom one sufficient?
rk604 is offline
post #12 of 59 (permalink) Old 07-16-2010, 10:47 AM Thread Starter
It probably is but I just found this easiest to get to the oil filter off. Truth be told you don't really need to take off any of the fairings. This way just seemed best to minimize oil spilling on the headers.
Cheers
DDM 10000K HID
post #13 of 59 (permalink) Old 08-03-2010, 05:31 AM
Nice write-up, thanks for posting that.
COBRA90GT is offline
The Following User Says Thank You to COBRA90GT For This Useful Post:
lotsofchops (06-15-2012)
post #14 of 59 (permalink) Old 08-03-2010, 06:18 AM
u took the whole side fairing off. the top and bottom are seperate on mine. im thinkin the 08 is the same. but good write up. wish i seen this back when i did an oil change the first time
chevelle1469 is offline
post #15 of 59 (permalink) Old 10-22-2010, 02:25 PM
2009CBR's Avatar
phew i had a bad feeling i would have to take my headers off this thread just made my day
2000 Suzuki Bandit 600S
2009 Honda CBR 600RR
Neon Green Underglow
Shogun Frame Sliders
Green Rim Tape
Proton Flushmounts
Hyperflo Exhaust
Black Chrome Midpipe
Puig db Dark Smoke Windscreen
Midpipe Heat Shield Flat Black
Tex Black Subframe/Passenger Peg&Bracket/Rearsets
PCV
Motovation Rear Axle Sliders
DDM HID kit 6k
Solo Seat Cowel
Custom pearl paint
helix spike bolts from jda custom
k&n high flow air filter
2009CBR is offline
post #16 of 59 (permalink) Old 10-22-2010, 06:56 PM
dickturpin 1976's Avatar
nice walk thru mate, thinking of an oil change wont need to look any further than here for info.
dickturpin 1976 is offline
post #17 of 59 (permalink) Old 11-21-2010, 03:19 PM
Orin's Avatar
Where did you buy the oil, filter, drain container? I'm going to do my first ever oil change and I've seen it done once on a car like 5 years ago so I kind of got the idea. I just dunno if I should just go to my local Autozone or do I need to get OEM specific stuff at the dealer?
I purchased a pre-owned 2009 Cbr 600rr that had its oil changed right before I purchased it from the dealer (it had 9,500 miles). Rode it for about 4 months and it now has around 11,000 miles and I'm getting it ready for winter storage.
Orin is offline
post #18 of 59 (permalink) Old 11-22-2010, 03:29 AM
TheRookie's Avatar
too many places to buy oils and filters just make sure what you get is pretty much motorcycle specific. Lot of people here just contact the Amsoil dealer guy here on the forums and order oil and filters through him. Usually arrives at your door within a week of your order or less.
TheRookie is offline
post #19 of 59 (permalink) Old 11-29-2010, 08:44 PM
Orin's Avatar
Mission acomplished!!!!!!!!!...though I encountered a couple problems, mainly due to me learning how to do it the first time. Got all my supplies at the same place I bought the bike from they are very helpful. Overall I would say this is a 15 minute job but it took me about an hour. After I put the fairings back on (F**k!) I realized I did not have to take off any fairings as I saw that they located everything easy access.
I rather clean up a little oil spill on the pipes than having to deal with fairings.
Orin is offline
post #20 of 59 (permalink) Old 12-12-2010, 04:59 AM
mpicanco01's Avatar
Feedback Score: 6 reviews
Greast Write Up! I'm sure it will help ALOT OF PEOPLE!
Motorcycle Maintenace 101, everyone should know how to
do this.
2005 CBR600RR:
- Leo Vince Caron/Carbon- Tripage Knight Rider - HID's 8000K - Flush Mounts -
- Driven D3 Grips - Pazzo Levers - Puig DB - BMC Race Filter - Shogun Sliders -
- PCV - Velocity Stacks - Vortex Gas Cap - Spiegler Brake Lines -
- Integrated Mirrors / Taillight - Galfer Wave Rotors-
2003 CBR600RR: (Project Bike -Build Coming Soon)
2003-2006 CBR600rr Parts For Sale:
http://www.600rr.net/vb/106-03-06-rr-parts/295244-swingarm-flush-mounts-sprockets-mirrors-shift-linkage-etc.html
http://www.facebook.com/profile.php?id=594611001
mpicanco01 is offline
post #21 of 59 (permalink) Old 12-27-2010, 08:28 PM
8700mxj's Avatar
This is awesome! This will be very helpful since im up for my first oil change. Thanks for the pics.
8700mxj is offline
post #22 of 59 (permalink) Old 01-22-2011, 08:54 PM
FL RR's Avatar
Just finished. Was easy-- really appreciate the post! Also, I've seen a lot of back and forth elsewhere on the forum about whether or not to remove the fairing. After seeing how simple that is, I wonder why it's even an issue. Even for a newb like me!
Thanks again
White '07 600RR "Eileen"
Competition Werkes FE kit
Puig light smoke racing screen
Pazzo short levers
To Be Continued...
FL RR is offline
post #23 of 59 (permalink) Old 01-31-2011, 08:17 PM
Anyone happen to know what oil filter cup will fit the OE filter?
Unregistered is offline
post #24 of 59 (permalink) Old 04-16-2011, 12:27 PM
Could you do all these with just the kick stand down on your bike or does it have to be on a special ramp or stand?? Also, did you just use a regular allen wrench to take the fairings off or what kind of tool did you use?
danieljogbn is offline
post #25 of 59 (permalink) Old 04-17-2011, 01:33 AM Thread Starter
I did it on the kick stand and truth be told you don't really need to take off a fairing if you would prefer not to. I felt it made the job easier. But if your okay with a little oil on the headers its not a big deal. and yeah just a regular allen wrench should do the trick. let me know if you need anything else
DDM 10000K HID
post #26 of 59 (permalink) Old 04-26-2011, 09:02 PM
TyRz's Avatar
Great write up man. I especially like the part about the oil window as well, good thing to give that kind of info to non mechanical types. This way they learn, and the fairings idea I think is great. It's always better for more accessibility when doing this stuff.
Screen-FX
~2008 Honda CBR 600RR Graffiti~
Hotbodies Black Tinted Windscreen~
Hotbodies CBR Smoke Flushmounts~
Honda Racing Tank Pads~
Progrip Carbon Fiber gascap Cover~
Akra Slip-On~
R&G Crash kit~
6000k DDM 55w HID Kit~
Custom LED Flasher Relay~
RSP's CF Tnk. panels, Mid & Lrg Inserts, & Exh. Shield
Trip's IT light
Trip's 12 LED Rear Psngr. pegs
MC's CF Headlight Corners
Trip's Adj Fe kit
On the Way~
Blue Accent lights
TyRz is offline
post #27 of 59 (permalink) Old 07-01-2011, 11:34 PM
PearlWhteRR's Avatar
so i changed my oil and i spilled some oil while i was taking the filter out.. when i turned on my bike and let it run for a bit... a few mins in my bike started to smoke up like crazy.. the source was from the pipes that are right under the filter.. will the smoke go away? what can i do to make it go away?
PearlWhteRR is offline
post #28 of 59 (permalink) Old 07-02-2011, 12:02 AM
The spilled oil will smoke off, no problem
You can search around for OIL ABSORBENT WIPES, they soak up oil and are great to have around. I reuse them most of the time. But they will wipe up any spilled oil better then a cloth rag.
Dartmouth is offline
post #29 of 59 (permalink) Old 07-02-2011, 01:19 PM
Banned
You're suppose to torque the drain plug on with a new gasket(washer) and even torque the OE filter on. 22 ft lbs for drain plug, 20 ft lbs for oil filter. Get a oil filter wrench that fits on the 3/8" torque wrench so it's easier. Otherwise a hand tightened filter on an o-ring style filter won't be reliable. That only works with oil filters with a thick gasket that is suppose to be turned 3/4's of a turn once the filter touches the baseplate. Oh and if you don't replace the drain plug gasket it will potentially leak.
midgear is offline
post #30 of 59 (permalink) Old 07-03-2011, 03:24 AM Thread Starter
Man raining on my day.
DDM 10000K HID
Human Verification
