oil at very top of window - 600RR.net
post #1 of 19 (permalink) Old 12-09-2012, 09:56 PM Thread Starter
JColmar's Avatar
I tried searching but am relegated to using my iPhone. it has trouble using the search field for some reason. I apologize for a redundant question.
I just changed my oil for the first time on my bike. it's a 12 600rr. when the bike was on the stand, the oil was 3/4 the way up between the lower and upper marks. when I put it down and balanced it upright. the bottom of the meniscus of oil is approx 2-3mm above the top line. I can just barely see air at the top of the window. hopefully my crude drawing will load so you can see what I mean.
my question is: is this too much oil? enough to do damage and/or get frothy? I suppose I could turkey baster some out of the feed hole but I'd rather not if I'm totally in the clear. thanks
JColmar is offline
post #2 of 19 (permalink) Old 12-09-2012, 10:13 PM
redlinernyc's Avatar
Feedback Score: 14 reviews
that's not enough to do any damage. Don't even worry about it. When you're about a quart or two over that's when you risk blowing some seals due to too much oil in the crank. You're fine. If it bothers you then you could always drain a bit out so that oil level is in the middle of the window.
edit: the guys who do wheelies a lot usually run a quart over the full mark and they are all fine.
Black 2006 600rr l SOLD Dec 2010
07 600rr - sold Aug 2011
07 white/silver 600rr - sold
Current: 2015 1000rr
redlinernyc is offline
post #3 of 19 (permalink) Old 12-09-2012, 10:27 PM
PattyK's Avatar
Have you ran the bike yet? Once you run it for a bit the level will drop down a touch once the oil starts circulating.
PattyK is offline
post #4 of 19 (permalink) Old 12-10-2012, 12:44 AM
run the motor for a minute, shut off and wait 2 mins.
bike vertical, measure oil level.
per manual....IIRC.
30k miles on my 09 doing so.
tary preisser is offline
post #5 of 19 (permalink) Old 12-10-2012, 12:55 AM Thread Starter
JColmar's Avatar
yes, I went for a pretty spirited run up the highway for about 10 miles. it's still at the top of the window.
JColmar is offline
post #6 of 19 (permalink) Old 12-10-2012, 08:39 AM
BOTM Winner 1/13
Nuttynu's Avatar
10 minutes burn out should fix it..
My Ride Report :
-Alaska,The Last Frontier
Nuttynu is offline
post #7 of 19 (permalink) Old 12-10-2012, 03:07 PM
Tyleronanrr's Avatar
Images: 2
As long as its not an extra half of a quart, you should be fine. If it really bothers you though, pop the drain plug off for a second or two.
Tyleronanrr is offline
post #8 of 19 (permalink) Old 12-10-2012, 07:49 PM
I'm a pretty lady!!!
weStTXgrEase_mOnKay's Avatar
guys ! let keep it clean untill we have at least a page of ingo then we can start blasting boobies. we dont want the net to have thread of troll at the time. thats u monkay
Hmmmmmmm.........
2012 Suzuki GSX-R1000
2W1R elCapitan
Alexander the Great
Happy Catholic
weStTXgrEase_mOnKay is offline
post #9 of 19 (permalink) Old 12-10-2012, 09:28 PM
pvn23's Avatar
If you have entirely flushed the oil, and replaced it with new oil, you should look for the capacity people usually fill it up to. Some people fill 3 quarts, others might only need 2 quarts. For me, when I did my oil change, I did 3 quarts and it filled up fine. After running the bike a bit, you saw the window (while on a stand) that the oil had probably gone down slightly. That's just because the oil is now in the engine.
However, if you filled it up properly it should be a full window again after you start up the bike again.
As long as you don't overfill the bike, it's fine.
pvn23 is offline
post #10 of 19 (permalink) Old 12-10-2012, 09:46 PM
BOTM Winner 1/13
Nuttynu's Avatar
Hmmmmmmm.........
bwahah , that was was a legetiment solution
My Ride Report :
Nuttynu is offline
post #11 of 19 (permalink) Old 12-10-2012, 10:04 PM
Posting to post!!!
2W1R elCapitan
Alexander the Great
Happy Catholic
post #12 of 19 (permalink) Old 12-11-2012, 12:56 AM
Tater S's Avatar
Originally Posted by westtxgrease_monkay View Post
guys ! Let keep it clean untill we have at least a page of ingo then we can start blasting boobies.
Hmmmmmmm.........
BOOyah! In!!!
__________________________________________________ ____________________________________
Thank you for purchasing a 600rr as your first bike.
The odds are strong that you will successfully add to our classified section and help lower parts prices
Crash Stats: Length of ownership
http://www.600rr.net/vb/20-polls-research/313730-crash-stats-length-ownership.html
Tater S is offline
The Following User Says Thank You to Tater S For This Useful Post:
weStTXgrEase_mOnKay (12-11-2012)
post #13 of 19 (permalink) Old 12-11-2012, 01:00 AM
Tater S's Avatar
Boobies and Lubricant
This thread is going to be full of WIN!
http://www.600rr.net/vb/showthread.php?t=313730
Tater S is offline
post #14 of 19 (permalink) Old 12-11-2012, 01:17 AM
^^^^ Hahaha Wooooo!!!!!!!!!! You sir knows what's up!!!!
2W1R elCapitan
Alexander the Great
Happy Catholic
post #15 of 19 (permalink) Old 12-11-2012, 03:34 PM Thread Starter
JColmar's Avatar
after entirely flushing the oil, I initially added exactly 3 quarts. after following the steps outlined in the owners manual, I checked the oil and found it to be just above the top line on the window. last night I loosened the pan plug and let maybe 8 ounces of oil drip out. I'll check it again once I can wheel the bike out of my living room haha. sitting cold, the oil is about 3/4 up the sight glass
JColmar is offline
post #16 of 19 (permalink) Old 12-11-2012, 04:37 PM
rkoe17's Avatar
'nuff said
"I plan on living fast and dying young!"
rkoe17 is offline
post #17 of 19 (permalink) Old 12-11-2012, 04:53 PM
pvn23's Avatar
Doesn't hurt to go over 3 quarts when you add more. Mines cover the window entirely so I'm fine with it. Nothing overflowed.
pvn23 is offline
post #18 of 19 (permalink) Old 12-16-2012, 06:50 PM
rm600rr's Avatar
im just a tad bit over, still running fine.
07 HONDA CBR 600rr
rm600rr is offline
post #19 of 19 (permalink) Old 12-16-2012, 11:22 PM
BOTM Winner 09/14
qteter's Avatar
Hondas don't have issues if you go over.. It's only about a quarter quart over so don't fret it.. That's where I run my bike
qteter is offline
Human Verification
