Oil pan replacement - 600RR.net
post #1 of 7 (permalink) Old 04-20-2017, 10:54 PM Thread Starter
Oil pan replacement
Hey .net!! I was trying to replace a stripped drain bolt (prior owner used channel locks to tighter it LOL) and noticed a sizeable crack, as you can see in the pic, from him using a jack directly on the pan. Had to drop the headers since I have a custom welded exhaust which runs directly underneath and was curious as to whether or not they had seals inside the engine block where the pipes fit in? I orders some Honda bond for the oil pan, so that's covered :) any help is awesome!! My new oil pan comes in next week.
Mikey Messina is offline
post #2 of 7 (permalink) Old 04-21-2017, 12:10 AM
FightingChance's Avatar
Feedback Score: 10 reviews
You mean seals where the exhaust headers mate with the engine?
FightingChance is online now
The Following User Says Thank You to FightingChance For This Useful Post:
dixon cider (04-23-2017)
post #3 of 7 (permalink) Old 04-21-2017, 04:04 PM Thread Starter
Yes!! That's exactly what I'm talking about
post #4 of 7 (permalink) Old 04-21-2017, 04:20 PM
Speak917's Avatar
Yes there are exhaust gaskets that should be replaced; be sure you pull the old ones out.
Speak917
Speak917 is offline
The Following User Says Thank You to Speak917 For This Useful Post:
post #5 of 7 (permalink) Old 04-23-2017, 12:08 AM
Yeah, you will need 4 new crush gaskets. The old ones may need some pliers to take out.
post #6 of 7 (permalink) Old 04-29-2017, 12:42 AM Thread Starter
Smoke after oil pan replacement
So.. I swapped my cracked oil pan out and now there's smoke coming off of my exhaust right near the pan.. It's not that audible but I can smell it and it's still happening after riding around for an hour or so.. idk if it's from residual oil that was caked up or from the silicone sealant I put on the pan and it spilled out onto the exhaust but any help would be awesome!!
post #7 of 7 (permalink) Old 04-30-2017, 01:09 AM
keeblerkhan's Avatar
If you put enough sealant on that it squeezed out onto your headers, then you used way too much. You also likely squeezed at least that much out into the interior of your oil pan and it can(will) clog oil passages.
keeblerkhan is offline
Human Verification
