Marvel Mystery Oil.. - 600RR.net
post #1 of 18 (permalink) Old 12-04-2007, 12:41 AM Thread Starter
F_iT23's Avatar
Did a search and found lots of nothing. Just wondering if you guys use it? What are your opinions on it?
F_iT23 is offline
post #2 of 18 (permalink) Old 12-04-2007, 03:45 AM
Hitz eit from z back
600rr Rider's Avatar
Its good stuff, Never used it on any bikes before but on an old seized engine my friend had. The piston wouldn't move so I went and grabbed some of that let it sit for a few hours and was able to slowly get the piston out and was then able to hone the cylinder and get the engine running again. What are you going to be using it for?
600rr Rider is offline
post #3 of 18 (permalink) Old 12-04-2007, 05:19 AM Thread Starter
F_iT23's Avatar
For my bike, but I want to know If you guys have had any experience with it in bikes.
F_iT23 is offline
post #4 of 18 (permalink) Old 12-04-2007, 05:44 AM
No experience with it on bikes, only that one engine. My dads the one that told me about it, I'll see if he knows more about it. Their has to be someone on here that has used it before on a bike though.
post #5 of 18 (permalink) Old 12-04-2007, 01:46 PM
Knightslugger
Posts: n/a
i wouldn't run any additives that have unknown contents in the oil when we're talking about a shared sump wet friction clutch...
post #6 of 18 (permalink) Old 12-04-2007, 01:56 PM
Rizoma King
sorenmd's Avatar
Correct, usually they cause slippage...
sorenmd is offline
post #7 of 18 (permalink) Old 02-22-2008, 09:07 PM
Marvel Mystery Oil is good stuff... I add a bottle to my gas tank (car) every 5k miles. It does a good job of keeping the fuel system & injectors clean.
As previously mentioned, I would not suggest adding it to your oil (bike) as it may effect the clutch operation, howerver, adding a few ounces to your gas tank every couple thousand miles couldn't hurt!
Kris05TSX is offline
post #8 of 18 (permalink) Old 03-31-2008, 01:39 PM
I used to use it bout 15 years ago in an old Harley Shovelhead. Suppossedly it would help with valve seat lubrication since they were originally designed for leaded gas. I don't think I would use is in my CBR tho.
mp597 is offline
post #9 of 18 (permalink) Old 04-01-2008, 02:46 PM
enfant's Avatar
does it come with a free spiderman action figure?
enfant is offline
post #10 of 18 (permalink) Old 04-01-2008, 03:16 PM
MXRider's Avatar
Feedback Score: 17 reviews
dont use it^, i dont want any mysteries when it comes to my engine oil.....
amsoil, repsol, motorex. run one of those in the recommended weight for your bike/temp range.
the owners manual will tell u what type exactly.
MXRider is offline
post #11 of 18 (permalink) Old 04-01-2008, 06:01 PM
Its not really an oil, its more like an additive. I use to throw in a capful in the gas tank of my harley.
mp597 is offline
post #12 of 18 (permalink) Old 04-01-2008, 06:46 PM
MXRider's Avatar
well since honda knows how to build a reliable engine i wouldnt worry about it in your RR ;)
MXRider is offline
post #13 of 18 (permalink) Old 04-06-2008, 11:23 PM
Ok cheap shot but funny
mp597 is offline
post #14 of 18 (permalink) Old 10-24-2012, 01:49 PM
I wanna bring this one back to life. I have a neighbor that's a professional race car/performance vehicle mechanic, and when I ran into him in the garage the other day, I started telling him all about my bike and what I was doing to it, how it hadn't been run in two years, and how I was bringing her back to life with all sorts of new fluids and checks.
He asked me if I had turned the engine over yet and I told him no. He suggested marvel mystery oil. He said that some of my valves had been sitting in the open position for two years, and that he thinks it's a good idea to add marvel mystery oil to the list of things I do before I run it.
I finished the oil change last night with mobil 1 syn. 10W40, a new bosche filter, and a new drain plug and washer, and my chain has been degreased and lubed with motul degreaser and lucas chain oil.
Tonight, I'm going to drain the stale fuel and replace it with some fresh shell 91, as well as replace the old air filter with a K&N.
I was just wondering if anyone can chime in with a yay or nay regarding the marvel mystery oil? Or should I just fire her up when I'm done and be good with it?
(I have engine ice coolant and some dot 4 brake fluid I plan on doing later, maybe this weekend or something.)
Thanks guys.
Soska is offline
post #15 of 18 (permalink) Old 11-28-2012, 03:04 AM
NaturalPhenomenon's Avatar
Marvel mystery oil is actually mineral oil, refined and aditives. When you are doing a cleaning of ur crank case for the year or for when u need to, I add an ounce of seafoam or marvel. And run it for 20 to 50 miles. It does have aditives and will make your clutch slip. Its not ment for long term. I found on my kawasaki it removed sludge and improved my oil presure.
Sent from my LG-C800 using Motorcycle.com Free App
NaturalPhenomenon is offline
post #16 of 18 (permalink) Old 11-28-2012, 03:30 AM
clx
i remember the duralube craze in the late 90's. was supposed to be the ultimate additive. my brother added it to his car and had to rebuild the engine within 6 months.
i see it was found they lied about everything and was fined and bancrupted. if honda wanted us to add stuff, they would have specified it.
2005 600rr 36300km
2001 Isuzu kb 320 V6 LX double cab 212000km
clx is offline
post #17 of 18 (permalink) Old 11-28-2012, 06:29 AM
TheX's Avatar
Images: 2
Feedback Score: 5 reviews
Do you run synthetic oil? After market air filter? Slip on? PC3?
Iím jealous of all the people that haven't met you.
TheX is offline
post #18 of 18 (permalink) Old 11-28-2012, 07:14 AM
clx
i run whatever oil the dealer uses when serviced
aftermarket air filter as recommended by service agent
slip on, no, her fanny is standard
pc3, no
i see what your saying, but there is a difference between using a different type or grade of oil, and adding a completely different substance in addition to oil.
as indicated in my previous post i am not completely foreign to aditives. weve tried it, with mixed results, some very expensive
2005 600rr 36300km
clx is offline
Human Verification
