Hey guys, i recently got a 03 cbr 600 for 800 bucks. Has ton of after market parts really nice bike, only problem is it was all taken apart. They wanted to do a valve job on it and they took the whole bike apart. Including the wiring. The dash turns on and bike cranks over but has no spark and the fuel pump isn't priming, checked all fuses including PGM fi fuse. FI light is on, Also i don't have everything connected there is lots on connecters that don't have anywhere to plug into. I tired looking on a wiring diagram and can't find where they plug into which is making me think i have missing sensors/wiring harness. I have all main things connected, throttle bodies, have a good ground, all connecters from dash are connected, ecu . Is there any wiring harness that is separate from the main wiring like the coil harness that plugs into the main harness, and what needs to be plugged in for the bike to have spark and fuel pump signal. Also can i read codes on the bike? I had i had gsxr and i used to be able to read codes on that. Thanks guys
