So I over filled my bike with oil and I was riding it and it started smoking alot from the pipe and then died. What can i do to fix the problem. Now when I try to start it, it makes a clicking sound from by the battery.
You sure it hydrolocked?
Can motor be turned over by push starting the bike?
Or remove the crank cover (the small one in the center of cover) and turn the motor over with a socket wrench?
This doesn't add up. Overfilling the oil (unless atrociously overfilled, maybe) doesn't result in the engine being hydrolocked. Drain the oil to the proper level, then you'll need to figure out the other problem. Head gasket? Battery? Battery connections?
