1 - 3 of 3 Posts
the fuel pump in my bike will not prime when i turn the key.I have been able to turn the switch on and off like 20 times and the pump will randomly prime.Does this sound like a ground/relay problem or the fuel pump itself???
Check the relays under the left side ram air cover
Did you mess with the upper or the headlights at all ?
BAS bank angle sensor might be loose
K
randomly as you toggle the run switch? sounds like something is loose or malfuntioning. either something in the switch itself, the fuel cut off relay, or the BAS.
1 - 3 of 3 Posts
