1 - 3 of 3 Posts
So hi everyone I have a 05 cbr600rr and when I am under a heavy load or WOT when the bike is accelerating it seems to
Lose power at 9000-10000 rpm then Comes back to life after 10000 rpm..then in between 120000-13000rpm it does the same thing again. Loses power. It only does it between those exact rpms every time. Please help if anyone has ever experienced this befor. Thank you
These are just suggestions.
Sounds electrical, so check the plug caps are on securely, maybe put new spark plugs in if they haven't been changed in a while, they might be breaking down.
Also might be a sensor problem: air temperature sensors; water temperature sensors.
Possibly a loose wire? Hard to find, but start at the connections on the battery and make sure they are tight. Vibrations at certain revs might be enough to loosen them.
Thank you for the response. I am gonna put new plugs in it and do a coolant flush at the same time. I was told about this yellow ground block that may have a loose connection as well. Just have to find that and see as well
1 - 3 of 3 Posts
